SSM-108-F-SV
SSM-108-F-SV
    SAMTEC(申泰)
    SMD,P=2.54mm
    1X8P 间距:2.54MM 立贴
SSM-108-F-SV 数据手册
REVISION DB DO NOT SCALE FROM THIS PRINT NOTES: SSM-1XX-XXX-XX-XX-XX-X-XX-XX OPTION -TR: TAPE AND REEL(SEE FIG 8, SHT 4) (29 POSITIONS MAX)(SEE NOTE 15) -FR: FULL REEL QTY. TAPE & REEL (29 POSITIONS MAX) (SEE NOTE 16) OPTION -P: PICK AND PLACE PAD (ONLY AVAILABLE ON -SV, USE PPP-12, SEE FIG 6, SHT 3) (SEE NOTE 12) -K: POLYIMIDE FILM PAD (SEE FIG 5, SHT 2) (USE K-DOT-.138-.250-.005) (NOT AVAILABLE ON -SH AND -DH) 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM PUSHOUT FORCE: .50 LBS. No OF POSITIONS 3. COPLANARITY TO BE: -02 THRU -36 -DH: -36 THRU -28 POS: .008[0.20] (SEE NOTE 8) -02 THRU -27 POS: .006[0.15] -SV, -SH: -02 THRU 36 POS: .006 (FULL STRIP STOCK: .008). PLATING SPECIFICATION 4. PACKAGE IN TUBES PER SHT 4, TABLE 2. ALL OTHER POSITIONS BULK PACKAGE. -S: 30µ" SELECTIVE GOLD IN CONTACT 5. MAXIMUM CUT FLASH: .015[0.38]. AREA, MATTE TIN ON TAIL. 6. NOTCH OF PPP-12 TO BE ORIENTED TOWARD SAME END AS POSITION 1. -L: 10µ" SELECTIVE GOLD IN CONTACT 7. ROWS TO BE WITHIN .004[0.10] OF ONE ANOTHER. AREA, MATTE TIN ON TAIL. 8. -36 MAX POSITION AVAILABLE, -50 FOR STOCK ONLY. -T: MATTE TIN ON CONTACT AND TAIL. 9. ENDWALL AFTER CUTTING: .033[0.84]±.005[0.13] -F: 3µ" SELECTIVE GOLD IN CONTACT 10. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE -LC OPTION AREA, MATTE TIN ON TAIL. IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS -STL: 30µ" SELECTIVE GOLD IN CONTACT AREA, TIN/LEAD (90/10) ON TAIL. MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE -LC OPTION. -H: 30µ" SELECTIVE GOLD IN CONTACT 11. FOR -SV TAIL STYLE: EVEN CUTS LOSE 2 POSITIONS PER CUT; ODD CUTS AREA, 3µ" SELECTIVE GOLD ON TAIL. LOSE 1 POSITION PER CUT. -LM: 10µ" SELECTIVE GOLD IN CONTACT 12. IF POLARIZATION OCCURS AT CENTER POSITION(S) OF BODY, MOVE PICK & AREA, MATTE TIN ON TAIL. PLACE PAD LEFT OR RIGHT TO NEXT AVAILABLE POSITION. -TM: MATTE TIN ON CONTACT AND TAIL. 13. THIS DIMENSION IS TO BE MEASURED RELATIVE TO DATUM -Z-. -FM: 3µ" SELECTIVE GOLD IN CONTACT 14. CHAMFERED END WALL MAY OR MAY NOT BE ON CUT TO POSITION PARTS. 15. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) TAIL SPECIFICATION FOUND ON WWW.SAMTEC.COM. -SV: SINGLE VERTICAL (SEE FIG 1) 16. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL, (USE SSM-XX-S) BASED ON OPTIONS SELECTED. -SH: SINGLE HORIZONTAL (SEE FIG 3, SHT 2) (USE SSM-XX-SH) C -DH: DOUBLE HORIZONTAL (SEE FIG 4, SHT 3) (NO OF POS x .100[2.54]) -.100[2.54] (NO OF POS x .100[2.54]) (USE BCH-XX-D) ±.010[0.25] (CUT TOLERANCE, SEE NOTE 11) ±.005[0.13] (MOLDED BODY TOLERANCE) .050 1.27 REF 02 POLARIZATION OPTION -XX: POSITION TO BE POLARIZED (USE PK-06-N, SEE FIG 7, SHT 3 FOR POLARIZATION POSITIONS) (NOT AVAILABLE FOR -BE OPTION) MOUNTING OPTION -LC: LOCKING CLIP (USE LC-05-TM, SEE NOTE 10) (FOR -SH AND -DH USE MOLDED TO POSITION BODIES) OPTION -BE: BOTTOM ENTRY (ONLY AVAILABLE ON -SV) (USE SSM-XX-S-BE) (SEE FIG 2, SHT 2) 36 .100 2.54 REF SSM-XX-S 01 35 CONTACT #1 2 MAX SWAY C (EITHER DIRECTION) FLUSH TO .005[0.13] MAX "A" .18 4.6 REF -Z- SEE NOTE 9 C 1° C (SEE NOTE 13) +0.051 .295+-.002 .005 7.49 - 0.127 (MEASURE AT BEND) .290 7.37 REF DETAIL 'D' SCALE 8 : 1 LC-05-TM "A" SEE NOTE 3 C 'D' .050 1.27 (NO OF POS x .100[2.54]) -.200[5.08] 2 MAX SWAY (EITHER DIRECTION) C .047 1.19 SECTION "A"-"A" SCALE 3 : 1 FIG 1 -SV: SINGLE VERTICAL ROW (SSM-1XX-XXX-SV-LC SHOWN) 4° (SEE NOTE 13) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [0.3] 2 .XXX: .005 [0.13] .XXXX: .0020 [0.051] MATERIAL: * -SV IN-PROCESS PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 INSULATOR: LCP, UL 94 VO, COLOR: BLACK CONTACT: PHOS BRONZE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100[2.54] C.L. SURFACE MOUNT SOCKET STRIP DWG. NO. SSM-1XX-XXX-XX-XX-XX-X-XX-XX F:\DWG\MISC\MKTG\SSM-1XX-XXX-XX-XX-XX-X-XX-XX-MKT.SLDDRW BY: KOLB 09/11/1998 SHEET 1 OF 4 REVISION DB "R" SSM-XX-S-BE .300 7.62 "S" ±.020[0.51] 01 .138 3.50 REF FIG 5 .019±.020 0.48±0.51 -K: KAPTON PAD (SSM-110-XXX-SV-K SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) "R" = SEE FIG 1, SHEET 1 FOR OAL "S" = "R"/2 - .0689[1.750] FIG 2 -SV-BE: SINGLE VERTICAL ROW BOTTOM ENTRY (SSM-1XX-XXX-SV-BE SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) .069 1.75 C +.010 +0.254 .433 - .020 11.00 - 0.508 C .020 0.51 REF 2 MAX SWAY (EITHER DIRECTION) .053 1.35 REF .058 1.47 CONTACT #1 -Z- SEE NOTE 3 C .015 0.38 .320 8.13 REF -SH IN-PROCESS 3° C (SEE NOTE 13) MEASURE AT BEND 2 MAX SWAY (EITHER DIRECTION) 3° (SEE NOTE 13) .055 1.40 SSM-XX-SH "B" SECTION "B"-"B" .125 3.18 .070 1.78 REF 01 "B" 36 LC-05-TM FIG 3 -SH: SINGLE HORIZONTAL (SSM-136-XXX-SH-LC SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\SSM-1XX-XXX-XX-XX-XX-X-XX-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100[2.54] C.L. SURFACE MOUNT SOCKET STRIP DWG. NO. SSM-1XX-XXX-XX-XX-XX-X-XX-XX BY: KOLB 09/11/1998 SHEET 2 OF 4 REVISION DB CONTACT #1 CONTACT #2 C .430±.020 10.92±0.508 .055 1.40 REF .078 1.98 .167 4.24 .272 6.91 REF BCH-XX-D -DH IN-PROCESS .0200±.0040 0.508±0.102 (SEE NOTE 7) .055 1.40 SECTION "C"-"C" SEE NOTE 14 72 71 "C" 02 01 "C" SEE NOTE 14 FIG 4 -DH: DOUBLE HORIZONTAL (SSM-1XX-XXX-DH-LC SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 3) 01 "R" "S"±.010[0.25] 02 PK-06-N .195 4.95 REF .395 10.03 REF 01 02 PK-06-N SEE NOTE 6 PPP-12 FIG 6 -P: PICK AND PLACE PAD (SSM-110-XXX-SV-P SHOWN) -02 AND -03 POS NOT AVAILABLE WITH POLARIZATION -04 POS - CANNOT OFFER IF POLARIZATION IS POS 2 OR 3 -05 POS - CANNOT OFFER IF POLARIZATION IS POS 3 *MUST USE TR ON POS 2 & 3 (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) "R" = SEE FIG 1, SHEET 1 FOR OAL "S" = IF NO OF POS IS EVEN: "R"/2 - .1975[5.017] IF NO OF POS IS ODD: "R"/2 - .2475[6.287] 36 02 71 SSM-136-XXX-DH-02 SHOWN PK-06-N 01 FIG 7 POLARIZATION (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:2 F:\DWG\MISC\MKTG\SSM-1XX-XXX-XX-XX-XX-X-XX-XX-MKT.SLDDRW SSM-136-XXX-SH-02 SHOWN 72 .050 1.27 REF POS 1 36 SSM-136-XXX-SV-02 SHOWN 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100[2.54] C.L. SURFACE MOUNT SOCKET STRIP DWG. NO. SSM-1XX-XXX-XX-XX-XX-X-XX-XX BY: KOLB 09/11/1998 SHEET 3 OF 4 REVISION DB MATING SIDE OF CONNECTOR POS 1 CONTACT ENTRY SIDE FOR ASSEMBLY POS 1 SSM-110-XXX-SV-TR SHOWN USER DIRECTION OF UNREELING SSM-110-XXX-DH-TR SHOWN USER DIRECTION OF UNREELING SSM-110-XXX-SH-TR SHOWN USER DIRECTION OF UNREELING FIG 8 -TR: TAPE AND REEL SCALE 1:1 STANDOFF SIDE OF BODY SSM-1XX-XXX-SV-LC-P SHOWN (SSM-1XX-XXX-SV-LC-K SIMILAR) CORE LEAD IN SIDE OF BODY POS 1 SSM-1XX-XXX-SV-P SHOWN (SSM-1XX-XXX-SV-K SIMILAR) SSM-1XX-XXX-DH-LC SHOWN CORE LEAD IN SIDE OF BODY 1ST POSITION WITH TUBE LOGO STANDOFF SIDE OF BODY SSM-1XX-XXX-SH-LC SHOWN SSM-1XX-XXX-SV-LC SHOWN * FIG 9 TUBE VIEWS PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 3:2 F:\DWG\MISC\MKTG\SSM-1XX-XXX-XX-XX-XX-X-XX-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100[2.54] C.L. SURFACE MOUNT SOCKET STRIP DWG. NO. SSM-1XX-XXX-XX-XX-XX-X-XX-XX BY: KOLB 09/11/1998 SHEET 4 OF 4
SSM-108-F-SV 价格&库存
很抱歉,暂时无法提供与“SSM-108-F-SV”相匹配的价格&库存,您可以联系我们找货
SSM-108-F-SV
    • 1+11.17800
    • 10+10.89720
    • 28+10.71360
    库存:6
