REVISION X
CLP-1XX-XX-XX-S-XX
No. OF POSITIONS
-02 THRU -50
DO NOT
SCALE FROM
THIS PRINT
OPTION
-TR: TAPE AND REEL
BODY SPEC
-S: SINGLE ROW
(USE CLP-50-S)
LEAD STYLE SPEC
-02: SURFACE MOUNT
(USE C-106-01-X)
C1
(NO OF POS X .0500[1.270])+.017[0.43]±.005[0.13]
PLATING SPEC
-G: 10µ" GOLD IN CONTACT AREA,
3µ" GOLD ON TAIL
-F: 3µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-L: 10µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-FM: 3µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
02
.025 0.64 REF
01
03
C-106-01-X
.0160 0.406 x .0050[.127] REF
C2
1 MAX SWAY
(ANY DIRECTION)
(NO OF POS X .0500[1.270]) - .0500[1.270] REF
"A"
C3
.0890 2.261
(MEASURE AT BEND)
.0835 2.121 REF
+3
C4
.004[0.10 POS. 2-25
.006[0.15 POS. 26-50
"A"
-3
.119±.010 3.02±0.25
(SEE NOTE 3)
TUBE PACKAGING
SECTION "A"-"A"
SCALE 3:1
CLP-50-S
TUBE: PT-1-24-02-65
PLUG: TP-30
C6
C5
NOTES:
1. C PREPRESENTS A CRITICAL DIMENSION FOR STATISTICAL PROCESS CONTROL.
2. MINIMUM PUSHOUT FORCE: .5 LB.
3. SHEAR TAILS TO DIMENSIONS SHOWN.
4. PARTS TO BE SYMMETRICAL ABOUT CL .
5. WILL LOSE ONE POSITION PER CUT TO OBTAIN ODD POSITION PARTS.
WILL LOSE TWO POSITIONS PER CUT TO OBTAIN EVEN POSITION PARTS.
6. TUBE PACKAGE POSITIONS 5 THROUGH 50 ONLY. POSITIONS 2 THRU4
ARE TO BE LAYER PACKAGED.
7. .002[0.05] MAX BURR.
8. CUT FLASH TO BE .010[0.25] MAX WITH NO FLASH ALLOWED IN HOLES
OR EXTENDING BELOW LEADS.
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 6:1
INSULATOR: LCP, UL 94 VO, COLOR: BLACK
CONTACT: PHOS BRONZE
F:\DWG\MISC\MKTG\CLP-1XX-XX-XX-S-XX-MKT.SLDDRW
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
LOW PROFILE .050 C.L. SINGLE ROW ASM.
DWG. NO.
CLP-1XX-XX-XX-S-XX
BY: BRATCHER 06/07/1995
SHEET 1 OF 1
很抱歉,暂时无法提供与“CLP-103-02-L-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+10.571721+1.36577
