RAVF168DFT4K70
RAVF168DFT4K70
    SEI
    RA_0402X8
    排阻/电阻网络 0402x8 4.7kΩ ±1% 63mW ±200ppm/℃
RAVF168DFT4K70 数据手册
RAVF Series Stackpole Electronics, Inc. Resistive Product Solutions Convex Termination Chip Resistor Array Features: • • • • • • • • • • • Thick film resistor element Multiple circuit types available Ideal SMD substitute for leaded networks Auto-placement capability Square corner construction standard Zero-ohm jumper available RAVF 324D is standard with scalloped corner Styles 102D, 104D and 164D are qualified to AEC-Q200 RoHS compliant and halogen free Halogen free REACH compliant Electrical Specifications Type/Code, # of Elements, Circuit Type Power Rating (W) (per element) @ 70ºC 0.063 RAVF102D Maximum Working Voltage (1) (V) Maximum Overload Voltage (V) TCR (ppm/ºC) 50 ± 400 ± 200 25 Ohmic Range (Ω) and Tolerance Jumper: 1A 0.063 RAVF104D 25 50 Jumper: 1A 0.063 Jumper: 1A 50 100 0.1 50 100 25 50 Jumper: 1A RAVF324D 0.125 200 RAVF328N 0.063 25 RAVF328R 0.063 25 (1) Lesser of √ P*R or maximum working voltage. 400 50 50 RAVF162D RAVF164D ± 400 ± 200 ± 200 ± 400 ± 200 Jumper: 1A 0.063 RAVF168D ± 250 ± 200 ± 200 ± 200 ± 200 1% - 2%, 5% 1 - 9.1 10 - 1M 0.025 max - 0.05 max 1 - 9.1 10 - 1M 0.025 max 10 - 1M 10 - 1M 0.025 max 10 - 1M 22 - 1M - 0.05 max 1 - 1M 0.05 max 1. - 9.1 10 - 1M 0.05 max 1 - 1M 0.05 max 10 - 1M 22 - 1M 22 - 1M Schematics Isolated Circuit - 2D Isolated Circuit - 4D Isolated Circuit - 8D Rev Date: 7/30/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 1 Bussed Circuit - N Bussed Circuit - R www.seielect.com marketing@seielect.com RAVF Series Stackpole Electronics, Inc. Resistive Product Solutions Convex Termination Chip Resistor Array Terminations RAVF - 2 Resistors / 4 Terminations (D) Type/Code # of Elements Circuit Type RAVF102D RAVF104D RAVF162D RAVF164D RAVF168D RAVF324D RAVF328N RAVF328R L Body Length 0.039 1.00 0.079 2.00 0.063 1.60 0.126 3.20 0.157 4.00 0.201 5.10 0.126 3.20 0.126 3.20 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.004 0.10 0.008 0.20 0.006 0.15 0.008 0.20 0.008 0.20 0.009 0.22 0.006 0.15 0.006 0.15 W Body Width 0.039 1.00 0.039 1.00 0.063 1.60 0.063 1.60 0.063 1.60 0.122 3.10 0.063 1.60 0.063 1.60 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.004 0.10 0.006 0.15 0.006 0.15 0.008 0.20 0.006 0.15 0.008 0.20 0.006 0.15 0.006 0.15 RAVF - 4 Resistors / 8 Terminations (D) H Body Height 0.014 0.35 0.014 0.35 0.020 0.50 0.020 0.50 0.016 0.40 0.022 0.55 0.022 0.55 0.022 0.55 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.004 0.10 0.006 0.15 0.006 0.15 0.004 0.10 0.004 0.10 0.006 0.15 0.004 0.10 0.004 0.10 P Element Spacing 0.026 ± 0.039 0.67 ± 1.00 0.020 ± 0.006 0.50 ± 0.15 0.031 ± 0.002 0.80 ± 0.05 0.031 ± 0.008 0.80 ± 0.20 0.020 ± 0.006 0.50 ± 0.15 0.051 ± 0.008 1.30 ± 0.20 0.025 ± 0.002 0.64 ± 0.05 0.025 ± 0.002 0.64 ± 0.05 Q Termination Width 0.012 ± 0.004 0.30 ± 0.10 0.020 ± 0.006 0.50 ± 0.15 0.010 ± 0.004 0.25 ± 0.10 0.031 ± 0.008 0.80 ± 0.20 0.013 ± 0.006 0.34 ± 0.15 0.013 ± 0.006 0.34 ± 0.15 RAVF - 8 Resistors / 10 Terminations (N/R) R Termination Width 0.013 ± 0.004 0.34 ± 0.10 0.017 ± 0.004 0.43 ± 0.10 0.024 ± 0.006 0.60 ± 0.15 0.024 ± 0.006 0.61 ± 0.15 0.015 ± 0.004 0.38 ± 0.10 0.031 ± 0.008 0.80 ± 0.20 0.019 ± 0.006 0.49 ± 0.15 0.019 ± 0.006 0.49 ± 0.15 D Bottom Termination 0.010 ± 0.039 0.25 ± 1.00 0.008 +0.006/-0.004 0.20 +0.15/-0.10 0.012 ± 0.006 0.30 ± 0.15 0.012 ± 0.008 0.30 ± 0.20 0.012 ± 0.008 0.30 ± 0.20 0.022 ± 0.012 0.55 ± 0.30 0.010 ± 0.006 0.25 ± 0.15 0.010 ± 0.006 0.25 ± 0.15 A Top Termination 0.006 ± 0.004 0.15 ± 0.10 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.006 0.30 ± 0.15 0.012 ± 0.008 0.30 ± 0.20 0.012 ± 0.008 0.30 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 0.012 ± 0.008 0.30 ± 0.20 0.012 ± 0.008 0.30 ± 0.20 Unit Inches mm Inches mm Inches mm Inches mm Inches mm Inches mm Inches mm Inches mm Performance Characteristics Test Test Result (JIS C 5202) Load Life in Moisture Temperature cycle Load Life Resistance to Soldering heat Terminal Adhesion Short Time Overload Operating temperature range is -55°C to +155°C, except for RAVF328N and RAVF328R Operating temperature range for RAVF328N and RAVF328R is -55°C to +125°C ±3% ±1% ±3% ±1% ±1% ±2% Power Derating Curve: Rev Date: 7/30/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com RAVF Series Stackpole Electronics, Inc. Resistive Product Solutions Convex Termination Chip Resistor Array Recommended Pad Layout Type/Code RAVF102D RAVF162D A B P Q1 Q2 Unit 0.020 0.50 0.039 1.00 0.079 2.00 0.102 2.60 0.026 0.67 0.031 0.80 0.013 0.33 0.016 0.40 0.013 0.34 0.016 0.40 Inches mm Inches mm Type/Code A B P Q Q1 Q2 Unit RAVF104D 0.020 0.50 0.079 2.00 0.020 0.50 0.012 0.30 0.016 0.40 0.008 0.20 Inches mm Type/Code RAVF164D RAVF324D Type/Code RAVF168D A B P Q1 Q2 Unit 0.039 1.00 0.079 2.00 0.102 2.60 0.187 4.75 0.031 0.80 0.051 1.30 0.016 0.40 0.035 0.90 0.016 0.40 0.015 0.38 Inches mm Inches mm A 0.039 1.00 Rev Date: 7/30/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. B 0.110 2.80 3 P 0.020 0.50 Q1 0.012 0.30 Unit Inches mm www.seielect.com marketing@seielect.com RAVF Series Stackpole Electronics, Inc. Resistive Product Solutions Convex Termination Chip Resistor Array Recommended Pad Layout (cont.) Type/Code RAVF328R A 0.031 0.80 B 0.122 3.10 P 0.025 0.64 Q1 0.013 0.34 Q2 0.018 0.45 Unit Inches mm Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Minimum 60 seconds 100°C 240°C * N/A Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Rev Date: 7/30/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com RAVF Series Stackpole Electronics, Inc. Resistive Product Solutions Convex Termination Chip Resistor Array Recommended Lead Free Resistor Reflow Profile RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Termination Type Thick Film Surface Mount Chip Resistor Array Convex Terminations Note (1): RoHS Compliant by means of exemption 7c-I. RAVF SMD Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) YES(1) 100% Matte Sn over Ni Jan-04 (Japan) Jul-04 (Taiwan) Lead-Free Effective Date Code (YY/WW) 04/01 04/27 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Rev Date: 7/30/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com RAVF Series Stackpole Electronics, Inc. Resistive Product Solutions Convex Termination Chip Resistor Array Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 14 R A V F 1 6 4 D J T 1 0 K 0 Product Series Code Description Convex RAVF Termination Size Code W 102D 0.063 104D 0.063 162D 0.063 164D 0.1 168D 0.063 324D 0.125 328N 0.063 328R 0.063 Tolerance(1) Code Tol Value F 1% E24 G 2% J 5% Z jumper Code T Packaging Size 102D, 104D 162D, 164D, 168D Tape and Reel 328N, 328R 324D Description Resistance Value Quantity 10000 5000 4000 Note (1): 1% tolerance is available in E24 values only. E96 values are generally not available. Contact Stackpole for details. Four characters with the multiplier used as the decimal holder. 10 ohm = 10R0 10.2 Kohm = 10K2 1 Mohm = 1M00 Zero ohm jumper = 0R00 D = Isolated N = Bussed R = Bussed Rev Date: 7/30/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 6 www.seielect.com marketing@seielect.com
RAVF168DFT4K70
物料型号:RAVF系列,包括102D, 104D, 162D, 164D, 168D, 324D, 328N, 328R等型号。
器件简介:RAVF系列是由Stackpole Electronics, Inc.生产的凸端芯片电阻阵列,具有多种电路类型,是理想的SMD替代引脚网络,具备自动放置能力,标准直角构造,并且有零欧姆跳线选项。
引脚分配:文档提供了不同型号的引脚分配和尺寸信息,例如RAVF102D为2个电阻/4个引脚(D),RAVF164D为8个电阻/10个引脚(N/R)。
参数特性:包括功率额定值、最大工作电压、最大过载电压、温度系数、欧姆范围和公差等。例如,RAVF102D的功率额定值为每个元件0.063W,最大工作电压为25V。
功能详解:文档提供了电阻阵列的电气规格、性能特性测试结果、推荐焊盘布局和焊接温度曲线等详细信息。
应用信息:RAVF系列电阻阵列适用于需要小型化和高可靠性电阻网络的应用场合。
封装信息:提供了不同型号的尺寸参数,包括体长、体宽、体高、元件间距、引脚宽度等,单位有英寸和毫米两种。
RAVF168DFT4K70 价格&库存
很抱歉,暂时无法提供与“RAVF168DFT4K70”相匹配的价格&库存,您可以联系我们找货
