RSMF12JTR120
RSMF12JTR120
    SEI
    插件
    插件电阻 - 120mΩ ±5% 1/2W ±200ppm/℃
RSMF12JTR120 数据手册
RSF / RSMF Series Stackpole Electronics, Inc. General Purpose Metal Oxide Resistor Resistive Product Solutions Features: • • • • • • • • • Lower-cost alternative to carbon comps and wirewounds Coating meets UL 94V-0 Meets solvent test of Mil Standard 202, Method 215 Cut and formed product is available on select sizes - contact Stackpole Higher or lower resistance values may be possible - contact Stackpole Flameproof 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical Specifications Maximum Maximum Dielectric Power Rating Type/Code Working Overload Withstanding (W) @ 70ºC (1) Voltage (V) Voltage (V) Voltage (V) RSF12 0.5 250 400 350 RSF1 1 350 600 600 RSF2 2 350 600 600 RSF3 3 800 1000 750 RSF5 5 1000 1000 750 RSMF12 0.5 250 400 350 RSMF1 1 350 600 500 RSMF2 2 350 600 500 RSMF3 3 500 800 600 RSMF5 5 1000 1000 750 (1) Lesser of √ P*R or maximum working voltage (2) Contact Stackpole for resistance values outside the specified range (2) TCR (ppm/ºC) ± 200 ± 200 ± 200 ± 200 ± 200 ± 200 ± 200 ± 200 ± 200 ± 200 Ohmic Range (Ω) and Tolerance 1% 2% 0.1 - 150K 0.1 - 75K 0.1 - 100K 0.1 - 120K 0.1 - 470K 0.1 - 510K 0.1 - 470K 0.1 - 510K 0.1 - 46.4K 0.1 - 47K 0.1 - 75K 0.1 - 100K 0.1 - 118K 0.1 - 120K 0.1 - 470K 0.1 - 510K 5% 0.1 - 510K 0.1 - 510K 0.1 - 510K 0.1 - 510K 0.1 - 510K 0.1 - 470K 0.1 - 470K 0.1 - 470K 0.1 - 470K 0.1 - 510K Mechanical Specifications Type/Code RSF12 RSF1 RSF2 RSF3 RSF5 RSMF12 RSMF1 RSMF2 RSMF3 RSMF5 A Body Length 0.35 ± 0.04 9.00 ± 1.00 0.43 ± 0.06 11.00 ± 1.50 0.59 ± 0.06 15.00 ± 1.50 0.69 ± 0.04 17.50 ± 1.00 0.96 ± 0.04 24.50 ± 1.00 0.24 ± 0.03 6.00 ± 0.80 0.35 ± 0.04 9.00 ± 1.00 0.43 ± 0.06 11.00 ± 1.50 0.59 ± 0.06 15.00 ± 1.50 0.69 ± 0.04 17.50 ± 1.00 B Body Diameter 0.13 ± 0.03 3.20 ± 0.80 0.18 ± 0.04 4.50 ± 1.00 0.22 ± 0.04 5.50 ± 1.00 0.24 ± 0.02 6.00 ± 0.50 0.31 ± 0.02 8.00 ± 0.50 0.09 ± 0.01 2.30 ± 0.30 0.13 ± 0.03 3.20 ± 0.80 0.18 ± 0.04 4.50 ± 1.00 0.22 ± 0.04 5.50 ± 1.00 0.24 ± 0.02 6.00 ± 0.50 Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 C Lead Length (Bulk) 1.10 ± 0.12 28.00 ± 3.00 1.10 ± 0.20 28.00 ± 5.00 1.18 ± 0.20 30.00 ± 5.00 1.38 ± 0.12 35.00 ± 3.00 1.38 ± 0.12 35.00 ± 3.00 1.10 ± 0.12 28.00 ± 3.00 1.10 ± 0.12 28.00 ± 3.00 1.18 ± 0.20 30.00 ± 5.00 1.18 ± 0.20 30.00 ± 5.00 1.38 ± 0.08 35.00 ± 2.00 D Lead Diameter 0.03 ± 0.003 0.70 ± 0.08 0.03 ± 0.002 0.80 ± 0.05 0.03 ± 0.004 0.75 ± 0.10 0.03 ± 0.002 0.80 ± 0.05 0.03 ± 0.002 0.80 ± 0.05 0.02 ± 0.003 0.55 ± 0.07 0.03 ± 0.003 0.70 ± 0.08 0.03 ± 0.002 0.80 ± 0.05 0.03 ± 0.004 0.75 ± 0.10 0.03 ± 0.002 0.80 ± 0.05 Lead-Tape Specification 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com RSF / RSMF Series Stackpole Electronics, Inc. General Purpose Metal Oxide Resistor Resistive Product Solutions Performance Characteristics Test Test Method Test Specification Typical Results Insulation Resistance JIS C5201-1, IEC60115-1, 4.6 ≥ 1G Ω ≥ 1G Ω Voltage Proof JIS C5201-1, IEC60115-1, 4.7 ≤ ± (0.5% + 0.05 Ω) No mechanical damage < ± 0.25% Short Time Overload JIS C5201-1, IEC60115-1, 4.13 ≤ ± (0.75% + 0.05 Ω) < ± 0.1% Resistance to Solder Heat JIS C5201-1, IEC60115-1, 4.18 ≤ ± (2.0% + 0.05 Ω) < ± 1.0% Endurance at 70°C JIS C5201-1, IEC60115-1, 4.25.1 ≤± (5.0% + 0.05 Ω) < ± 2.0% Robustness of Terminations JIS C5201-1, IEC60115-1, 4.16 ≤ ± (1.0% + 0.05 Ω) < ± 0.10% ≤± (5% + 0.05 Ω) Damp Heat (Steady state) JIS C5201-1, IEC60115-1, 4.24 < ± 1.5% ≤± (1% + 0.05 Ω) Rapid Change of Temperature JIS C5201-1, IEC60115-1, 4.19 < ± 0.2% Resistance to Solvents JIS C5201-1, IEC60115-1, 4.29 No damage to component or removal of marking Pass ≤± (2% + 0.05 Ω) Intermittent Overload JIS C5201-1, IEC60115-1, 4.39 < ± 0.3% Accidental Overload (Flame resistance) JIS C5201-1, IEC60115-1, 4.26 No flaming of gauze Pass Operating temperature range is -55ºC to +200ºC (RSF12, RSMF12, RSMF1) -55ºC to +235ºC (all others) Power Derating Curve: Surface Temperature Rise: Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com RSF / RSMF Series Stackpole Electronics, Inc. General Purpose Metal Oxide Resistor Resistive Product Solutions Repetitive Pulse Information: If repetitive pulses are applied to resistors, pulse wave form must be less than “pulse limiting voltage”, “pulse limiting current” or “pulse limiting wattage” calculated by the formula below. Vp = K√P x R x T/t lp = K√P/R x T/t Pp = K2 x P x T/t Where: Vp: lp: Pp: P: R: T: t: K: [Vr: Note 1: Note 2: Note 3: Note 4: Note 5: Note 6: Pulse limiting voltage (V) Pulse limiting current (A) Pulse limiting wattage (W) Power rating (W) Nominal resistance (ohm) Repetitive period (sec) Pulse duration (sec) Coefficient: 0.8 Rated Voltage (V), Ir: Rated Current (A)] If T > 10 → T = 10 (sec), T / t > 1000 → T / t = 1000 If T > 10 and T / t > 1000, “Pulse Limiting power (Single pulse) is applied If Vp < Vr (lp < lr or Pp < P), Vr (lr, P) is Vp (lp, Pp) Pulse limiting voltage (current, wattage) is applied at less than rated ambient temperature. If ambient temperature is more than the rated temperature (70 °C), decrease power rating according to “Power Derating Curve” Assure sufficient margin for use period and conditions for “pulse limiting voltage” If the pulse waveform is not square wave, judge after transform the waveform into square wave according to the “Waveform Transformation to Square Wave”. Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com RSF / RSMF Series Stackpole Electronics, Inc. General Purpose Metal Oxide Resistor Resistive Product Solutions Waveform Transformation to Square Wave 1. Discharge curve wave with time constant “t” → Square wave 2. Damping oscillation wave with time constant of envelope “t” → Square wave 3. Half-wave rectification wave → Square wave 4. Triangular wave → Square wave 5. Special wave → Square wave Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com RSF / RSMF Series Stackpole Electronics, Inc. General Purpose Metal Oxide Resistor Resistive Product Solutions Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Minimum 60 seconds 100°C 240°C * N/A Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Recommended Lead Free Resistor Reflow Profile Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com RSF / RSMF Series Stackpole Electronics, Inc. General Purpose Metal Oxide Resistor Resistive Product Solutions Reel Packaging Specifications Reeled in accordance with EIA-296-F Type/Code RSF12 RSF1 RSF2 RSF3 RSF5 Type/Code RSMF12 RSMF1 RSMF2 RSMF3 RSMF5 A max.(1) 2.736 69.50 2.815 71.50 3.524 89.50 3.740 95.00 4.331 110.00 .(1) A max 2.618 66.50 2.736 69.50 2.815 71.50 3.524 89.50 3.740 95.00 B max 13.504 343.00 13.504 343.00 13.504 343.00 12.008 305.00 12.008 305.00 B max 13.504 343.00 13.504 343.00 13.504 343.00 13.504 343.00 12.008 305.00 0.197 5.00 0.197 5.00 0.394 10.00 0.394 10.00 0.394 10.00 0.197 5.00 0.197 5.00 0.197 5.00 0.394 10.00 0.394 10.00 C ± ± ± ± ± ± ± ± ± ± C ± ± ± ± ± ± ± ± ± ± D(2) 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.500 ± 0.079 63.50 ± 2.00 2.874 ± 0.079 73.00 ± 2.00 3.465 ± 0.079 88.00 ± 2.00 (2) D 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.063 ± 0.079 52.40 ± 2.00 2.500 ± 0.079 63.50 ± 2.00 2.874 ± 0.079 73.00 ± 2.00 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 Tape 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 Tape 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 Unit inches mm inches mm inches mm inches mm inches mm Unit inches mm inches mm inches mm inches mm inches mm Dimension "E": This is a non-critical dimension that does not have a tolerance in the standard. Range of diameters is from 0.547 inches (13.90 mm) to 1.500 inches (38.10 mm). (1) Reference value only. The "A" dimension shall be governed by the overall length of the taped component. The distance between flanges shall be 0.059 inches (1.50 mm) to 0.315 (8.00 mm) greater than the overall component. (2) The given dimension "D" expresses the standard width spacing. A 26 mm narrow spacing is available as option "N" packaging code. Ammo Packaging Specifications Type/Code Size A B RSF 2 3.346 ± 0.079 85.00 ± 2.00 3.543 ± 0.118 90.00 ± 3.00 Unit inches mm RSF 1 2.953 ± 0.079 75.00 ± 2.00 2.756 ± 0.118 70.00 ± 3.00 inches mm RSMF 3 3.346 ± 0.079 85.00 ± 2.00 3.543 ± 0.118 90.00 ± 3.00 RSMF 2 2.953 ± 0.079 75.00 ± 2.00 2.756 ± 0.118 70.00 ± 3.00 inches mm RSMF 1 2.953 ± 0.079 75.00 ± 2.00 2.756 ± 0.118 70.00 ± 3.00 inches mm Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 6 C 10.039 ± 0.197 255.00 ± 5.00 inches mm www.seielect.com marketing@seielect.com RSF / RSMF Series Stackpole Electronics, Inc. General Purpose Metal Oxide Resistor Resistive Product Solutions Pana-Sert Packaging Specifications Symbol Description ØD Body diameter A Body length A0 Mounting height Ød Lead diameter P Component pitch P0 Feed hole pitch P1 Feed hole center to lead P2 Feed hole center to body F Lead-lead distance Alpha Performing angle Δh Component alignment Δg Component alignment W Tape width W0 Hold down tape width W1 Hole position W2 Hold down tape position Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. PRSM12 0.157 max. 4.00 max. 0.394 max. 10.00 max. 0.571 max. 14.50 max. 0.028 ± 0.004 0.70 ± 0.10 PRSF1 / PRSM2 0.217 max. 5.50 max. 0.492 max. 12.50 max. 0.709 max. 18.00 max. 0.028 ± 0.004 0.70 ± 0.10 0.500 12.70 0.500 12.70 0.152 3.85 0.250 6.35 0.200 5.08 ± 0.039 ± 1.00 ± 0.012 ± 0.30 ± 0.020 ± 0.50 ± 0.016 ± 0.40 +0.24 / -0.008 +0.60 / -0.20 45° max 7 0.000 0.00 0.000 0.00 0.709 18.00 0.492 12.50 0.354 9.00 0.079 2.00 ± 0.079 ± 2.00 ± 0.118 ± 3.00 +0.039 / -0.031 +1.00 / -0.80 min. min. ± 0.020 ± 0.50 +0 / -0.059 +0 / -1.50 www.seielect.com marketing@seielect.com RSF / RSMF Series Stackpole Electronics, Inc. General Purpose Metal Oxide Resistor Resistive Product Solutions Packaging Specifications – Pana-Sert (cont.) Symbol Description PRSM12 H Distance to tape center H0 Lead wire clinch height I Lead wire portrait ØD0 Feed hole diamenter i Total tape thickness L Length of shipped lead PRSF1 / PRSM2 0.748 19.00 0.630 16.00 0.039 1.00 0.157 4.00 0.028 0.70 0.433 11.00 ± 0.039 ± 1.00 ± 0.020 ± 0.50 max. max. ± 0.008 ± 0.20 max. max. max. max. Pulse Limiting Power (one pulse) / RSMF Series ≤ 5Ω Pulse Limiting Power (one pulse) / RSMF Series > 5Ω Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 8 www.seielect.com marketing@seielect.com RSF / RSMF Series Stackpole Electronics, Inc. General Purpose Metal Oxide Resistor Resistive Product Solutions RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Termination Type Standard Series RoHS Compliant RSF General Purpose Metal Oxide Leaded Resistor Axial YES RSMF Mini-Metal Oxide Leaded Resistor Axial YES Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) 99.3/0.7 Sn/Cu 100% Matte Sn 99.3/0.7 Sn/Cu 100% Matte Sn Apr-05 (Japan) Jan-04 (Taiwan, China) Apr-05 (Japan) Jan-04 (Taiwan, China) Lead-Free Effective Date Code (YY/WW) 05/14 04/01 05/14 04/01 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the Eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 R S F 1 2 J T R 4 7 0 Product Series RSF Metal Oxide RSMF Mini PRSF Panasert PRSM Panasert Mini Power Rating Size W 12 0.5 1 1 2 2 3 3 5 5 Code F G J Tolerance Tol Value 1% E96 2% E24 5% Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. Code Description T Tape and Reel T Tape and Reel A Ammo B Bulk 9 Packaging Size Quantity RSMF12, PRSM12 5000 RSF12, RSF1 2500 RSMF1, RSMF2 PRSF1, PRSM2 2000 RSF2, RSMF3 1000 RSF3, RSMF5 1000 RSF5 500 RSMF12 5000 RSF12; RSMF1, PRSM12 2000 RSF1, RSF2, RSMF2, PRSF1, PRSM2, RSMF3 1000 RSF3, RSF5, RSMF5 All Sizes 500 1000 Resistance Value Four characters with the multiplier used as the decimal holder. 0.22 ohm = R220 33.2 ohm = 33R2 10.2 Kohm = 10K2 1 Mohm = 1M00 www.seielect.com marketing@seielect.com
RSMF12JTR120 价格&库存
很抱歉,暂时无法提供与“RSMF12JTR120”相匹配的价格&库存,您可以联系我们找货
