BCS-114-T-S-HE
BCS-114-T-S-HE
    SAMTEC(申泰)
    弯插,P=2.54mm
    排母 间距:2.54mm 1x14P 弯插
BCS-114-T-S-HE 数据手册
BCS-1XX-XXX-X-XX-XXX REVISION CG No OF POSITIONS x .100[2.54] (MOLD TO POSITION: +.000[0.00] ) -.005[0.13] (CUT TO POSITION: ±.010[.25] - SEE NOTE 4) PLATING SPECIFICATIONS (SEE TABLE 1) -T: MATTE TIN CONTACT AND TAIL -L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -F: 3µ" FLASH SELECTIVE GOLD CONTACT AREA, MATTE TIN ON TAIL -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -H: 30µ" HEAVY GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -TM: MATTE TIN CONTACT AND TAIL -LM: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -FM: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -LTL: 10µ’’ LIGHT SELECTIVE GOLD IN CONTACT AREA, TIN LEAD (90/10 +/-5%) ON TAIL (No OF POS x .100[2.54]) - (.100[2.54]) "B" DO NOT SCALE FROM THIS PRINT .050 1.27 REF -02 -50 .100 2.54 REF -01 "A" -49 "B" -50 -02 .200 5.08 REF .100 2.54 REF "A" -01 -49 .290 7.37 REF .119 3.02 C (SEE NOTE 9) CONTACT #1 -DE/-DE-BE FIG 1(SEE NOTE 11) .16 4.1 2 MAX SWAY IN EITHER DIRECTION NOTES: POSITION 01 (-DE TAIL ORIENTATION) ENTRY SPECIFICATION -DE: DUAL ENTRY (SEE TABLE 1) -TE: TOP ENTRY (SEE TABLE 1) -HE: HORIZONTAL ENTRY (SEE TABLE 1) -PE: PASS-THROUGH ENTRY (SEE TABLE 1) -DE-BE: (SEE TABLE 1) -PE-BE: (SEE TABLE 1) BODY SPECIFICATION -S: SINGLE ROW (SEE TABLE 1) -D: DOUBLE ROW (SEE TABLE 1) CONTACT #1 .06 1.6 C C 2 MAX SWAY 2 MAX SWAY SECTION "B"-"B" SECTION "A"-"A" BCS-1XX-X-S-DE BCS-1XX-X-D-DE POSITION 01 POLARIZING OPTION INSERT PK-06-N INTO SPECIFIED POS AND BREAK OFF TAB (NOT AVAILABLE FOR -BE OPTION) No OF POSITIONS -01 THRU -50 C POSITION 01 POSITION 01 (-TE TAIL ORIENTATION) 1. C REPRESENTS CRITICAL DIM. FOR STATISTICAL PROCESS CONTROL. 2. MINIMUM PUSHOUT FORCE TO BE: 1 LB. 3. [ ] DIMENSIONS ARE IN MILLIMETERS. 4. MINIMUM WALL THICKNESS ON CUT PARTS: .009 [0.23]. 5. CUT PARTS TO BE SYMMETRICAL ABOUT CL . 6. 1st POSITION WILL ALWAYS POINT UP ON TOP VIEW AS SHOWN. 7. 1 THROUGH 4 POSITIONS ARE TO BE LAYER PACKAGED, 5 THROUGH 50 POSITIONS ARE TO BE TUBED FOR ALL ENTRY SPECIFCATION EXCEPT BCS-S-HE AND BCS-D-HE. FOR BCS-S-HE AND BCS-D-HE, 1 THROUGH 3 POSITIONS ARE TO BE LAYER PACKAGED, 4 THROUGH 50 POSITIONS ARE TO BE TUBED. 8. DAMAGE TO THE CUT SURFACE CAN NOT EFFECT LEAD-IN OF THE CORES. 9. MAXIMUM VARIATION WITHIN A ROW: .006 [0.15]. MAXIMUM VARIATION FROM ROW TO ROW: .012 [0.30]. 10. MAXIMUM CUT FLASH: .015 [0.38]. 11. CHAMFERED END-WALLS MAY OR MAY NOT BE PRESENT ON ONE OR BOTH ENDS OF FINISHED GOOD. (-PE TAIL ORIENTATION) (-HE TAIL ORIENTATION) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01[0.3] 2 .XXX: .005[0.13] .XXXX: .0020[0.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 INSULATOR: GLASS FILLED LCP UL 94 VO, COLOR: BLACK CONTACT: PHOS. BRONZE F:\DWG\MISC\MKTG\BCS-1XX-XXX-X-XX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. BOX CONNECTOR SOCKET STRIP BCS-1XX-XXX-X-XX-XXX BY: KOLB 09/12/1991 SHEET 1 OF 3 REVISION CG C .147 3.73 .320 8.13 REF CONTACT #1 CONTACT #1 C .143 3.63 IN-PROCESS .110 2.79 REF .125 3.18 REF "C" CONTACT # 1 -50 -01 .290 7.37 REF -S-HE C .122 3.10 .015 0.38 REF C .122 3.10 .10 2.59 C "C" 2 MAX SWAY (EITHER DIRECTION) 2 MAX SWAY IN EITHER DIRECTION .31 7.9 BCS-1XX-X-S-HE +.010 .125 -.015 C +0.254 3.18 -0.381 BCS-1XX-XXX-D-TE SECTION "C"-"C" SEE NOTE 11 FIG 2 -HE 2 MAX SWAY (EITHER DIRECTION) C 2 MAX SWAY (EITHER DIRECTION) C FIG 3 CONTACT #1 +0.127 C .250+-.005 .003 6.35 - 0.076 CONTACT #1 CONTACT #1 CONTACT #2 .320 8.13 REF .293 7.44 REF .150 3.81 C IN-PROCESS -D-HE C .128±.010 3.25±0.254 (NO. OF POS x .100[2.54]) - .100[2.54] 50 .050 1.27 REF 02 .210 5.33 REF .100 2.54 REF C .20 5.1 .310 7.88 .128±.010 3.25±0.254 .015 0.38 REF C BCS-1XX-X-S-PE BCS-1XX-XXX-D-PE 01 49 "D" .0700 1.779 REF C .30 7.6 (NO. OF POS x .100[2.54])±.008[0.20] "D" 2 MAX SWAY IN EITHER DIRECTION BCS-1XX-X-D-HE .225 5.72 REF +.010 +0.254 FIG 4 -PE/-PE-BE (SEE SHEET 3 FOR IN-PROCESS) 3 MAX SWAY (EITHER DIRECTION) .125 -.015 3.16 -0.381 * +0.381 C .310+.015 -.010 7.87 -0.254 SECTION "D"-"D" PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\BCS-1XX-XXX-X-XX-XXX-MKT.SLDDRW BCS-1XX-X-S-TE -TE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. BOX CONNECTOR SOCKET STRIP BCS-1XX-XXX-X-XX-XXX BY: KOLB 09/12/1991 SHEET 2 OF 3 IN-PROCESS REVISION CG IN-PROCESS BCS-1XX-X-D-PE (SAME FOR -BE) BCS-1XX-X-S-PE (SAME FOR -BE) IN-PROCESS 1 IN-PROCESS 2 .176 4.47 -50 C -01 -49 -02 -S-BE: (SAME AS FIG 1 EXCEPT AS SHOWN -D-BE: (SAME AS FIG 1) PT-3-24-01-01 BCS-S-DE BCS-S-DE-BE PT-1-24-01-15 BCS-D-PE BCS-D-PE BCS-D-PE-BE BCS-D-PE-DE-BE .176 4.47 .544 13.83 REF -50 -01 -49 -02 PT-1-24-01-24 BCS-S-TE IN-PROCESS 2 IN-PROCESS 1 .445 11.31 REF C -50 -02 -49 -01 -S-PE-BE: (SAME AS -S-PE EXCEPT AS SHOWN) -D-PE-BE: (SAME AS -D-PE) -50 -02 -01 (SEE NOTE 6) -49 PT-1-24-01-22 BCS-D-TE PT-1-24-20-09 PT-1-24-04-38 BCS-S-HE (SEE NOTE 7) PT-1-24-01-127 BCS-D-HE (SEE NOTE 7) BCS-S-PE BCS-S-PE-BE * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\BCS-1XX-XXX-X-XX-XXX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. BOX CONNECTOR SOCKET STRIP BCS-1XX-XXX-X-XX-XXX BY: KOLB 09/12/1991 SHEET 3 OF 3
BCS-114-T-S-HE
1. 物料型号:BCS-1XX-XXX-X-XX-XXX,具体型号取决于后缀,表示不同的配置选项。
2. 器件简介:这是Samtec公司生产的盒式连接器插座条,用于电子设备中。
3. 引脚分配:文档提供了不同配置的引脚分配,例如单排(-S)和双排(-D),以及不同的入口规格(-DE, -TE, -HE, -PE)。
4. 参数特性: - 接触材料:磷青铜。 - 绝缘体材料:玻璃填充LCP,UL 94 VO,颜色为黑色。 - 镀层规格:包括镀锡、轻金、重金等不同选项。
5. 功能详解:文档详细描述了连接器的功能,包括不同入口规格的配置和引脚的布局。
6. 应用信息:文档提供了连接器的应用信息,包括最小推力、最大摇摆角度、切割部分的最小壁厚等。
7. 封装信息:提供了连接器的封装尺寸和设计细节,如最大切割闪光、端壁倒角等。
8. 版权声明:文档包含Samtec公司的保密和专有信息,未经Samtec明确书面同意,不得向任何未授权的个人或实体披露、复制、转移或以任何方式纳入其他项目。
BCS-114-T-S-HE 价格&库存
很抱歉,暂时无法提供与“BCS-114-T-S-HE”相匹配的价格&库存,您可以联系我们找货
