SFC-110-T2-F-D-K-TR
SFC-110-T2-F-D-K-TR
    SAMTEC(申泰)
    SMD,P=1.27mm
    排母 间距:1.27mm 2x10P SMT
SFC-110-T2-F-D-K-TR 数据手册
REVISION AJ DO NOT SCALE FROM THIS PRINT SFC-1XX-XX-XX-D-XX NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM PUSHOUT FORCE: .5 LB. No OF POSITIONS C 3. COPLANARITY: .004[0.10] = POS 05 THRU 26 ALL POSITIONS AVAILABLE .006[0.15] = POS 27 THRU 50 -02 THRU -50 4. TUBE ALL POSITIONS. PARTS TO BE TUBED WITH NOTCH GOING WITH ARROW. 5. PINS CAN BE ORIENTED IN ANY DIRECTION; BOTH ROWS MUST FACE SAME WAY. 6. SEE NOTCH FOR PROPER ORIENTATION. LEAD STYLE C 7. MAXIMUM PIN HEIGHT VARIATION: .003[0.08]. -T1: THROUGH HOLE FROM PIN TO PIN AND ROW TO ROW, MUST BE (SEE FIG. 1, SHT. 1) MEASURED BETWEEN ADJACENT PINS. 8. DUE TO HIGH AMOUNT OF INSERTION FORCE -T2: SURFACE MOUNT NEEDED, THE -LC OPTION IS NOT COMPATIBLE WITH (SEE FIG. 2, SHT. 2) AUTO PLACEMENT. SAMTEC RECOMMENDS MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE -LC OPTION. 9. MEASUREMENT TO BE TAKEN AT BEND. 10. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM. 11. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL, BASED ON OPTIONS SELECTED. 12. LOAD VISION TRAYS WITH PIN #1 OPPOSITE STANDARD - AWAY FROM THE TERMINAL INDICATOR SIDE OF TRAY. .020 0.51 REF .080 2.03 REF OPTIONS (LEAVE BLANK FOR STANDARD AND USE SFM-XX-D) -A: ALIGNMENT PIN (USE SFM-XX-D-A) (SEE FIG 4, SHT 2) -LC: LOCKING CLIP (SEE FIG 6, SHT 3 & NOTE 8) (USE SFM-XX-D-LC) -TR: TAPE & REEL (SEE SHT 3) (SEE NOTE 10) -FR: FULL REEL QTY. TAPE & REEL (SEE NOTE 11) -K: POLYIMIDE FILM PAD (.005[0.13] THICKNESS) (SEE FIG 3, SHT 2) (USE K-DOT-.157-.250-.005) BODY SPECIFICATION -D: DOUBLE ROW PLATING SPECIFICATION -F: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -FM: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -LM: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL .120 3.05 REF .050 1.27 REF 02 .145 3.68 REF CL 01 .050 1.27 REF CL (NO. OF POS x .050[1.27]) + .015[0.38] REF "A" SFM-XX-D-XX (NO. OF POS x .050[1.27]) + .155[3.94] REF CL C-119-01-XX (SEE NOTE 5) .180 4.57 REF .110 2.79 REF .015 0.38 REF C CL .120 3.05 "A" 2 MAX SWAY (TYP) .020 0.51 REF .050 1.27 (NO. OF POS x .050[1.27]) - .050[1.27] REF 1 MAX SWAY (TYP) C .005 0.13 REF C SECTION "A"-"A" FIG 1 THROUGH HOLE/STRAIGHT MODIFIED UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, COLOR: BLACK CONTACT: PHOSPHOR BRONZE F:\DWG\MISC\MKTG\SFC-1XX-XX-XX-D-XX-MKT.SLDDRW SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 SOCKET STRIP DOUBLE ROW ASSEMBLY DWG. NO. SFC-1XX-XX-XX-D-XX BY: BRATCHER 5/25/01 SHEET 1 OF 3 REVISION AJ (NO. OF POS x .050[1.27]) - .050[1.27] REF (TOL ACCUM ±.005[0.13] OVER 50 POS) C-119-02-XX C +.003 02 +0.08 .190 - .007 4.83 - 0.18 (SEE NOTE 9) IN-PROCESS -T2 01 2 MAX SWAY (TYP) FOR HAND FILL ONLY C "B" NOTE: DIMENSION APPLIES PRIOR TO RE-PRESS, SEE SECTION "B-B" FOR FINISHED DIMENSION SFM-XX-D-XX C +.002 +0.051 .185 - .005 4.70 - 0.127 (SEE NOTE 7 & 9) 4° SEE NOTE 3 "B" 2° .161 4.09 REF FIG 2 SECTION "B"-"B" -T2: SURFACE MOUNT (SAME AS FIG 1, DIFFERENT AS SHOWN) "R" (SEE NOTE) C .019±.020 0.48±0.508 "S" (SEE NOTE) (NO. OF POS x .050[1.27]) + .125[3.18] REF SFM-XX-D-A .1575±.0050 4.00±0.127 FIG 3 .050 1.27 REF R.025 0.64 REF -K: POLYIMIDE FILM PAD (SAME AS FIG 2, DIFFERENT AS SHOWN) .050 1.27 REF (NO. OF POS x .050[1.27]) + .075[1.91] REF NOTE: "R" = USED MEASURED DIMENSION REF "S" = {("R" - .1575[4.000])/2}±.020[0.51] * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. FIG 4 -A: ALIGNMENT PIN (SAME AS FIG 2, DIFFERENT AS SHOWN) DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\SFC-1XX-XX-XX-D-XX-MKT.SLDDRW .190 4.83 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 SOCKET STRIP DOUBLE ROW ASSEMBLY DWG. NO. SFC-1XX-XX-XX-D-XX BY: BRATCHER 5/25/01 SHEET 2 OF 3 REVISION AJ SFM-XX-D-LC .630 16.00 C .064 1.63 .056 1.42 REF LC-05-TM .010 0.25 REF (NO OF POS x .050[1.27] + .075[1.91] REF FIG 6 -LC: LOCKING CLIP (SAME AS FIG 2, DIFFERENT AS SHOWN) 2.205 56.00 "D" "D" PT-SFM004-X1-X3-D UNWINDING DIRECTION (SEE NOTE 6) PT-SFM004-X1-X3-D SECTION "D"-"D" SCALE 2 : 1 PACKAGING VIEW -TR: TAPE AND REEL * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING 5 POS -T1 LEAD STYLE MAY BE TUBED USING PT-1-24-15-09, TP-24-02 SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\SFC-1XX-XX-XX-D-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 SOCKET STRIP DOUBLE ROW ASSEMBLY DWG. NO. SFC-1XX-XX-XX-D-XX BY: BRATCHER 5/25/01 SHEET 3 OF 3
SFC-110-T2-F-D-K-TR 价格&库存
很抱歉,暂时无法提供与“SFC-110-T2-F-D-K-TR”相匹配的价格&库存,您可以联系我们找货
SFC-110-T2-F-D-K-TR
  • 725+14.72963725+1.91481
  • 1450+13.990931450+1.81878
库存:1150
SFC-110-T2-F-D-K-TR
  • 1+27.251221+3.54257
  • 10+23.1352710+3.00751
  • 100+19.66013100+2.55576
库存:1150
