CLP-113-02-L-S-TR
CLP-113-02-L-S-TR
    SAMTEC(申泰)
    SMD,P=1.27mm
    排母 间距:1.27mm 1x13P 立贴
CLP-113-02-L-S-TR 数据手册
REVISION X CLP-1XX-XX-XX-S-XX No. OF POSITIONS -02 THRU -50 DO NOT SCALE FROM THIS PRINT OPTION -TR: TAPE AND REEL BODY SPEC -S: SINGLE ROW (USE CLP-50-S) LEAD STYLE SPEC -02: SURFACE MOUNT (USE C-106-01-X) C1 (NO OF POS X .0500[1.270])+.017[0.43]±.005[0.13] PLATING SPEC -G: 10µ" GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -F: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -L: 10µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -FM: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL 02 .025 0.64 REF 01 03 C-106-01-X .0160 0.406 x .0050[.127] REF C2 1 MAX SWAY (ANY DIRECTION) (NO OF POS X .0500[1.270]) - .0500[1.270] REF "A" C3 .0890 2.261 (MEASURE AT BEND) .0835 2.121 REF +3 C4 .004[0.10 POS. 2-25 .006[0.15 POS. 26-50 "A" -3 .119±.010 3.02±0.25 (SEE NOTE 3) TUBE PACKAGING SECTION "A"-"A" SCALE 3:1 CLP-50-S TUBE: PT-1-24-02-65 PLUG: TP-30 C6 C5 NOTES: 1. C PREPRESENTS A CRITICAL DIMENSION FOR STATISTICAL PROCESS CONTROL. 2. MINIMUM PUSHOUT FORCE: .5 LB. 3. SHEAR TAILS TO DIMENSIONS SHOWN. 4. PARTS TO BE SYMMETRICAL ABOUT CL . 5. WILL LOSE ONE POSITION PER CUT TO OBTAIN ODD POSITION PARTS. WILL LOSE TWO POSITIONS PER CUT TO OBTAIN EVEN POSITION PARTS. 6. TUBE PACKAGE POSITIONS 5 THROUGH 50 ONLY. POSITIONS 2 THRU4 ARE TO BE LAYER PACKAGED. 7. .002[0.05] MAX BURR. 8. CUT FLASH TO BE .010[0.25] MAX WITH NO FLASH ALLOWED IN HOLES OR EXTENDING BELOW LEADS. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 6:1 INSULATOR: LCP, UL 94 VO, COLOR: BLACK CONTACT: PHOS BRONZE F:\DWG\MISC\MKTG\CLP-1XX-XX-XX-S-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: LOW PROFILE .050 C.L. SINGLE ROW ASM. DWG. NO. CLP-1XX-XX-XX-S-XX BY: BRATCHER 06/07/1995 SHEET 1 OF 1
CLP-113-02-L-S-TR 价格&库存
很抱歉,暂时无法提供与“CLP-113-02-L-S-TR”相匹配的价格&库存,您可以联系我们找货
CLP-113-02-L-S-TR
  • 1650+17.617721650+2.28707
