YC104-JR-071ML
YC104-JR-071ML
    YAGEO(国巨)
    排阻/电阻网络 0502 1MΩ ±5% 31mW ±200ppm/℃
YC104-JR-071ML 数据手册
120 DATA SHEET ARRAY CHIP RESISTORS YC/TC 5%, 1% sizes YC:102/104/122/124/162/164/248/324/158T/358L/358T TC: 122/124/164 Product Specification – February 21, 2019 V.9 RoHS compliant 2 Product specification Chip Resistor Surface Mount YC/TC 12 102 to 358 SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC This specification describes YC (convex, flat) and TC (concave) series chip resistor arrays with leadfree terminations made by thick film process. Both part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. YAGEO BRAND ordering code GLOBAL PART NUMBER (PREFERSRED ) APPLICATIONS  Terminal for SDRAM and DDRAM  Computer applications: laptop computer, desktop computer  Consume electronic equipments: PDAs, PNDs  Mobile phone, telecom… FEATURES  AEC-Q200 qualified  More efficient in pick & place application  Low assembly costs  RoHS compliant  Products with lead free terminations meet RoHS requirements  Pb-glass contained in electrodes  Resistor element and glass are exempted by RoHS  Reducing environmentally hazardous wastes  High component and equipment reliability  Saving of PCB space  None forbidden-materials used in products/production  Halogen Free Epoxy  MSL class: MSL 1 YC TC XXXX X X X X XX XXXX L/T (1) (2) (3) (4) (5) (6) (7) (8) (1) SIZE YC:102/104/122/124/162/164/248/324/158T/358L/358T TC: 122/124/164 (2) ARRAYS OR NETWORKS Array YC102/104/122/124/162/164/248/324: Network YC158T/YC358L/YC358T: NA (3) TOLERANCE F = ± 1% J = ± 5% (for Jumper ordering, use code of J) (4) PACKAGING TYPE R = Paper taping reel K = Embossed plastic tape reel (5) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec (6) TAPING REEL 07 = 7 inch dia. Reel 13 = 13 inch dia. Reel (7) RESISTANCE VALUE There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point. Detailed resistance rules show in table of “Resistance rule of global part number”. (8) DEFAULT CODE Letter L is the system default code for ordering only. (Note) Letter T is the only default code for YC102. O RDERING EXAMPLE The ordering code of a YC122 convex chip resistor array, value 1,000 Ω with ± 5% tolerance, supplied in 7-inch tape reel is: YC122-JR-071KL. Resistance rule of global part number Resistance code rule Example 0R 0R = Jumper XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω NOTE XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω 1. All our RSMD products meet RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" XXXR (100 to 976 Ω) 100R = 100 Ω 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω YC158T network, value 100,000 tape reel is: YC158TJR-07100KL with 5% tolerance, supplied in 7-inch XM (1 MΩ) 1M = 1,000,000 Ω www.yageo.com Feb. 21, 2019 V.9 Product specification Chip Resistor Surface Mount YC/TC SERIES 3 12 102 to 358 MARKING YC102 No marking ynsc142 Fig. 1 YC122 No marking Fig. 2 ynsc008 YC104 No marking Fig. 3 YNSC108_1 YC124 / 162 / 164 / 324 0 1-Digit marking YNSC010 Fig. 4 Jumper=0Ω 2 E-24 series: 3 digits, 5% YNSC029 Fig. 4-1 Value=240KΩ First two digits for significant figure and 3rd digit for number of zeros YC248 0 1-Digit marking YNSC014 Fig. 5 Jumper=0Ω 2 E-24 series: 3 digits, 5% YNSC035 Fig. 5-1 Value=240KΩ First two digits for significant figure and 3rd digit for number of zeros YC158T/358L/358T E-24 series: 3 digits 2 YNSC072 Fig. 6 Value=24Ω YNSC034 Fig. 6-1 Value=240KΩ First two digits for significant figure and 3rd digit for number of zeros TC122 No marking ynsc060 Fig. 7 TC124 No marking YNSC061 Fig. 8 www.yageo.com Feb. 21, 2019 V.9 Product specification Chip Resistor Surface Mount YC/TC SERIES 4 12 102 to 358 TC164 0 1-Digit marking YNSC032 Fig. 9 Jumper=0Ω 2 E-24 series: 3 digits, 5% YNSC036 First two digits for significant figure and 3rd digit for number of zeros Fig. 9-1 Value=240KΩ For further marking information, please refer to data sheet “Chip resistors marking”. CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environment influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Nibarrier) are added as shown in Fig.10. OUTLINES overcoat resistive layer inner electrode termination ceramic substrate YNSC069 Fig. 10 Chip resistor outlines www.yageo.com Feb. 21, 2019 V.9 Product specification Chip Resistor Surface Mount YC/TC SERIES 102 to 358 5 12 SCHEMATIC Fig. 11 Equivalent circuit diagram Note: 1. YC102/104 is flat type For dimension, please refer to Table 1 T W1 W2 YC102_ T YC 122/162 YC 104/124/164/324 158/358/248 Hw H H H P a B B B Side view for all types P L P L a H1 L TC 122 TC 124/164 H H P a B B P L a L unit: m m Fig. 12 YC/TC122 series chip resistors dimension Note: (1) YC102/104 is flat type www.yageo.com Feb. 21, 2019 V.9 Product specification Chip Resistor Surface Mount YC/TC SERIES 6 12 102 to 358 DIMENSIONS Table 1 TYPE YC102 H / H1 / HW B P L T W1 W2 H : 0.25± 0.10 0.15± 0.10 0.55± 0.10 0.80± 0.10 0.35± 0.10 0.15± 0.10 0.60± 0.10 YC104 H : 0.20± 0.10 0.15± 0.05 0.40± 0.10 1.40± 0.10 0.35± 0.10 0.15± 0.10 0.60± 0.10 YC122 H : 0.210.10 / -0.05 HW : 0.35± 0.10 0.20± 0.10 0.67± 0.05 1.00± 0.10 0.30± 0.10 0.25± 0.10 1.00± 0.10 YC124 H: 0.40± 0.15 H1: 0.30± 0.05 0.20± 0.15 0.50± 0.05 2.00± 0.10 0.45± 0.10 0.30± 0.15 1.00± 0.10 YC162 H : 0.30± 0.10 HW : 0.65± 0.15 0.30± 0.10 0.80± 0.05 1.60± 0.10 0.40± 0.10 0.30± 0.10 1.60± 0.10 YC164 H : 0.65± 0.05 H1: 0.50± 0.15 0.30± 0.15 0.80± 0.05 3.20± 0.15 0.60± 0.10 0.30± 0.15 1.60± 0.15 YC248 H : 0.45± 0.05 H1: 0.30± 0.05 0.30± 0.15 0.50± 0.05 4.00± 0.20 0.45± 0.10 0.40± 0.15 1.60± 0.15 YC324 H : 1.10± 0.15 H1: 0.90± 0.15 0.50± 0.20 1.27± 0.05 5.08± 0.20 0.60± 0.10 0.50± 0.15 3.20± 0.20 TC122 H : 0.30± 0.05 0.25± 0.15 0.50± 0.05 1.00± 0.10 0.30± 0.10 0.25± 0.15 1.00± 0.10 TC124 H : 0.30± 0.10 0.20± 0.10 0.50± 0.05 2.00± 0.10 0.40± 0.10 0.25± 0.10 1.00± 0.10 TC164 H : 0.50± 0.15 0.30± 0.15 0.80± 0.05 3.20± 0.15 0.60± 0.10 0.30± 0.15 1.60± 0.15 YC158T H : 0.45± 0.05 H1: 0.32± 0.05 0.30± 0.15 0.64± 0.05 3.20± 0.20 0.60± 0.10 0.35± 0.15 1.60± 0.15 YC358L YC358T H : 1.10± 0.15 H1: 0.90± 0.15 0.50± 0.15 1.27± 0.05 6.40± 0.20 0.60± 0.10 0.50± 0.15 3.20± 0.20 www.yageo.com Feb. 21, 2019 V.9 Product specification Chip Resistor Surface Mount YC/TC SERIES 7 12 102 to 358 ELECTRICAL CHARACTERISTICS Table 2 POWER TYPE P70 YC102 1/32W OPERATING MWV TEMP. RANGE -55°C to +125°C RESISTANCE RANGE & TOLERANCE RCOV DWV 30V 30V E24 ± 5% 10Ω≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω≤ R ≤ 1MΩ Jumper < 0.05Ω 15V T. C. R. Jumper criteria (unit: A) Rated current 0.5 Max. current 1.0 ± 200 ppm/°C YC104 1/32W -55°C to +125°C 12.5V 25V 25V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω YC122 1/16W -55°C to +155°C 50V 100V 100V E24 ± 5% 1Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 1Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω YC124 1/16W -55°C to +155°C 25V 50V 100V E24 ± 5% 1Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 1Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω YC162 1/16W -55°C to +155°C 50V 100V 100V E24 ± 5% 1Ω ≤ R ≤ 1MΩ E/24/E96 ± 1% 1Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω YC164 1/16W -55°C to +155°C 50V 100V 100V E24 ± 5% 1Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 1Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω Rated current 1.0 Max. current 2.0 YC248 1/16W -55°C to +155°C 50V 100V 100V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω Rated current 2.0 Max. current 10.0 YC324 1/8W -55°C to +155°C 200V 500V 500V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ TC122 1/16W -55°C to +125°C 50V 100V 100V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω Rated current 1.0 Max. current 1.5 Rated current 1.0 Max. current 2.0 TC124 1/16W -55°C to +125°C 50V 100V 100V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω TC164 1/16W -55°C to +155°C 50V 100V 100V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω YC158T 1/16W -55°C to +155°C 25V 50V 50V E24 ± 5% YC358L 1/16W YC358T -55°C to +155°C 50V 100V 100V E24 ± 5% 10Ω≤ R ≤ 330KΩ Rated current 0.5 Max. current 1.0 Rated current 0.5 Max. current 1.0 1Ω ≤ R ≤ 10Ω ± 250 ppm/°C 10Ω < R ≤ 1MΩ ± 200 ppm/°C Rated current 1.0 Max. current 2.0 Rated current 1.0 Max. current 2.0 --- ± 200 ppm/°C --- Rated current 1.0 Max. current 1.5 10Ω ≤ R ≤ 100KΩ --- --- --- --- FOOTPRINT AND SOLDERING PROFILES For recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity YC102/ 104 YC/TC 122 YC/TC 124 YC162 7" (178mm) 10,000 10,000 10,000 5,000 5,000 5,000 --- 5,000 --- 13" (254mm) 50,000 50,000 40,000 --- 20,000 --- --- 20,000 --- --- --- --- --- --- 4,000 4,000 --- 4,000 PACKING STYLE PACKING STYLE Paper taping reel ( R ) Embossed taping reel ( K) 7" (178mm) YC/TC YC248 164 YC324 YC158T YC358L YC358T NOTE 1. For tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”. www.yageo.com Feb. 21, 2019 V.9 Product specification Chip Resistor Surface Mount YC/TC FUNCTIONAL DESCRIPTION OPERATING TEMPERATURE RANGE YC102/104, TC122/124 Range: -55 to +125 (Fig.13) YC122/124/162/164/248/324/158T/358L/358T, TC164 Range: -55 to +155 (Fig.14) SERIES 8 12 102 to 358 handbook, P halfpage MLB206 max (%Prated) 100 50 POWER RATING Each type rated power at 70 YC102/104 = 1/32 W YC122/124/162/164/248/158T/358L/358T = 1/16 W YC324 = 1/8 W 0 55 0 50 70 100 125 o Tamb ( C) Fig. 13 Maximum dissipation (P) in percentage of rated power as a function of the operating ambient temperature (T amb) TC122/124/164 = 1/16 W R ATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: MLB206_1 P (%Prated ) 100 V= (PxR) or max. working voltage whichever is less 50 Where V=Continuous rated DC or AC (rms) working voltage (V) R=Resistance value ( 0 55 P=Rated power (W) ) 0 50 70 100 155 o Tamb ( C) Fig. 14 Maximum dissipation (P) in percentage of rated power as a function of the operating ambient temperature (T amb) www.yageo.com Feb. 21, 2019 V.9 Product specification Chip Resistor Surface Mount YC/TC SERIES 9 12 102 to 358 TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Life/ Operational Life/ Endurance MIL-STD-202-method 108 1,000 hours at 70± 5 °C applied RCWV 1.5 hours on, 0.5 hour off, still air required ± (2%+0.05 Ω) High Temperature Exposure/ Endurance at Upper Category Temperature MIL-STD-202-method 108 1,000 hours at maximum operating temperature depending on specification, unpowered ± (1%+0.05 Ω)
YC104-JR-071ML 价格&库存
很抱歉,暂时无法提供与“YC104-JR-071ML”相匹配的价格&库存,您可以联系我们找货
