SSW-107-01-L-D
SSW-107-01-L-D
    SAMTEC(申泰)
    插件,P=2.54mm
    排母 间距:2.54mm 2x7P 直插
SSW-107-01-L-D 数据手册
SSW-1XX-XX-XXX-X-XX-XXX-XX REVISION CI No OF POSITIONS -01 THRU -50 (-P OPTION: 36 POS MAX) DO NOT SCALE FROM THIS PRINT LEAD STYLE (SEE TABLE 1) -01 THRU -06 (STD. INS. FORCE) -21 THRU -24 (LOW INS. FORCE) OPTION -LL: LOCKING LEAD (SEE FIG 4, SHT 2) (N/A IN SINGLE ROW, 1 & 2 POSITION) POLARIZING OPTION INDICATE POS, SEE FIG 3, SHT 3 OPTION -RA: RIGHT ANGLE (SEE FIG 2, SHT 2) PLATING SPECIFICATION (STYLE -01 & -21 N/A) -N: NOTCH (SEE FIG 6, SHT 3) -G: 20µ" GOLD IN CONTACT AREA, (ONLY AVAILABLE IN -D ROW) 3µ" GOLD ON TAIL (ONLY AVAILABLE IN 5, 7, 8, 10, 12, -T: MATTE TIN CONTACT AND TAIL 13, 15, 17, 20, 25, 32, 36 POSITIONS) (CONTACT -21 THRU -24 N/A) (USE NSW-XX-D-N-XX BODY, -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, SEE TABLE 6) MATTE TIN ON TAIL -H: 30µ" HEAVY GOLD IN CONTACT AREA, ROW SPECIFICATION 3µ" GOLD ON TAIL -E: 50µ" EXTRA HEAVY GOLD IN CONTACT AREA, -S: SINGLE 3µ" GOLD ON TAIL -D: DOUBLE (CONTACT -01 & -02 STRAIGHT ONLY) -T: TRIPLE -F: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, -P: SINGLE MATTE TIN ON TAIL -Q: TRIPLE WITH ONLY OUTER 2 ROWS -STL: 30µ" SELECTIVE GOLD IN CONTACT AREA, FILLED TIN/LEAD (90/10 ± 5%) TAIL .295 7.493 -TL: TIN/LEAD (90/10 ± 5%) CONTACT AND TAIL (AVAILABLE ONLY ON LEAD STYLES -01) REF -TM: MATTE TIN CONTACT AND TAIL (CONTACT -21 THRU -24 N/A) -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -FM: 3µ" FLASH GOLD SELECTIVE IN CONTACT AREA, MATTE TIN ON TAIL -L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL .200 5.08 .050 1.27 REF ((No OF POS x .100[2.54]) + .020[0.51] .010[0.25]) 60° .095 2.41 REF SEE NOTE 10 .0110 0.280 REF .245 6.22 'A' 2 MAX SWAY (EITHER DIRECTION) .295 7.493 REF .195 4.95 REF SEE NOTE 8 .335 8.51 DETAIL 'A' SCALE 4 : 1 NOTES: .095 2.41 REF "B" C .031 0.79 X .016[0.41] REF (TYP) 1. C REPRESENTS A CRITICAL DIMENSION. 2. MAXIMUM CUT FLASH: .015[0.38] WITH NO FLASH BELOW STANDOFFS OR IN CONTACT HOLES. 3. MINIMUM CONTACT PUSHOUT FORCE: 1.5 LBS 4. MAXIMUM ALLOWABLE BOW: .003[0.08] INCH/INCH 5. NOTE DELETED. 6. MAXIMUM ALLOWABLE VARIATION BETWEEN ROWS: .010[0.25] 7. "END WALLS" AFTER CUTTING SHOULD BE .020±.003 [0.51±0.08]. 8. NOTCH ON -P-RA & -D-RA-N OPTIONS TO BE ORIENTED AS SHOWN. 9. SHEAR LOCATION TO BE WITHIN .001[0.03] OF THE BREAK OFF CENTER LOCATION. 10. SHEAR LOCATION TO BE WITHIN .001[0.03] OF THE BREAK OFF CENTER LOCATION FOR MACHINE FILL. 11. LEAD STYLE X2 (SINGLE AND DOUBLE) -RA's TO BE LAYER PACKAGED. ALL OTHER -RA LEAD STYLES: UNDER 5 POSITION TO BE LAYER PACKAGED, 5 AND UP TO BE PACKAGED IN TUBES. 12. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM -Q -S -P .100 2.54 C "G" -D-N -D .200 5.08 FIG 1 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS .XX: .01 [0.3] .XXX: .005 [0.13] ANGLES 2 * PROPRIETARY NOTE F:\DWG\MISC\MKTG\SSW-1XX-XX-XXX-X-XX-XXX-XX-MKT.SLDDRW SHEET SCALE: 2:1 -T * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. MATERIAL: DO NOT SCALE DRAWING INSULATOR: -S, -D, -D-N: VECTRA E130i, COLOR: BLACK UL94 V0 -P, -T: PCT, COLOR: BLACK UL94 V0 CONTACT: PHOSPHOR BRONZE, SPRING TEMPER ALLOY 511 OR 510 (TENSILE STRENGTH 90-100 KSI) (YEILD STRENGTH @ 2% OFFSET 88-98 KSI) PER MIL-B-13501 THICKNESS: .0160±.001 [0.635±0.03] C .100 2.54 ±"G" 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: ASSEMBLY, SOCKET STRIP .016 X .031 TAIL DWG. NO. SSW-1XX-XX-XXX-X-XX-XXX-XX BY: PURVIS 06/12/1987 SHEET 1 OF 3 REVISION CI SEE NOTE 8 C SEE NOTE 8 C .06 1.524 90° -P-RA -S-RA "C" (SEE TABLE 2, SHEET 1) C "D" C .100 2.54 C .200 5.08 C .100 2.54 C "E" -D-RA-N "F" C -T-RA -D-RA FIG 2 RIGHT ANGLE OPTION ALL OPTIONS DIFFERENT AS SHOWN, OTHERWISE SAME AS -S-RA 01 CL CL 01 CL CL .04 1.0 -S 01 -D -D-N CRIMP LOCATIONS -T 01 CL CL 01 CL -D-LL -S-LL ODD POSITIONS = CRIMP LOCATION 01 IN-PROCESS -T-LL R.0560 1.422 (TYP) R.0320 0.813 (TYP) CL +0.13 .008+-.005 .000 0.20 0.00 C (TYP) .04 1.0 -S -D 01 -D-N CRIMP LOCATIONS -T 01 -S-RA-LL CRIMP DETAIL ALL CONFIGURATIONS -D-RA-LL EVEN POSITIONS = CRIMP LOCATION -T-RA-LL FIG 4 LOCKING LEAD OPTION ALL OPTIONS SAME AS -S-XX-LL UNLESS OTHERWISE SHOWN * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\SSW-1XX-XX-XXX-X-XX-XXX-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: ASSEMBLY, SOCKET STRIP .016 X .031 TAIL DWG. NO. SSW-1XX-XX-XXX-X-XX-XXX-XX BY: PURVIS 06/12/1987 SHEET 2 OF 3 REVISION CI SSW-1XX-04-XXX-S-RA SSW-1XX-24-XXX-S-RA SSW-1XX-03-XXX-S-RA SSW-1XX-23-XXX-S-RA SSW-1XX-03-XXX-D-RA SSW-1XX-23-XXX-D-RA SSW-1XX-03-XXX-D-RA-N SSW-1XX-23-XXX-D-RA-N SEE NOTE 8 01 50 SSW-1XX-XX-XXX-T-RA SSW-1XX-XX-XXX-Q-RA -S, -P, -S-RA & -P-RA 100 02 99 01 FIG 5 PACKAGING VIEWS (SEE NOTE 11) -D, -D-RA .050 1.27 REF 01 99 02 100 .190 4.83 REF .245 6.22 REF NSW-XX-D-N-XX (SEE TABLE 6) -D-N, -D-RA-N 150 03 FIG 6 NOTCH OPTION DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 * 148 01 -T, -Q, -T-RA & -Q-RA FIG 3 POLARIZATION LOCATION (INSERT PK-15-N INTO SPECIFIED POSITION & BREAK OFF TAB) (-RA OPTION SHOWN FOR ORIENTATION PURPOSE ONLY) F:\DWG\MISC\MKTG\SSW-1XX-XX-XXX-X-XX-XXX-XX-MKT.SLDDRW PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: ASSEMBLY, SOCKET STRIP .016 X .031 TAIL DWG. NO. SSW-1XX-XX-XXX-X-XX-XXX-XX BY: PURVIS 06/12/1987 SHEET 3 OF 3
SSW-107-01-L-D
1. 物料型号:文档描述了多种型号的插座条,包括不同的引脚数量和配置。
2. 器件简介:SSW-1XX-XX-XXX-X-XX-XXX-XX是Samtec公司生产的插座条,具有多种不同的配置选项,如引脚样式、极性选项、锁定引脚等。
3. 引脚分配:文档提供了详细的引脚分配表,包括不同的引脚样式和对应的型号。
4. 参数特性: - 引脚样式:包括直引脚和直角引脚等。 - 极性选项:包括锁扣、直角等。 - 引脚材料:包括磷青铜等。 - 镀层规格:包括接触区域的金镀层和尾部的锡镀层。
5. 功能详解:文档详细描述了插座条的功能特性,如最大插入力、最小接触推力、最大允许弯曲等。
6. 应用信息:虽然文档没有直接提供应用信息,但从提供的规格和选项可以推断,这些插座条适用于需要高可靠性和多种配置选项的电子应用。
7. 封装信息:文档提供了封装的详细尺寸和材料规格,如绝缘体材料、接触材料的厚度和材料类型。
SSW-107-01-L-D 价格&库存
很抱歉,暂时无法提供与“SSW-107-01-L-D”相匹配的价格&库存,您可以联系我们找货
SSW-107-01-L-D
  • 1+18.205471+2.35651
  • 100+16.25703100+2.10431
  • 250+14.66668250+1.89845
  • 500+12.81129500+1.65829
  • 1000+9.453841000+1.22370
  • 2500+7.156682500+0.92636
  • 5000+7.030095000+0.90998
库存:3690
