CES-115-01-T-S
CES-115-01-T-S
    SAMTEC(申泰)
    插件,P=2.54mm
    排母 间距:2.54mm 1x15P 直插
CES-115-01-T-S 数据手册
REVISION AE CES-1XX-XX-X-S-XX NOTES: No OF POSITIONS -01 THRU -50 1. C REPRESENTS A CRITICAL DIMENSION. 2. MIN CONTACT RETENTION 2 LB C 3. MAX ALLOWABLE BOW: .006 [.015] IN/IN .03 .001 4. "END WALLS" AFTER CUTTING SHOULD BE .015 .005[.38 .13] 5. MAX CUT FLASH: .015 [.38] WITH NO FLASH ALLOWED IN HOLES. 6. MAX TERMINAL BURR: .003 [.08] 7. WHEN FILLING THE ASSEMBLY, ALL CONTACTS MUST BE FACING THE SAME DIRECTION. 8. TO BE MEASURED AT THE BEND. DO NOT SCALE FROM THIS PRINT C CONTACT LEAD STYLE -01: USE C-45-01-X -02: USE C-45-02-X ROW SPECIFICATION -S: SINGLE ROW (USE CES-XX-S) PLATING SPECIFICATION -T: MATTE TIN, CONTACT AND TAIL -G: 10µ" GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -F: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -L: 10µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL NO OF POSITIOINS X .100 [2.54] .008 [.20] (CUT POSITIONS) +.002 [.03] (50 POSITION ONLY) -.005 [.13] +.001 OPTIONS -RA: RIGHT ANGLE (STYLE -02 ONLY) +0.03 .050 - .005 1.27 - 0.13 (SEE NOTE 4) "B" "B" NOTE: MIXED PIN ORIENTATION ACCEPTABLE .120 3.05 REF CL "A" CL PACKAGING VIEW LEAD STYLE -01 & -02 CL .020 0.51 REF .200 5.08 REF C "A" 2 MAX SWAY (EITHER DIRECTION) SECTION "B"-"B" .040 1.02 (SEE NOTE 8) NOTE: PINS TO BE FACING THE SAME DIRECTION "A" .100 2.54 .025 0.64 REF C 90°±2° .120 3.05 REF .010 0.25 REF 2 MAX SWAY (EITHER DIRECTION) -RA PACKAGING VIEW LEAD STYLE -02-RA SECTION "A"-"A" UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: PBT, UL 94 VO COLOR: BLACK TERMINAL: PHOS BRONZE F:\DWG\MISC\MKTG\CES-1XX-XX-X-S-XX-MKT.SLDDRW SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. CLOSED ENTRY SOCKET STRIP CES-1XX-XX-X-S-XX BY: KOLB 12-6-89 SHEET 1 OF 1
CES-115-01-T-S 价格&库存
很抱歉,暂时无法提供与“CES-115-01-T-S”相匹配的价格&库存,您可以联系我们找货
