REVISION DB
DO NOT
SCALE FROM
THIS PRINT
NOTES:
SSM-1XX-XXX-XX-XX-XX-X-XX-XX
OPTION
-TR: TAPE AND REEL(SEE FIG 8, SHT 4)
(29 POSITIONS MAX)(SEE NOTE 15)
-FR: FULL REEL QTY. TAPE & REEL
(29 POSITIONS MAX) (SEE NOTE 16)
OPTION
-P: PICK AND PLACE PAD
(ONLY AVAILABLE ON -SV,
USE PPP-12, SEE FIG 6, SHT 3)
(SEE NOTE 12)
-K: POLYIMIDE FILM PAD
(SEE FIG 5, SHT 2)
(USE K-DOT-.138-.250-.005)
(NOT AVAILABLE ON -SH AND -DH)
1. C REPRESENTS A CRITICAL DIMENSION.
2. MINIMUM PUSHOUT FORCE: .50 LBS.
No OF POSITIONS
3. COPLANARITY TO BE:
-02 THRU -36
-DH: -36 THRU -28 POS: .008[0.20]
(SEE NOTE 8)
-02 THRU -27 POS: .006[0.15]
-SV, -SH: -02 THRU 36 POS: .006 (FULL STRIP STOCK: .008).
PLATING SPECIFICATION
4. PACKAGE IN TUBES PER SHT 4, TABLE 2. ALL OTHER POSITIONS BULK PACKAGE. -S: 30µ" SELECTIVE GOLD IN CONTACT
5. MAXIMUM CUT FLASH: .015[0.38].
AREA, MATTE TIN ON TAIL.
6. NOTCH OF PPP-12 TO BE ORIENTED TOWARD SAME END AS POSITION 1.
-L: 10µ" SELECTIVE GOLD IN CONTACT
7. ROWS TO BE WITHIN .004[0.10] OF ONE ANOTHER.
8. -36 MAX POSITION AVAILABLE, -50 FOR STOCK ONLY.
-T: MATTE TIN ON CONTACT AND TAIL.
9. ENDWALL AFTER CUTTING: .033[0.84]±.005[0.13]
-F: 3µ" SELECTIVE GOLD IN CONTACT
10. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE -LC OPTION
IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS
-STL: 30µ" SELECTIVE GOLD IN CONTACT
AREA, TIN/LEAD (90/10) ON TAIL.
MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE -LC OPTION.
-H: 30µ" SELECTIVE GOLD IN CONTACT
11. FOR -SV TAIL STYLE: EVEN CUTS LOSE 2 POSITIONS PER CUT; ODD CUTS
AREA, 3µ" SELECTIVE GOLD ON TAIL.
LOSE 1 POSITION PER CUT.
-LM: 10µ" SELECTIVE GOLD IN CONTACT
12. IF POLARIZATION OCCURS AT CENTER POSITION(S) OF BODY, MOVE PICK &
PLACE PAD LEFT OR RIGHT TO NEXT AVAILABLE POSITION.
-TM: MATTE TIN ON CONTACT AND TAIL.
13. THIS DIMENSION IS TO BE MEASURED RELATIVE TO DATUM -Z-.
-FM:
14. CHAMFERED END WALL MAY OR MAY NOT BE ON CUT TO POSITION PARTS.
15. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE PACKAGED
ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES)
TAIL SPECIFICATION
FOUND ON WWW.SAMTEC.COM.
-SV: SINGLE VERTICAL (SEE FIG 1)
16. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL,
(USE SSM-XX-S)
BASED ON OPTIONS SELECTED.
-SH: SINGLE HORIZONTAL (SEE FIG 3, SHT 2)
(USE SSM-XX-SH)
C
-DH: DOUBLE HORIZONTAL (SEE FIG 4, SHT 3)
(NO OF POS x .100[2.54]) -.100[2.54]
(USE BCH-XX-D)
±.010[0.25] (CUT TOLERANCE, SEE NOTE 11)
±.005[0.13] (MOLDED BODY TOLERANCE)
.050 1.27
REF
02
POLARIZATION OPTION
-XX: POSITION TO BE POLARIZED
(USE PK-06-N, SEE FIG 7, SHT 3
FOR POLARIZATION POSITIONS)
(NOT AVAILABLE FOR -BE OPTION)
MOUNTING OPTION
-LC: LOCKING CLIP
(USE LC-05-TM, SEE NOTE 10)
(FOR -SH AND -DH USE MOLDED TO
POSITION BODIES)
OPTION
-BE: BOTTOM ENTRY
(ONLY AVAILABLE ON -SV)
(USE SSM-XX-S-BE)
(SEE FIG 2, SHT 2)
36
.100 2.54 REF
SSM-XX-S
01
35
CONTACT #1
2 MAX SWAY C
(EITHER DIRECTION)
FLUSH TO .005[0.13] MAX
"A"
.18 4.6 REF
-Z-
SEE NOTE 9
C
1° C
(SEE NOTE 13)
+0.051
.295+-.002
.005 7.49 - 0.127
(MEASURE AT BEND)
.290 7.37 REF
DETAIL 'D'
SCALE 8 : 1
LC-05-TM
"A"
SEE NOTE 3
C
'D'
.050 1.27
(NO OF POS x .100[2.54]) -.200[5.08]
2 MAX SWAY
(EITHER DIRECTION)
C
.047 1.19
SECTION "A"-"A"
SCALE 3 : 1
FIG 1
-SV: SINGLE VERTICAL ROW
(SSM-1XX-XXX-SV-LC SHOWN)
4°
(SEE NOTE 13)
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [0.3]
2
.XXX: .005 [0.13]
.XXXX: .0020 [0.051]
MATERIAL:
-SV IN-PROCESS
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 2:1
INSULATOR: LCP, UL 94 VO, COLOR: BLACK
CONTACT: PHOS BRONZE
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.100[2.54] C.L. SURFACE MOUNT SOCKET STRIP
DWG. NO.
F:\DWG\MISC\MKTG\SSM-1XX-XXX-XX-XX-XX-X-XX-XX-MKT.SLDDRW
BY: KOLB
09/11/1998
SHEET 1 OF 4
REVISION DB
"R"
SSM-XX-S-BE
.300 7.62
"S" ±.020[0.51]
01
.138 3.50 REF
FIG 5
.019±.020 0.48±0.51
-K: KAPTON PAD
(SSM-110-XXX-SV-K SHOWN)
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1)
"R" = SEE FIG 1, SHEET 1 FOR OAL
"S" = "R"/2 - .0689[1.750]
FIG 2
-SV-BE: SINGLE VERTICAL ROW BOTTOM ENTRY
(SSM-1XX-XXX-SV-BE SHOWN)
.069 1.75
C
+.010
+0.254
.433 - .020 11.00 - 0.508
C
.020 0.51
REF
2 MAX SWAY
(EITHER DIRECTION)
.053 1.35 REF
.058 1.47
CONTACT #1
-Z-
SEE NOTE 3
C
.015 0.38
.320 8.13 REF
-SH IN-PROCESS
3° C
(SEE NOTE 13)
MEASURE AT BEND
2 MAX SWAY
(EITHER DIRECTION)
3°
(SEE NOTE 13)
.055 1.40
SSM-XX-SH
"B"
SECTION "B"-"B"
.125 3.18
.070 1.78 REF
01
"B"
36
LC-05-TM
FIG 3
(SSM-136-XXX-SH-LC SHOWN)
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: KOLB
09/11/1998
SHEET 2 OF 4
REVISION DB
CONTACT #1
CONTACT #2
C
.430±.020 10.92±0.508
.055 1.40 REF
.078 1.98
.167 4.24
.272 6.91 REF
BCH-XX-D
-DH IN-PROCESS
.0200±.0040 0.508±0.102
(SEE NOTE 7)
.055 1.40
SECTION "C"-"C"
SEE NOTE 14
72
71
"C"
02
01
"C"
SEE NOTE 14
FIG 4
(SSM-1XX-XXX-DH-LC SHOWN)
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 3)
01
"R"
"S"±.010[0.25]
02
PK-06-N
.195 4.95
REF
.395 10.03
REF
01
02
PK-06-N
SEE NOTE 6
PPP-12
FIG 6
(SSM-110-XXX-SV-P SHOWN)
-02 AND -03 POS NOT AVAILABLE WITH POLARIZATION
-04 POS - CANNOT OFFER IF POLARIZATION IS POS 2 OR 3
-05 POS - CANNOT OFFER IF POLARIZATION IS POS 3
*MUST USE TR ON POS 2 & 3
"S" = IF NO OF POS IS EVEN: "R"/2 - .1975[5.017]
IF NO OF POS IS ODD: "R"/2 - .2475[6.287]
36
02
71
SSM-136-XXX-DH-02 SHOWN
PK-06-N
01
FIG 7
POLARIZATION
PROPRIETARY NOTE
SHEET SCALE: 3:2
SSM-136-XXX-SH-02 SHOWN
72
.050 1.27
REF
POS 1
36
SSM-136-XXX-SV-02 SHOWN
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: KOLB
09/11/1998
SHEET 3 OF 4
REVISION DB
MATING SIDE
OF CONNECTOR
POS 1
CONTACT ENTRY
SIDE FOR ASSEMBLY
POS 1
SSM-110-XXX-SV-TR SHOWN
USER DIRECTION OF UNREELING
SSM-110-XXX-DH-TR SHOWN
SSM-110-XXX-SH-TR SHOWN
FIG 8
-TR: TAPE AND REEL
SCALE 1:1
STANDOFF
SIDE OF BODY
SSM-1XX-XXX-SV-LC-P SHOWN
(SSM-1XX-XXX-SV-LC-K SIMILAR)
CORE LEAD IN
SIDE OF BODY
POS 1
SSM-1XX-XXX-SV-P SHOWN
(SSM-1XX-XXX-SV-K SIMILAR)
CORE LEAD IN
SIDE OF BODY
1ST POSITION WITH TUBE LOGO
STANDOFF SIDE
OF BODY
SSM-1XX-XXX-SH-LC SHOWN
FIG 9
TUBE VIEWS
PROPRIETARY NOTE
SHEET SCALE: 3:2
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: KOLB
09/11/1998
SHEET 4 OF 4
