REVISION AE
CES-1XX-XX-X-S-XX
NOTES:
No OF POSITIONS
-01 THRU -50
1. C REPRESENTS A CRITICAL DIMENSION.
2. MIN CONTACT RETENTION 2 LB
C 3. MAX ALLOWABLE BOW: .006 [.015] IN/IN
.03
.001
4. "END WALLS" AFTER CUTTING SHOULD BE .015 .005[.38 .13]
5. MAX CUT FLASH: .015 [.38] WITH NO FLASH ALLOWED IN HOLES.
6. MAX TERMINAL BURR: .003 [.08]
7. WHEN FILLING THE ASSEMBLY, ALL CONTACTS MUST BE
FACING THE SAME DIRECTION.
8. TO BE MEASURED AT THE BEND.
DO NOT
SCALE FROM
THIS PRINT
C
CONTACT LEAD STYLE
-01: USE C-45-01-X
-02: USE C-45-02-X
ROW SPECIFICATION
-S: SINGLE ROW
(USE CES-XX-S)
PLATING SPECIFICATION
-T: MATTE TIN, CONTACT AND TAIL
-G: 10µ" GOLD IN CONTACT AREA,
3µ" GOLD ON TAIL
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-F: 3µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-L: 10µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
NO OF POSITIOINS X .100 [2.54]
.008 [.20] (CUT POSITIONS)
+.002 [.03] (50 POSITION ONLY)
-.005 [.13]
+.001
OPTIONS
-RA: RIGHT ANGLE
(STYLE -02 ONLY)
+0.03
.050 - .005 1.27 - 0.13
(SEE NOTE 4)
"B"
"B"
NOTE: MIXED PIN
ORIENTATION
ACCEPTABLE
.120 3.05
REF
CL
"A"
CL
PACKAGING VIEW
LEAD STYLE -01 & -02
CL
.020 0.51
REF
.200 5.08 REF
C
"A"
2 MAX SWAY
(EITHER DIRECTION)
SECTION "B"-"B"
.040 1.02
(SEE NOTE 8)
NOTE: PINS TO BE
FACING THE
SAME
DIRECTION
"A"
.100 2.54
.025 0.64 REF
C
90°±2°
.120 3.05 REF
.010 0.25 REF
2 MAX SWAY
(EITHER DIRECTION)
-RA
PACKAGING VIEW
LEAD STYLE -02-RA
SECTION "A"-"A"
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: PBT, UL 94 VO
COLOR: BLACK
TERMINAL: PHOS BRONZE
F:\DWG\MISC\MKTG\CES-1XX-XX-X-S-XX-MKT.SLDDRW
SHEET SCALE: 3:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
DWG. NO.
CLOSED ENTRY SOCKET STRIP
CES-1XX-XX-X-S-XX
BY: KOLB 12-6-89
SHEET 1 OF 1
很抱歉,暂时无法提供与“CES-114-02-T-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+16.582051+2.12851
