CLP-105-02-S-D-BE-A-TR 数据手册
REVISION DE
DO NOT
SCALE FROM
THIS PRINT
CLP-1XX-XX-XXX-D-XX
1. C REPRESENTS A CRITICAL DIMENSION.
2. MINIMUM PUSHOUT FORCE: .5LB (8 OZ).
3. ONE POSITON WILL BE LOST FOR EVERY CUT MADE ON A
No OF POSITIONS PER ROW
OPTION
SOCKET STRIP.
-02 THRU -50
-P: PICK & PLACE PAD (USE LMP-01)
4. TUBE PACKAGE POSITIONS 5-50 ONLY. POSITIONS 2-4 ARE
(AVAILABLE ON POSITON -05 THRU -50 ONLY)
TO BE PLACED IN ANTISTATIC BUBBLE BAGS P/N ASBBLT4X5.5.
(NOT AVAILABLE WITH -PA OR -K OPTIONS)
5. SHEAR TAILS TO DIMENSIONS SHOWN.
(SEE FIG 3, SHT 2)
LEAD STYLE SPEC
6. NOTE DELETED.
-A:
ALIGNMENT PIN (USE CLP-XX-D-XX)
-02: SURFACE MOUNT
7. TAIL SIDE ENDWALL AFTER CUTTING: .0160[0.406]±.0025[0.064].
(NOT AVAILABLE WITH -PA OPTION)
(USE C-106-X2-XXX OR
8. VOID CORES MAY NOT BE PRESENT.
(SEE FIG 2, SHT 2)
SUB-C-106-X2-XXX)
9. HAND FILL USE C-106-01-XX.
-TR: TAPE AND REEL (SEE NOTE 14)
(SEE NOTE 9)
-BE: BOTTOM ENTRY ONLY (USE CLP-XX-DBE-XX)
CAN'T HAND FILL -STL & -LTL-PLATING.
-PA: PICK & PLACE PAD WITH ALIGNMENT PINS
AUTOMATION USE C-106-22-XX. C-106-02-XX CAN BE
(NOT AVAILABLE WITH -P, -A, OR -K OPTIONS)
SUBBED FOR C-106-22-XX.
(SEE SHT 2, TABLE 3)(SEE NOTE 12)
.0100 0.254
FOR -LTL AND -STL PLATING USE SUB-C-106-X2-XTL PINS
-K: POLYIMIDE FILM PAD (AVAILABLE ON -03 THRU -50
C 10. MAX CUT FLASH: .010[0.25] X .020[0.51] (HEIGHT X WIDTH) WITH NO .005 0.12
C
POSITIONS. USE K-DOT-.157-.250-.005) (AVAILABLE
FLASH ALLOWED IN HOLES OR EXTENDING BELOW LEADS.
(SEE
NOTE
13)
ON -02 POSITIONS. USE K-DOT-.118-.219-.005)
C 11. MAX BURR: .005[.13].
(SEE FIG 5, SHT 2)(NOT AVAILABLE WITH -P OR -PA
C
12. ALL -PA OPTION PARTS SHIP IN EIA-960 TRAYS.
OPTIONS)
13. DOES NOT APPLY TO -BE END OPTION.
-FR: FULL REEL QTY. TAPE & REEL (SEE NOTE 15)
14. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE
PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY
BODY SPEC
STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM.
-D: DOUBLE ROW
15. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL,
(USE CLP-XX-D)
BASED ON OPTIONS SELECTED.
PLATING SPEC
DETAIL 'D'
-F: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA
MATTE TIN ON TAIL
SCALE 16 : 1
-L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA
No OF POS x .0500[1.270]) - .0500[1.270]
MATTE TIN ON TAIL
(TOLERANCE ACCUM ±.0020[0.051])
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA
MATTE TIN ON TAIL
C
-G: 10µ" GOLD IN CONTACT AREA
(No OF POS X .0500[1.270]) + .017[0.43]±.008[0.20]
.034 0.85
3µ ON TAIL
(SEE NOTE 3 AND 7)
REF
-H: 30µ" HEAVY GOLD IN CONTACT AREA
3µ" ON TAIL
-LM: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA
'D'
02
MATTE TIN ON TAIL
-FM: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA
MATTE TIN ON TAIL
.120 3.05
-SM: 30µ" SELECTIVE GOLD IN CONTACT AREA
REF
MATTE TIN ON TAIL
-LTL: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA
01
TIN/LEAD (90/10+/-5%) TAIL (SEE NOTE 9)
-STL: 30µ" SELECTIVE GOLD IN CONTACT AREA
-D
-D-BE
CLP-XX-DBE-XX
CLP-XX-D-XX
.050 1.27 REF
+.003
+0.08
.090 - .001 2.29 - 0.03
"A"
"B"
(MEASURE AT BEND)
C
4°
.084 2.12 REF
"A"
SEE NOTE 10
"B"
-D
CL CL
-D-BE
C-106-22-XXX OR
SUB-C-106-22-XXX
(SEE NOTE 9)
C
88°
REF
90°
-D-BE
-D
IN-PROCESS
SCALE 8:1
POS. 02-35
POS. 36-50
SECTION "B"-"B"
(-D-BE BODY: CLP-XX-DBE-XX)
(DIFFERENT AS SHOWN,
OTHERWISE SAME AS -D BODY)
SECTION "A"-"A"
2.5 MAX SWAY
(TYP)
.010 0.25
.012 0.30
3°
.170±.010 4.31±0.25
.016 0.41 x .005[0.13] REF
.004[0.10]
.006[0.15]
FIG 1
(-D BODY: CLP-XX-D-XX)
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 3:1
INSULATOR: LCP, UL 94 VO, COLOR: BLACK
CONTACT: PHOS BRONZE
F:\DWG\MISC\MKTG\CLP-1XX-XX-XXX-D-XX-MKT.SLDDRW
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
LOW PROFILE .050 x .050 DOUBLE ROW ASM
DWG. NO.
CLP-1XX-XX-XXX-D-XX
BY: PURVIS
01/31/1994
SHEET 1 OF 3
AVAILABLE ON POSITIONS 05 THRU 50 ONLY
NOTE: "N" = USED MEASURED DIMENSION (REF)
"Q" = [("N" - .250[6.35])/2] ±.020[0.51]
REVISION DE
C
"N" (SEE NOTE)
C
"Q" 3.45
(SEE NOTE)
.100 2.54
.005 X 45° REF (TYP 4 SIDES)
.019 0.47
(No OF POS x .0500[1.270]) - .100[2.54] 22.86
LMP-01
.0070 0.178
REF (TYP)
.250 6.35 REF
FIG 2
.0050 0.127 REF (TYP)
FIG 3
-P: PICK AND PLACE PAD
(AVAILABLE ON POSITION 05 THRU 50 ONLY)
-A: ALIGNMENT PIN
(3 POSITION MINIMUM)
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1)
.025 0.64 REF (TYP)
.0100 0.254 REF (TYP)
C
.121 3.07
"A"
.051 1.30
C
"R"
(SEE NOTE)
.019±.020 0.47±0.51
.035 0.89 REF
.325 8.26
REF
C
"T"±.010
PPP-38-X-X-XX
.275 6.99
.095 2.41
"S"
(SEE NOTE)
C
"U"±.0050
FIG 5
FIG 4
(NOT AVAILABLE WITH -P OR -PA OPTIONS)
(NOT AVAILABLE WITH -P, -A OR -K OPTIONS)
NOTE: "R" = USED MEASURED DIMENSION (REF)
"S" ON -03 THRU -50 POS = {("R" - .1575[4.000])/2} ±.020[0.51]
"S" ON -02 POS = {("R" - .1180[2.997])/2} ±.020[0.51]
"U" ON -03 THRU -50 POS = .1575 [4.000]
"U" ON -02 POS = .118 [2.997]
PROPRIETARY NOTE
SHEET SCALE: 4:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
CLP-1XX-XX-XXX-D-XX
BY: PURVIS
01/31/1994
SHEET 2 OF 3
REVISION DE
PACKAGING
(SEE NOTE 4, SHEET 1)
PT-CLX-002-D
PT-CLX-001-D
PROPRIETARY NOTE
SHEET SCALE: 4:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
CLP-1XX-XX-XXX-D-XX
BY: PURVIS
01/31/1994
SHEET 3 OF 3
CLP-105-02-S-D-BE-A-TR 价格&库存
很抱歉,暂时无法提供与“CLP-105-02-S-D-BE-A-TR”相匹配的价格&库存,您可以联系我们找货
