W78L052A24FL
W78L052A24FL
    NUVOTON(新唐)
    BQFP44
    IC MCU 8BIT 8KB FLASH 44QFP
W78L052A24FL 数据手册
W78LE52/W78L052A 8-BIT MICROCONTROLLER Table of Contents1. GENERAL DESCRIPTION ............................................................................................................... 2 2. FEATURES....................................................................................................................................... 2 3. PIN CONFIGURATIONS .................................................................................................................. 3 4. PIN DESCRIPTION .......................................................................................................................... 4 5. FUNCTIONAL DESCRIPTION ......................................................................................................... 5 5.1 Eight-source interrupt information: .......................................................................................... 6 6. ON-CHIP FLASH EPROM CHARACTERISTICS .......................................................................... 10 7. SECURITY BITS............................................................................................................................. 12 8. ABSOLUTE MAXIMUM RATINGS ................................................................................................. 13 9. DC CHARACTERISTICS................................................................................................................ 14 10. AC CHARACTERISTICS................................................................................................................ 16 11. TIMING WAVEFORMS................................................................................................................... 19 12. TYPICAL APPLICATION CIRCUITS.............................................................................................. 22 13. PACKAGE DIMENSIONS............................................................................................................... 24 14. REVISION HISTORY...................................................................................................................... 26 -1- Publication Release Date: November 6, 2006 Revision A6 W78LE52/W78L052A 1. GENERAL DESCRIPTION The W78L052 is an 8-bit microcontroller which can accommodate a wider frequency range with low power consumption. The instruction set for the W78L052 is fully compatible with the standard 8051. The W78L052 contains an 8K bytes Flash EPROM; a 256 bytes RAM; four 8-bit bi-directional and bitaddressable I/O ports; an additional 4-bit I/O port P4; three 16-bit timer/counters; a hardware watchdog timer and a serial port. These peripherals are supported by eight sources two-level interrupt capability. To facilitate programming and verification, the Flash EPROM inside the W78L052 allows the program memory to be programmed and read electronically. Once the code is confirmed, the user can protect the code for security. The W78L052 microcontroller has two power reduction modes, idle mode and power-down mode, both of which are software selectable. The idle mode turns off the processor clock but allows for continued peripheral operation. The power-down mode stops the crystal oscillator for minimum power consumption. The external clock can be stopped at any time and in any state without affecting the processor. 2. FEATURES x x x x x x x x Fully static design 8-bit CMOS microcontroller x x x x x x x x Three 16-bit timer/counters Wide supply voltage of 2.4V to 5.5V 256 bytes of on-chip scratchpad RAM 8 KB electrically erasable/programmable Flash EPROM 64 KB program memory address space 64 KB data memory address space Four 8-bit bi-directional ports One extra 4-bit bit-addressable I/O port, additional INT2 / INT3 (available on 44-pin PLCC/QFP package) One full duplex serial port(UART) Watchdog Timer Eight sources, two-level interrupt capability EMI reduction mode Built-in power management Code protection mechanism Packages: − Lead Free (RoHS) DIP 40: W78L052A24DL − Lead Free (RoHS) PLCC 44: W78L052A24PL − Lead Free (RoHS) PQFP 44: W78L052A24FL -2- W78LE52/W78L052A 3. PIN CONFIGURATIONS 40-Pin DIP T2, P1.0 T2EX, P1.1 P1.2 P1.3 P1.4 P1.5 P1.6 P1.7 RST RXD, P3.0 TXD, P3.1 INT0, P3.2 INT1, P3.3 T0, P3.4 T1, P3.5 WR, P3.6 RD, P3.7 XTAL2 XTAL1 VSS 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 22 21 VDD P0.0, AD0 P0.1, AD1 P0.2, AD2 P0.3, AD3 P0.4, AD4 P0.5, AD5 P0.6, AD6 P0.7, AD7 EA ALE PSEN P2.7, A15 P2.6, A14 P2.5, A13 P2.4, A12 P2.3, A11 P2.2, A10 P2.1, A9 P2.0, A8 44-Pin QFP 44-Pin PLCC T 2 E X , P P P P 1 1 1 1 . . . . 4 3 2 1 P1.5 P1.6 P1.7 RST RXD, P3.0 INT2, P4.3 TXD, P3.1 INT0, P3.2 INT1, P3.3 T0, P3.4 T1, P3.5 T 2 , P 1 . 0 / I N T 3 , P 4 V . D 2 D A D 0 , P 0 . 0 A D 1 , P 0 . 1 A D 2 , P 0 . 2 A D 3 , P 0 . 3 6 5 4 3 2 1 44 43 42 41 40 7 39 8 38 9 37 10 36 11 35 12 34 13 33 14 32 15 31 16 30 17 29 18 19 20 21 22 23 24 25 26 27 28 P 3 . 6 , / W R P 3 . 7 , / R D X T A L 2 X V P P T S 4 2 A S . . L 0 0 1 , A 8 P 2 . 1 , A 9 P 2 . 2 , A 1 0 P 2 . 3 , A 1 1 T 2 E X , P P P P 1 1 1 1 . . . . 4 3 2 1 P0.4, AD4 P0.5, AD5 P0.6, AD6 P0.7, AD7 EA P4.1 ALE PSEN P2.7, A15 P2.6, A14 P2.5, A13 P1.5 P1.6 P1.7 RST RXD, P3.0 INT2, P4.3 TXD, P3.1 INT0, P3.2 INT1, P3T0, 3 P3.4 T1, P3.5 P 2 . 4 , A 1 2 A D 0 , P 0 . 0 A D 1 , P 0 . 1 A D 2 , P 0 . 2 A D 3 , P 0 . 3 44 43 42 41 40 39 38 37 36 35 34 33 32 31 3 30 4 29 5 28 6 27 7 8 26 9 25 10 24 11 23 12 13 14 15 16 17 18 19 20 21 22 1 2 P 3 . 6 , / W R -3- / I N T T 2 3 , , P P 1 4 V . . D 0 2 D P 3 . 7 , / R D X T A L 2 X V P P T S 4 2 A S . . L 0 0 1 , A 8 P 2 . 1 , A 9 P 2 . 2 , A 1 0 P 2 . 3 , A 1 1 P0.4, AD4 P0.5, AD5 P0.6, AD6 P0.7, AD7 EA P4.1 ALE PSEN P2.7, A15 P2.6, A14 P2.5, A13 P 2 . 4 , A 1 2 Publication Release Date: November 6, 2006 Revision A6 W78LE52/W78L052A 4. PIN DESCRIPTION SYMBOL DESCRIPTIONS EA EXTERNAL ACCESS ENABLE: This pin forces the processor to execute out of external ROM. It should be kept high to access internal ROM. The ROM address and data will not be presented on the bus if EA pin is high and the program counter is within on-chip ROM area. PSEN PROGRAM STORE ENABLE: PSEN enables the external ROM data onto the Port 0 address/ data bus during fetch and MOVC operations. When internal ROM access is performed, no PSEN strobe signal outputs from this pin. ALE ADDRESS LATCH ENABLE: ALE is used to enable the address latch that separates the address from the data on Port 0. RST RESET: A high on this pin for two machine cycles while the oscillator is running resets the device. XTAL1 CRYSTAL1: This is the crystal oscillator input. This pin may be driven by an external clock. XTAL2 CRYSTAL2: This is the crystal oscillator output. It is the inversion of XTAL1. VSS GROUND: Ground potential VDD POWER SUPPLY: Supply voltage for operation. PORT 0: Port 0 is a bi-directional I/O port which also provides a multiplexed low order P0.0−P0.7 address/data bus during accesses to external memory. The Port 0 is also an open-drain port and external pull-ups need to be connected while in programming. PORT 1: Port 1 is a bi-directional I/O port with internal pull-ups. The bits have alternate functions which are described below: P1.0−P1.7 T2(P1.0): Timer/Counter 2 external count input T2EX(P1.1): Timer/Counter 2 Reload/Capture control P2.0−P2.7 PORT 2: Port 2 is a bi-directional I/O port with internal pull-ups. This port also provides the upper address bits for accesses to external memory. PORT 3: Port 3 is a bi-directional I/O port with internal pull-ups. All bits have alternate functions, which are described below: RXD(P3.0) : Serial Port receiver input TXD(P3.1) : Serial Port transmitter output INT0 (P3.2) : External Interrupt 0 P3.0−P3.7 INT1 (P3.3) : External Interrupt 1 T0(P3.4) : Timer 0 External Input T1(P3.5) : Timer 1 External Input WR (P3.6) :External Data Memory Write Strobe RD (P3.7) : External Data Memory Read Strobe PORT 4: Another bit-addressable bidirectional I/O port P4. P4.3 and P4.2 are alternative P4.0−P4.3 function pins. It can be used as general I/O port or external interrupt input sources ( INT2 / INT3 ). -4- W78LE52/W78L052A 5. FUNCTIONAL DESCRIPTION The W78L052 architecture consists of a core controller surrounded by various registers, five general purpose I/O ports, 256 bytes of RAM, three timer/counters, and a serial port. The processor supports 111 different opcodes and references both a 64K program address space and a 64K data storage space. Timers 0, 1, and 2 Timers 0, 1, and 2 each consist of two 8-bit data registers. These are called TL0 and TH0 for Timer 0, TL1 and TH1 for Timer 1, and TL2 and TH2 for Timer 2. The TCON and TMOD registers provide control functions for timers 0 and 1. The T2CON register provides control functions for Timer 2. RCAP2H and RCAP2L are used as reload/capture registers for Timer 2. The operations of Timer 0 and Timer 1 are the same as in the W78C51. Timer 2 is a special feature of the W78L052: it is a 16-bit timer/counter that is configured and controlled by the T2CON register. Like Timers 0 and 1, Timer 2 can operate as either an external event counter or as an internal timer, depending on the setting of bit C/T2 in T2CON. Timer 2 has three operating modes: capture, autoreload, and baud rate generator. The clock speed at capture or auto-reload mode is the same as that of Timers 0 and 1. New Defined Peripheral In order to be more suitable for I/O, an extra 4-bit bit-addressable port P4 and two external interrupt INT2 , INT3 has been added to either the PLCC or QFP 44 pin package. And description follows: 1. INT2 / INT3 Two additional external interrupts, INT2 and INT3 , whose functions are similar to those of external interrupt 0 and 1 in the standard 80C52. The functions/status of these interrupts are determined/shown by the bits in the XICON (External Interrupt Control) register. The XICON register is bit-addressable but is not a standard register in the standard 80C52. Its address is at 0C0H. To set/clear bits in the XICON register, one can use the "SETB (/CLR) bit" instruction. For example, "SETB 0C2H" sets the EX2 bit of XICON. XICON - external interrupt control (C0H) PX3 EX3 IE3 IT3 PX2 EX2 IE2 IT2 PX3: External interrupt 3 priority high if set EX3: External interrupt 3 enable if set IE3: If IT3 = 1, IE3 is set/cleared automatically by hardware when interrupt is detected/serviced IT3: External interrupt 3 is falling-edge/low-level triggered when this bit is set/cleared by software PX2: External interrupt 2 priority high if set EX2: External interrupt 2 enable if set IE2: If IT2 = 1, IE2 is set/cleared automatically by hardware when interrupt is detected/serviced IT2: External interrupt 2 is falling-edge/low-level triggered when this bit is set/cleared by software -5- Publication Release Date: November 6, 2006 Revision A6 W78LE52/W78L052A 5.1 Eight-source interrupt information: VECTOR ADDRESS POLLING SEQUENCE WITHIN PRIORITY LEVEL ENABLE REQUIRED SETTINGS INTERRUPT TYPE EDGE/LEVEL External Interrupt 0 03H 0 (highest) IE.0 TCON.0 Timer/Counter 0 0BH 1 IE.1 - External Interrupt 1 13H 2 IE.2 TCON.2 Timer/Counter 1 1BH 3 IE.3 - Serial Port 23H 4 IE.4 - Timer/Counter 2 2BH 5 IE.5 - INTERRUPT SOURCE External Interrupt 2 33H 6 XICON.2 XICON.0 External Interrupt 3 3BH 7 (lowest) XICON.6 XICON.3 2. PORT4 Another bit-addressable port P4 is also available and only 4 bits (P4) can be used. This port address is located at 0D8H with the same function as that of port P1, except the P4.3 and P4.2 are alternative function pins. It can be used as general I/O pins or external interrupt input sources ( INT2 , INT3 ). Example: P4 MOV MOV ORL ANL REG 0D8H P4, #0AH ; Output data "A" through P4.0−P4.3. A, P4 ; Read P4 status to Accumulator. P4.#00000001B P4.#11111110B 3. Reduce EMI Emission Because of on-chip Flash EPROM, when a program is running in internal ROM space, the ALE will be unused. The transition of ALE will cause noise, so it can be turned off to reduce the EMI emission if it is useless. Turning off the ALE signal transition only requires setting the bit 0 of the AUXR SFR, which is located at 08Eh. When ALE is turned off, it will be reactivated when the program accesses external ROM/RAM data or jumps to execute an external ROM code. The ALE signal will turn off again after it has been completely accessed or the program returns to internal ROM code space. The AO bit in the AUXR register, when set, disables the ALE output. In order to reduce EMI emission from oscillation circuitry, W78L052 allows user to diminish the gain of on-chip oscillator amplifiers by using programmer to clear the B7 bit of security register. Once B7 is set to 0, a half of gain will be decreased. Care must be taken if user attempts to diminish the gain of oscillator amplifier, reducing a half of gain may affect the external crystal operating improperly at high frequency above 24MHz. The value of R and C1, C2 may need some adjustment while running at lower gain. ***AUXR - Auxiliary register (8EH) - - - - - AO: Turn off ALE output. -6- - - AO W78LE52/W78L052A 4. Power-off Flag ***PCON - Power control (87H) POF: - - POF GF1 GF0 PD IDL Power off flag. Bit is set by hardware when power on reset. It can be cleared by software to determine chip reset is a warm boot or cold boot. GF1, GF0: These two bits are general-purpose flag bits for the user. PD: Power down mode bit. Set it to enter power down mode. IDL: Idle mode bit. Set it to enter idle mode. The power-off flag is located at PCON.4. This bit is set when VDD has been applied to the part. It can be used to determine if a reset is a warm boot or a cold boot if it is subsequently reset by software. Watchdog Timer The Watchdog timer is a free-running timer which can be programmed by the user to serve as a system monitor, a time-base generator or an event timer. It is basically a set of dividers that divide the system clock. The divider output is selectable and determines the time-out interval. When the time-out occurs a system reset can also be caused if it is enabled. The main use of the Watchdog timer is as a system monitor. This is important in real-time control applications. In case of power glitches or electromagnetic interference, the processor may begin to execute errant code. If this is left unchecked the entire system may crash. The watchdog time-out selection will result in different time-out values depending on the clock speed. The Watchdog timer will de disabled on reset. In general, software should restart the Watchdog timer to put it into a known state. The control bits that support the Watchdog timer are discussed below. Watchdog Timer Control Register Bit: 7 6 5 4 3 2 1 0 ENW CLRW WIDL - - PS2 PS1 PS0 Mnemonic: WDTC Address: 8FH ENW : Enable watch-dog if set. CLRW : Clear watch-dog timer and prescaler if set. This flag will be cleared automatically WIDL : If this bit is set, watch-dog is enabled under IDLE mode. If cleared, watch-dog is disabled under IDLE mode. Default is cleared. PS2, PS1, PS0: Watch-dog prescaler timer select. Prescaler is selected when set PS2−0 as follows: -7- Publication Release Date: November 6, 2006 Revision A6 W78LE52/W78L052A PS2 PS1 PS0 0 0 0 0 1 1 1 1 0 1 0 1 0 0 1 1 PRESCALER SELECT 0 0 1 1 0 1 0 1 2 4 8 16 32 64 128 256 The time-out period is obtained using the following equation: 1 × 2 14 × PRESCALER × 1000 × 12 mS OSC Before Watchdog time-out occurs, the program must clear the 14-bit timer by writing 1 to WDTC.6 (CLRW). After 1 is written to this bit, the 14-bit timer, prescaler and this bit will be reset on the next instruction cycle. The Watchdog timer is cleared on reset. ENW WIDL IDLE EXTERNAL RESET OSC PRESCALER 1/12 Watchdog Timer Block Diagram 14-BIT TIMER CLEAR CLRW Typical Watch-Dog time-out period when OSC = 20 MHz PS2 PS1 PS0 0 0 0 0 1 1 1 1 0 1 0 1 0 0 1 1 WATCHDOG TIME-OUT PERIOD 0 0 1 1 0 1 0 1 19.66 mS 39.32 mS 78.64 mS 157.28 mS 314.57 mS 629.14 mS 1.25 S 2.50 S -8- INTERNAL RESET W78LE52/W78L052A Clock The W78L052 is designed to be used with either a crystal oscillator or an external clock. Internally, the clock is divided by two before it is used. This makes the W78L052 relatively insensitive to duty cycle variations in the clock. The W78L052 incorporates a built-in crystal oscillator. To make the oscillator work, a crystal must be connected across pins XTAL1 and XTAL2. In addition, a load capacitor must be connected from each pin to ground. An external clock source should be connected to pin XTAL1. Pin XTAL2 should be left unconnected. The XTAL1 input is a CMOS-type input, as required by the crystal oscillator. Power Management Idle Mode The idle mode is entered by setting the IDL bit in the PCON register. In the idle mode, the internal clock to the processor is stopped. The peripherals and the interrupt logic continue to be clocked. The processor will exit idle mode when either an interrupt or a reset occurs. Power-down Mode When the PD bit of the PCON register is set, the processor enters the power-down mode. In this mode all of the clocks are stopped, including the oscillator. The only way to exit power-down mode is by a reset. Reset The external RESET signal is sampled at S5P2. To take effect, it must be held high for at least two machine cycles while the oscillator is running. An internal trigger circuit in the reset line is used to deglitch the reset line when the W78L052 is used with an external RC network. The reset logic also has a special glitch removal circuit that ignores glitches on the reset line. During reset, the ports are initialized to FFH, the stack pointer to 07H, PCON (with the exception of bit 4) to 00H, and all of the other SFR registers except SBUF to 00H. SBUF is not reset. -9- Publication Release Date: November 6, 2006 Revision A6 W78LE52/W78L052A 6. ON-CHIP FLASH EPROM CHARACTERISTICS The W78L052 has several modes to program the on-chip Flash EPROM. All these operations are configured by the pins RST, ALE, PSEN , A9CTRL(P3.0), A13CTRL(P3.1), A14CTRL(P3.2), OECTRL(P3.3), CE (P3.6), OE (P3.7), A0(P1.0) and VPP( EA ). Moreover, the A15−A0(P2.7−P2.0, P1.7−P1.0) and the D7−D0(P0.7−P0.0) serve as the address and data bus respectively for these operations. Read Operation This operation is supported for customer to read their code and the Security bits. The data will not be valid if the Lock bit is programmed to low. Output Disable Condition When the OE is set to high, no data output appears on the D7..D0. Program Operation This operation is used to program the data to Flash EPROM and the security bits. Program operation is done when the VPP is reach to VCP (12.5V) level, CE set to low, and OE set to high. Program Verify Operation All the programming data must be checked after program operations. This operation should be performed after each byte is programmed; it will ensure a substantial program margin. Erase Operation An erase operation is the only way to change data from 0 to 1. This operation will erase all the Flash EPROM cells and the security bits from 0 to 1. This erase operation is done when the VPP is reach to VEP level, CE set to low, and OE set to high. - 10 - W78LE52/W78L052A Erase Verify Operation After an erase operation, all of the bytes in the chip must be verified to check whether they have been successfully erased to 1 or not. The erase verify operation automatically ensures a substantial erase margin. This operation will be done after the erase operation if VPP = VEP (14.5V), CE is high and OE is low. PROGRAM/ERASE INHIBIT OPERATION This operation allows parallel erasing or programming of multiple chips with different data. When P3.6( CE ) = VIH, P3.7( OE ) = VIH, erasing or programming of non-targeted chips is inhibited. So, except for the P3.6 and P3.7 pins, the individual chips may have common inputs. P3.6 (ERRO R! OBJEC TS CANN P3.3 P3.2 P3.1 P3.0 OT BE OPERATIONS (A9 (OE CREAT (A14 (A13 ED CTRL) CTRL) CTRL) CTRL) FROM EDITIN G FIELD CODE S.) ERRO R! OBJEC TS CANN OT BE P3.7 CREAT P2, P1 ED (A15..A0) FROM OE ( ) EDITIN G FIELD CODE S. P0 (D7..D0) NOTE (VPP) Read 0 0 0 0 0 0 1 Address Data Out Output Disable 0 0 0 0 0 1 1 X Hi-Z Program 0 0 0 0 0 1 VCP Address Data In Program Verify 0 0 0 0 1 0 VCP Address Data Out @3 Erase 1 0 0 0 0 1 VEP A0: 0, others: X Data In 0FFH @4 Erase Verify 1 0 0 0 1 0 VEP Address Data Out @5 Program/Erase Inhibit X 0 0 0 1 1 VCP/ VEP X X Notes: 1. All these operations happen in RST = VIH, ALE = VIL and PSEN = VIH. 2. VCP = 12.5V, VEP = 14.5V, VIH = VDD, VIL = Vss. 3. The program verify operation follows behind the program operation. 4. This erase operation will erase all the on-chip Flash EPROM cells and the Security bits. 5. The erase verify operation follows behind the erase operation. - 11 - Publication Release Date: November 6, 2006 Revision A6 W78LE52/W78L052A 7. SECURITY BITS During the on-chip Flash EPROM operation mode, the Flash EPROM can be programmed and verified repeatedly. Until the code inside the Flash EPROM is confirmed OK, the code can be protected. The protection of Flash EPROM and those operations on it are described below. The W78L052 has a Special Setting Register, the Security Register, which can not be accessed in normal mode. The Security register can only be accessed from the Flash EPROM operation mode. Those bits of the Security Registers can not be changed once they have been programmed from high to low. They can only be reset through erase-all operation. The Security Register is addressed in the Flash EPROM operation mode by address #0FFFFh. D7 D6 D5 D4 D3 D2 D1 D0 B7 Reserved B2 B1 B0 Security Bits 8KB Flash EPROM B0 : Lock bit, logic 0 : active B1 : MOVC inhibit, logic 0 : the MOVC instruction in external memory cannot access the code in internal memory. logic 1 : no restriction. B2 : Encryption logic 0 : the encryption logic enable logic 1 : the encryption logic disable 0000h Program Memory B7 : Osillator Control logic 0 : 1/2 gain logic 1 : Full gain Default 1 for all security bits. Reserved bits must be kept in logic 1. 1FFFh Reserved Security Register 0FFFFh Special Setting Register Lock bit This bit is used to protect the customer's program code in the W78L052. It may be set after the programmer finishes the programming and verifies sequence. Once this bit is set to logic 0, both the Flash EPROM data and Special Setting Registers can not be accessed again. - 12 - W78LE52/W78L052A MOVC Inhibit This bit is used to restrict the accessible region of the MOVC instruction. It can prevent the MOVC instruction in external program memory from reading the internal program code. When this bit is set to logic 0, a MOVC instruction in external program memory space will be able to access code only in the external memory, not in the internal memory. A MOVC instruction in internal program memory space will always be able to access the ROM data in both internal and external memory. If this bit is logic 1, there are no restrictions on the MOVC instruction. Encryption This bit is used to enable/disable the encryption logic for code protection. Once encryption feature is enabled, the data presented on port 0 will be encoded via encryption logic. Only whole chip erase will reset this bit. +5V +5V VDD A0 to A7 P1 VIL P3.0 VIL P3.1 VIL VIL VIL P3.2 P3.3 VIH P3.7 P0 EA/Vpp VIL RST VIH PSEN P2 A0 to A7 VCP ALE P3.6 X'tal1 VDD PGM DATA VIH P1 VIL P3.0 VIL P3.1 VIL VIL P3.2 P3.3 VIH P3.6 VIL P3.7 P0 EA/Vpp X'tal2 X'tal2 Vss Vss Programming Configuration VCP ALE VIL RST VIH PSEN VIH X'tal1 A8 to A15 PGM DATA P2 A8 to A15 Programming Verification 8. ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL MIN. MAX. UNIT VDD−VSS -0.3 +7.0 V Input Voltage VIN VSS -0.3 VDD +0.3 V Operating Temperature TA 0 70 °C Storage Temperature TST -55 +150 °C DC Power Supply Note: Exposure to conditions beyond those listed under Absolute Maximum Ratings may adversely affect the life and reliability of the device. - 13 - Publication Release Date: November 6, 2006 Revision A6 W78LE52/W78L052A 9. DC CHARACTERISTICS VSS = 0V, TA = 25° C, unless otherwise specified. PARAMETER SYM. 2.4 5.5 V - 20 mA No load VDD = 5.5V - 3 mA No load VDD = 2.4V - 6 mA VDD = 5.5V, FOSC = 20 MHz - 1.5 mA VDD = 2.4V, FOSC = 12 MHz - 50 μA VDD = 5.5V, FOSC = 20 MHz - 20 μA VDD = 2.4V, FOSC = 12 MHz IIN1 -50 +10 μA IIN2 -10 +300 μA ILK -10 +10 μA VDD = 5.5V 0V < VIN < VDD ITL [*4] -500 - μA VDD = 5.5V VIN = 2.0V VIL1 0 0.8 V VDD = 4.5V 0 0.5 V VDD = 2.4V 0 0 0 0 2.4 0.8 0.3 0.8 0.6 VDD +0.2 V V V V V VDD = 4.5V VDD = 2.4V VDD = 4.5V VDD = 2.4V VDD = 5.5V 1.4 VDD +0.2 V VDD = 2.4V 3.5 1.7 3.5 1.6 - VDD +0.2 VDD +0.2 VDD +0.2 VDD +0.2 0.45 0.25 0.45 V V V V V V V VDD = 5.5V VDD = 2.4V VDD = 5.5V VDD = 2.4V VDD = 4.5V, IOL = +2 mA VDD = 2.4V, IOL = +1 mA VDD = 4.5V, IOL = +4 mA - 0.25 V VDD = 2.4V, IOL = +2 mA Operating Current IDD Input Current P1, P2, P3, P4 Input Current RST Input Leakage Current P0, EA Logic 1 to 0 Transition Current P1, P2, P3, P4 Input Low Voltage P0, P1, P2, P3, P4, EA Input Low Voltage RST[*1] Input Low Voltage XTAL1 [*3] Input High Voltage P0, P1, P2, P3, P4, EA Input High Voltage RST[*1] Input High Voltage XTAL1 [*3] Output Low Voltage P1, P2, P3, P4 Output Low Voltage P0, ALE, PSEN [*2] TEST CONDITIONS MAX. VDD Power Down Current UNIT MIN. Operating Voltage Idle Current SPECIFICATION IIDLE IPWDN VIL2 VIL3 VIH1 VIH2 VIH3 VOL1 VOL2 - 14 - VDD = 5.5V VIN = 0V or VDD VDD = 5.5V 0 < VIN < VDD W78LE52/W78L052A DC Characteristics, continued PARAMETER Sink Current P1, P2, P3, P4 Sink Current SYM. 4 1.8 8 12 5.4 16 mA mA mA VDD = 4.5V, Vin = 0.45V VDD = 2.4V, Vin = 0.45V VDD = 4.5V, Vin = 0.45V 4.0 9 mA VDD = 2.4V, Vin = 0.45V 2.4 - V VDD = 4.5V, IOH = -100 μA 1.4 - V VDD = 2.4V, IOH = -8 μA 2.4 - V VDD = 4.5V, IOH = -400 μA 1.4 - V VDD = 2.4V, IOH = -200 μA ISR1 -100 -250 μA VDD = 4.5V, Vin = 2.4V ISR2 -10 -8 -30 -14 μA mA VDD = 2.4V, Vin = 1.4V VDD = 4.5V, Vin = 2.4V -1.0 -2.4 mA VDD = 2.4V, Vin = 1.4V ISK1 ISK2 VOH1 VOH2 P0, ALE, PSEN [*2] Source Current P1, P2, P3, P4 Source Current P0, ALE, PSEN TEST CONDITIONS MAX. P1, P2, P3, P4 Output High Voltage UNIT MIN. P0, ALE, PSEN Output High Voltage PECIFICATION Notes: *1. RST pin is a Schmitt trigger input. *2. P0, ALE and /PSEN are tested in the external access mode. *3. XTAL1 is a CMOS input. *4. Pins of P1, P2, P3, P4 can source a transition current when they are being externally driven from 1 to 0. - 15 - Publication Release Date: November 6, 2006 Revision A6 W78LE52/W78L052A 10. AC CHARACTERISTICS The AC specifications are a function of the particular process used to manufacture the part, the ratings of the I/O buffers, the capacitive load, and the internal routing capacitance. Most of the specifications can be expressed in terms of multiple input clock periods (TCP), and actual parts will usually experience less than a ±20 nS variation. The numbers below represent the performance expected from a 0.6micron CMOS process when using 2 and 4 mA output buffers. Clock Input Waveform XTAL1 T CH T CL F OP, PARAMETER TCP SYMBOL MIN. TYP. MAX. UNIT NOTES Operating Speed FOP 0 - 20 MHz 1 Clock Period TCP 50 - - nS 2 Clock High TCH 25 - - nS 3 Clock Low TCL 25 - - nS 3 Notes: 1. The clock may be stopped indefinitely in either state. 2. The TCP specification is used as a reference in other specifications. 3. There are no duty cycle requirements on the XTAL1 input. Program Fetch Cycle PARAMETER SYMBOL MIN. TYP. MAX. UNIT NOTES Address Valid to ALE Low TAAS 1 TCP -Δ - - nS 4 Address Hold from ALE Low TAAH 1 TCP -Δ - - nS 1, 4 ALE Low to PSEN Low TAPL 1 TCP -Δ - - nS 4 PSEN Low to Data Valid TPDA - - 2 TCP nS 2 Data Hold after PSEN High TPDH 0 - 1 TCP nS 3 Data Float after PSEN High TPDZ 0 - 1 TCP nS ALE Pulse Width TALW 2 TCP -Δ 2 TCP - nS 4 PSEN Pulse Width TPSW 3 TCP -Δ 3 TCP - nS 4 Notes: 1. P0.0−P0.7, P2.0−P2.7 remain stable throughout entire memory cycle. 2. Memory access time is 3 TCP. 3. Data have been latched internally prior to PSEN going high. 4. "Δ" (due to buffer driving delay and wire loading) is 20 nS. - 16 - W78LE52/W78L052A Data Read Cycle PARAMETER SYMBOL MIN. TYP. MAX. UNIT NOTES ALE Low to RD Low TDAR 3 TCP -Δ - 3 TCP +Δ nS 1, 2 RD Low to Data Valid TDDA - - 4 TCP nS 1 Data Hold from RD High TDDH 0 - 2 TCP nS Data Float from RD High TDDZ 0 - 2 TCP nS RD Pulse Width TDRD 6 TCP -Δ 6 TCP - nS 2 Notes: 1. Data memory access time is 8 TCP. 2. "Δ" (due to buffer driving delay and wire loading) is 20 nS. Data Write Cycle PARAMETER SYMBOL MIN. TYP. MAX. UNIT ALE Low to WR Low TDAW 3 TCP -Δ - 3 TCP +Δ nS Data Valid to WR Low TDAD 1 TCP -Δ - - nS Data Hold from WR High TDWD 1 TCP -Δ - - nS WR Pulse Width TDWR 6 TCP -Δ 6 TCP - nS Note: "Δ" (due to buffer driving delay and wire loading) is 20 nS. Port Access Cycle PARAMETER SYMBOL MIN. TYP. MAX. UNIT Port Input Setup to ALE Low TPDS 1 TCP - - nS Port Input Hold from ALE Low TPDH 0 - - nS Port Output to ALE TPDA 1 TCP - - nS Note: Ports are read during S5P2, and output data becomes available at the end of S6P2. The timing data are referenced to ALE, since it provides a convenient reference. - 17 - Publication Release Date: November 6, 2006 Revision A6 W78LE52/W78L052A Program Operation PARAMETER SYMBOL MIN. TYP. MAX. UNIT VPP Setup Time TVPS 2.0 - - μS Data Setup Time TDS 2.0 - - μS Data Hold Time TDH 2.0 - - μS Address Setup Time TAS 2.0 - - μS Address Hold Time TAH 0 - - μS CE Program Pulse Width for Program Operation TPWP 290 300 310 μS OECTRL Setup Time TOCS 2.0 - - μS OECTRL Hold Time TOCH 2.0 - - μS OE Setup Time TOES 2.0 - - μS OE High to Output Float TDFP 0 - 130 nS Data Valid from OE TOEV - - 150 nS Note: Flash data can be accessed only in flash mode. The RST pin must pull in VIH status, the ALE pin must pull in VIL status, and the PSEN pin must pull in VIH status. - 18 - W78LE52/W78L052A 11. TIMING WAVEFORMS Program Fetch Cycle S1 S2 S3 S4 S5 S6 S1 S2 S3 S4 S5 S6 XTAL1 TALW ALE TAPL PSEN TPSW TAAS PORT 2 TPDA TAAH TPDH, TPDZ PORT 0 A0-A7 Code Data A0-A7 A0-A7 Code Data A0-A7 Data Read Cycle S4 S5 S6 S1 S2 S3 S4 S5 S6 S1 S2 S3 XTAL1 ALE PSEN PORT 2 A8-A15 DATA A0-A7 PORT 0 T DAR T DDA T DDH, T DDZ RD T DRD - 19 - Publication Release Date: November 6, 2006 Revision A6 W78LE52/W78L052A Timing Waveforms, continued Data Write Cycle S4 S5 S6 S1 S2 S3 S4 S5 S6 S1 S2 XTAL1 ALE PSEN PORT 2 PORT 0 A8-A15 A0-A7 DATA OUT T DWD TDAD WR T DWR T DAW Port Access Cycle S5 S6 S1 XTAL1 ALE TPDS T PDA T PDH DATA OUT PORT INPUT SAMPLE - 20 - S3 W78LE52/W78L052A Timing Waveforms, continued Program Operation Program P2, P1 VIH (A15... A0) VIL P3.6 VIH (CE) VIL P3.3 (OECTRL) VIH P3.7 VIH (OE) VIL P0 (A7... A0) VIH Program Verify Address Stable TPWP TAH TOCS TOCH TOES TDFP TDH Data In D OUT Data Out TDS Vcp TOEV Vpp VIH Address Valid TAS VIL VIL Read Verify TVPS - 21 - Publication Release Date: November 6, 2006 Revision A6 W78LE52/W78L052A 12. TYPICAL APPLICATION CIRCUITS Expanded External Program Memory and Crystal VDD VDD 31 19 10 u CRYSTAL XTAL1 R 18 XTAL2 8.2 K 9 C1 EA RST C2 12 INT0 13 INT1 14 T0 15 T1 1 2 3 4 5 6 7 8 P1.0 P1.1 P1.2 P1.3 P1.4 P1.5 P1.6 P1.7 P0.0 P0.1 P0.2 P0.3 P0.4 P0.5 P0.6 P0.7 39 AD0 38 AD1 37 AD2 36 AD3 35 AD4 34 AD5 33 AD6 32 AD7 AD0 3 AD1 4 AD2 7 AD3 8 AD413 AD514 AD617 AD718 P2.0 P2.1 P2.2 P2.3 P2.4 P2.5 P2.6 P2.7 21 22 23 24 25 26 27 28 A8 A9 A10 A11 A12 A13 A14 A15 GND 1 D0 D1 D2 D3 D4 D5 D6 D7 Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 2 A0 5 A1 6 A2 9 A3 12 A4 15 A5 16 A6 19 A7 OC 11 G 74373 A0 10 A1 9 A2 8 A3 7 A4 6 A5 5 A6 4 A7 3 A8 25 A9 24 A10 21 A11 23 A12 2 A13 26 A14 27 A15 1 A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 A15 11 12 13 15 16 17 18 19 O0 O1 O2 O3 O4 O5 O6 O7 GND20 CE 22 OE RD 17 WR 16 PSEN 29 ALE 30 TXD 11 10 RXD 27512 W78LE52/W78L052A Figure A CRYSTAL C1 C2 R 16 MHz 30P 30P - 20 MHz 15P 15P - Above table shows the reference values for crystal applications (full gain). Note: C1, C2, R components refer to Figure A. - 22 - AD0 AD1 AD2 AD3 AD4 AD5 AD6 AD7 W78LE52/W78L052A Typical Application Circuits, continued Expanded External Data Memory and Oscillator VDD VDD 31 19 10 u OSCILLATOR EA XTAL1 18 XTAL2 8.2 K 9 RST 12 INT0 13 INT1 14 T0 15 T1 1 2 3 4 5 6 7 8 P1.0 P1.1 P1.2 P1.3 P1.4 P1.5 P1.6 P1.7 P0.0 P0.1 P0.2 P0.3 P0.4 P0.5 P0.6 P0.7 39 AD0 38 AD1 37 AD2 36 AD3 35 AD4 34 AD5 33 AD6 32 AD7 AD0 3 AD1 4 AD2 7 AD3 8 AD4 13 AD5 14 AD6 17 AD7 18 P2.0 P2.1 P2.2 P2.3 P2.4 P2.5 P2.6 P2.7 21 22 23 24 25 26 27 28 GND 1 OC 11 G RD WR 17 16 29 30 11 10 PSEN ALE TXD RXD A8 A9 A10 A11 A12 A13 A14 D0 D1 D2 D3 D4 D5 D6 D7 Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 74373 2 5 6 9 12 15 16 19 A0 A1 A2 A3 A4 A5 A6 A7 A0 10 A1 9 A2 8 A3 7 A4 6 A5 5 A6 4 A7 3 A8 25 A9 24 A10 21 A11 23 A12 2 A13 26 A14 1 A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 GND20 22 27 CE OE D0 D1 D2 D3 D4 D5 D6 D7 11 12 13 15 16 17 18 19 AD0 AD1 AD2 AD3 AD4 AD5 AD6 AD7 WR 20256 W78LE52/W78L052A Figure B - 23 - Publication Release Date: November 6, 2006 Revision A6 W78LE52/W78L052A 13. PACKAGE DIMENSIONS 40-pin DIP Symbol A A1 A2 B B1 c D E E1 e1 L D 40 21 E1 a eA S 20 1 Dimension in inch Dimension in mm Min. Nom. Max. Min. Nom. Max. 5.334 0.210 0.010 0.254 0.150 0.155 0.160 3.81 3.937 4.064 0.016 0.018 0.022 0.406 0.457 0.559 0.048 0.050 0.054 1.219 1.27 1.372 0.008 0.010 0.014 0.203 0.254 0.356 52.58 0.590 2.055 2.070 52.20 0.600 0.610 14.986 15.24 15.494 0.540 0.545 0.550 13.72 13.84 13.97 0.090 0.100 0.110 2.286 2.54 2.794 0.120 0.130 0.140 3.048 3.302 3.556 15 0 0.670 16.00 16.51 17.01 0 0.630 0.650 15 0.090 2.286 Notes: E S c A A2 A1 Base Plane Seating Plane L B e1 eA a B1 1. Dimension D Max. & S include mold flash or tie bar burrs. 2. Dimension E1 does not include interlead flash. 3. Dimension D & E1 include mold mismatch and . parting line. are determined at the mold 4. Dimension B1 does not include dambar protrusion/intrusion. 5. Controlling dimension: Inches. 6. General appearance spec. should be based on final visual inspection spec. 44-pin PLCC HD D 6 1 44 40 Symbol Dimension in inch Dimension in mm Min. Nom. Max. Min. Nom. Max. 39 7 E 17 HE GE 29 18 28 c A A1 A2 b1 b c D E e GD GE HD HE L y 0.185 4.699 0.508 0.020 0.145 0.150 0.155 3.683 3.81 3.937 0.026 0.028 0.032 0.66 0.711 0.813 0.016 0.018 0.022 0.406 0.457 0.559 0.008 0.010 0.014 0.203 0.254 0.356 0.648 0.653 0.658 16.46 16.59 16.71 0.648 0.653 0.658 16.46 16.59 16.71 0.050 BSC 1.27 BSC 0.590 0.610 0.630 14.99 15.49 16.00 0.590 0.610 0.630 14.99 15.49 16.00 0.680 0.690 0.700 17.27 17.53 17.78 0.680 0.690 0.700 17.27 17.53 17.78 0.090 0.100 0.110 2.296 2.54 2.794 0.004 0.10 L Notes: A2 A 1. Dimension D & E do not include interlead flash. 2. Dimension b1 does not include dambar protrusion/intrusion. 3. Controlling dimension: Inches 4. General appearance spec. should be based on final visual inspection spec. θ e b b1 Seating Plane A1 y GD - 24 - W78LE52/W78L052A Package Dimensions, continued 44-pin PQFP HD Dimension in inch Dimension in mm D Symbol Min. Nom. Max. Min. Nom. Max. 34 44 A A1 A2 b c D E e HD HE L L1 y θ 33 1 E HE 11 12 e b 22 --- --- --- --- 0.002 0.01 0.02 0.05 0.25 0.5 0.075 0.081 0.087 1.90 2.05 2.20 0.01 0.35 0.45 --- 0.014 0.018 0.25 --- 0.004 0.006 0.010 0.101 0.152 0.254 0.390 0.394 0.398 9.9 10.00 10.1 0.390 0.394 0.398 9.9 10.00 10.1 0.025 0.031 0.036 0.635 0.80 0.952 0.510 0.520 0.530 12.95 13.2 13.45 0.510 0.520 0.530 12.95 13.2 13.45 0.65 0.8 0.95 0.051 0.063 0.075 1.295 1.6 1.905 0.025 0.031 0.037 0.08 0.003 0 7 0 7 Notes: 1. Dimension D & E do not include interlead flash. 2. Dimension b does not include dambar protrusion/intrusion. 3. Controlling dimension: Millimeter 4. General appearance spec. should be base on final visual inspection spec. c A2 A Seating Plane See Detail F A1 y θ L L1 Detail F - 25 - Publication Release Date: November 6, 2006 Revision A6 W78LE52/W78L052A 14. REVISION HISTORY VERSION DATE PAGE REASONS FOR CHANGE A3 December 2000 A4 April 19, 2005 25 Add Important Notice A5 June 14, 2005 2 Add Lead Free (RoHS) parts - Remove block diagram A6 November 6, 2006 2 Remove all Leaded parts 16 Revise Operating speed to 20MHz Important Notice Winbond products are not designed, intended, authorized or warranted for use as components in systems or equipment intended for surgical implantation, atomic energy control instruments, airplane or spaceship instruments, transportation instruments, traffic signal instruments, combustion control instruments, or for other applications intended to support or sustain life. Further more, Winbond products are not intended for applications wherein failure of Winbond products could result or lead to a situation wherein personal injury, death or severe property or environmental damage could occur. Winbond customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Winbond for any damages resulting from such improper use or sales. - 26 -
W78L052A24FL
物料型号: W78LE52/W78L052A
器件简介: - W78L052是一款8位微控制器,兼容标准8051指令集。 - 包含8KB Flash EPROM、256字节RAM。 - 具有四个8位双向I/O端口、额外的4位I/O端口P4。 - 包含三个16位定时器/计数器、硬件看门狗定时器和串行端口。 - 支持双级中断,具有两种省电模式:空闲模式和掉电模式。
引脚分配: - 40引脚DIP、44引脚PLCC和44引脚QFP封装。 - 提供了多种I/O端口和特殊功能引脚,如EA(外部访问使能)、PSEN(程序存储使能)、ALE(地址锁存使能)、RST(复位)等。
参数特性: - 工作电压范围宽,2.4V至5.5V。 - 具有256字节片上RAM和8KB可擦写/可编程Flash EPROM。 - 支持64KB程序存储空间和64KB数据存储空间。
功能详解: - 包括定时器/计数器、串行端口、看门狗定时器、中断控制等功能。 - 特别提到了Timer 2的特殊功能,它是一个16位定时器/计数器,具有捕获、自动重载和波特率生成器模式。
应用信息: - 提供了典型应用电路图,包括扩展外部程序存储器和晶振的连接方式。
封装信息: - 提供了40引脚DIP、44引脚PLCC和44引脚QFP封装的详细尺寸信息。
W78L052A24FL 价格&库存
很抱歉,暂时无法提供与“W78L052A24FL”相匹配的价格&库存,您可以联系我们找货
