RC14KB2K70
RC14KB2K70
    SEI
    轴向
    插件电阻 - 2.7KΩ ±10% 1/4W -
RC14KB2K70 数据手册
RC Series Stackpole Electronics, Inc. Carbon Composition Resistor Resistive Product Solutions Features: • • • • • • • Non-inductive design Molded body for package uniformity Ideal for pulse-load handling characteristics 100% RoHS compliant and lead free without exemption Halogen free REACH compliant 5% TOLERANCES WILL NO LONGER BE AVAILABLE AFTER 2/28/2022. SEE PDN HERE. Electrical Specifications Maximum Maximum Power Rating Dielectric Withstanding Continuous Type/Code Pulse Voltage (W) @ 70ºC Voltage (V) (V) Working Voltage (V) (1) RC14 0.25 250 400 500 RC12 0.5 350 700 700 √ P*R or maximum working voltage. `(1) Lesser of Ohmic Range (Ω) and Tolerance 5%(2) 2.2 - 91K 1 - 91K 10% 1 - 5.6M 1 - 22M (2) EOL for 5% tolerances; last time order date 2/28/2022. Mechanical Specifications Type/Code RC14 RC12 A Body Length 0.248 ± 0.028 6.30 ± 0.70 0.374 ± 0.031 9.50 ± 0.80 B Body Diameter 0.094 ± 0.004 2.40 ± 0.10 0.142 ± 0.008 3.60 ± 0.20 C Lead Length (Bulk) 1.181 ± 0.118 30.00 ± 3.00 1.102 ± 0.118 28.00 ± 3.00 D Lead Diameter 0.024 ± 0.002 0.60 ± 0.05 0.028 ± 0.003 0.70 ± 0.07 Unit inches mm inches mm Performance Characteristics Test Test Results Voltage Proof No breakdown or flashover Overload Termination Strength Solderability Resistance to Soldering Heat Temperature Shock Climatic Sequence Damp Test, Steady State Endurance @ 70ºC ±2% +0.05Ω No visible damage, legible markings Tensile: ±2% +0.05Ω. No visible damage Bending: ±2% +0.05Ω. No visible damage Torsion: ±2% +0.05Ω. No visible damage In accordance with Clause 4.17.4.5 ±3% +0.05Ω No visible damage, legible markings ±2% +0.05Ω No visible damage. ±10% +0.5Ω Insulation resistance: R ≥100M ohm. No visible damage, legible markings ±10% +0.5Ω Insulation resistance: R ≥1G ohm. No visible damage. This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. After immersion into flux, the immersion into solder shall be carried out 4mm from the body at 350ºC for 3.5 seconds 5 cycles between -55ºC to 125ºC Dry/Damp heat: 12 +12 hour cycle, first cycle Cold/Damp heat: 12 + 12 hour cycle, remaining cycle D.C. load ±10% +0.5Ω Rev Date: 9/15/2021 Test Method V-block method RC 1/4 100 VAC, 60 seconds RC 1/2 500 VAC, 60 seconds 2.5 times the rated voltage or twice the limiting element voltage, whichever is less. Severe, 5 seconds. 10N for 5 - 10 seconds 5N, twice 180ºC, two rotations 235ºC, 5 seconds 1 40ºC 95% relative humidity for 56 days, test a, b and c of Clause 4.24.2.1 Rated voltage, 1.5 hours ON, 0.5 hours OFF at 70ºC, 1000 hours www.seielect.com marketing@seielect.com RC Series Stackpole Electronics, Inc. Carbon Composition Resistor Resistive Product Solutions Performance Characteristics (cont.) Test Test Results ±10% +0.5Ω Endurance @ 125ºC Insulation resistance: R ≥1G ohm. No visible damage. Operating Temperature Range: -55ºC to +125ºC Test Method 125ºC, no load, 1000 hours Power Derating Curve: Reliability Test – Load Life in Moisture Criteria (%) ∆ R/R ±5 ±10 Load Ratio P/Pn (%) Total Testing Time (Hrs) Number of Fractures (pcs) ƛ Failure Ratio ƛCL (60%) Average Lifetime (60% reliability level) (Hrs) 0 2.984 x 106 6 0.201 0.244 4.098 x 105 20 2.990 x 106 4 0.134 0.176 5.682 x 105 60 6 2.997 x 10 2 0.067 0.104 9.615 x 105 100 2.992 x 106 3 0.1 0.139 7.194 x 105 Total 1.196 x 107 15 0.125 0.138 7.209 x 105 Total 1.2 x 107 0 0.0055 0.0077 1.299 x 107 Resistance Temperature Characteristics Resistance Range Under 1K 1K to 9.1K 10K to 91K 100K 100K to 910K 1M to 10M -55ºC +2 to + 5 +5 to +9 +8 to +11 +10 to +14 +10 to +14 +13 to +20 Rev Date: 9/15/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. +105ºC -4 to -2 -5 to -3 -7 to -5 -9 to -7 -9 to -7 -14 to -9 2 Maximum % resistance change from room temperature (+25ºC) value www.seielect.com marketing@seielect.com RC Series Stackpole Electronics, Inc. Carbon Composition Resistor Resistive Product Solutions Temperature Rise Rev Date: 9/15/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com RC Series Stackpole Electronics, Inc. Carbon Composition Resistor Resistive Product Solutions Single Pulse Power Capability Rev Date: 9/15/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com RC Series Stackpole Electronics, Inc. Carbon Composition Resistor Resistive Product Solutions Continuous Pulse Circuit 100 Pulse Data E: 10kV; C1: 1000pF; R1: 1KΩ; R2: 4MΩ; X: Sample: RS: 15MΩ; 100 times pulse. 4 Continuous Pulse Capability Rev Date: 9/15/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com RC Series Stackpole Electronics, Inc. Carbon Composition Resistor Resistive Product Solutions Impedance x Frequency Equipment: HP4291A Impedance/Material Analyzer Rev Date: 9/15/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 6 www.seielect.com marketing@seielect.com RC Series Stackpole Electronics, Inc. Carbon Composition Resistor Resistive Product Solutions Current Noise Current Noise Data (Q.T.L.) Rev Date: 9/15/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 7 www.seielect.com marketing@seielect.com RC Series Stackpole Electronics, Inc. Carbon Composition Resistor Resistive Product Solutions Characteristic Data Impressing Electric Power (W) 0.125 0.250 0.375 Surface Temperature (°C) 40.7 53.6 66.8 Impressing Electric Power (W) 0.25 0.50 0.75 Surface Temperature (°C) 52.3 68.5 85.6 Rev Date: 9/15/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 8 www.seielect.com marketing@seielect.com RC Series Stackpole Electronics, Inc. Carbon Composition Resistor Resistive Product Solutions Measurement Condition: Technical Guide: 1. Storage Conditions: Temperature: 5 to 35ºC (40 to 95ºF). Humidity: 25 – 60% relative humidity. Term: One year in poly-bag with desiccant. If parts are removed from the poly-bag, they should be used immediately or resealed in the bag. Environment: Clean, dry environment, free of corrosive gases. 2. Application precautions: Lead forming: Forming is recommended at least 2mm of farther from the base of the lead. Soldering: Soldering is recommended at least 4mm or farther from the base of the lead. 3. Washing: Carbon composition resistors are highly hygroscopic and changes in resistance value can occur if too much moisture is absorbed. For this reason, it is recommended not to use water or water-soluble solvents to clean these components. Alcohol or hydrocarbon solvents are recommended for rinsing. 4. Soldering Recommendations: Note: The conditions shown below are for reference. Please perform a mounting evaluation to assure compatibility. a. Flow soldering (recommended profile for Sn and Sn/Pb solders). Rev Date: 9/15/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 9 www.seielect.com marketing@seielect.com RC Series Stackpole Electronics, Inc. Carbon Composition Resistor Resistive Product Solutions b. Soldering iron (recommended for Sn and Sn/Pb solders): Temperature of soldering tip: 300ºC, duration: 10 sec. max. Temperature of soldering tip: 350ºC, duration: 3 sec. max. Other: 1. Evaluate and confirm the compatibility of your assembly process with this product. 2. Refer to the catalog, the product news, and the specifications for details on the RC series resistors. 3. If you have any questions, please contact our sales staff. Packaging Specifications Type / Code RC14 RC12 A max. B max 2.787 70.80 2.756 70.00 13.504 343.00 13.504 343.00 C 0.394 10.00 0.394 10.00 ± ± ± ± D 0.020 0.50 0.020 0.50 2.063 52.40 2.063 52.40 ± ± ± ± 0.079 2.00 0.079 2.00 Tape Unit 0.250 6.35 0.250 6.35 inches mm inches mm RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series RC Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) Carbon Composition Leaded Resistor Axial YES 100% Matte Sn Jan-86 86/01 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Rev Date: 9/15/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 10 www.seielect.com marketing@seielect.com RC Series Stackpole Electronics, Inc. Carbon Composition Resistor Resistive Product Solutions Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order RC 1 2 3 4 5 6 7 8 9 10 R C 1 4 F T 1 0 R 0 Product Series Carbon Comp Size Code W 0.25 14 12 0.5 Code J(*) K Tolerance Tol Value 5% E24 10% Code T B Packaging Description Size Quantity Tape and Reel 5000 All Sizes Bulk 1000 (*) EOL for 5% tolerances; last time order date 2/28/2022. Rev Date: 9/15/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 11 Resistance Value Four characters with the multiplier used as the decimal holder. 1 ohm = 1R00 10 Kohm = 10K0 1 Mohm = 1M00 www.seielect.com marketing@seielect.com
RC14KB2K70 价格&库存
很抱歉,暂时无法提供与“RC14KB2K70”相匹配的价格&库存,您可以联系我们找货
