VM5JBR510
VM5JBR510
    SEI
    WR-13X9.5MM_TM
    插件电阻 - 510mΩ ±5% 5W ±800ppm/℃
VM5JBR510 数据手册
VM / MVM Series Stackpole Electronics, Inc. Ceramic Housed Vertical Mount Resistor Resistive Product Solutions Features: • • • • • • • Flameproof inorganic construction High temperature potting compound VM – Wirewound element MVM – Metal oxide element for higher values 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical Specifications Power Rating (W) @ 70ºC Type / Code Voltage Rating (V) TCR (ppm/°C) Ohmic Range (Ω) and Tolerance 5% VM2 2 250 VM3 3 300 < 1 Ω = ± 800 ppm/ºC VM5 5 350 > 1 Ω = ± 300 ppm/ºC VM7 7 500 VM10 10 700 MVM2 2 250 MVM3 3 300 ± 200 ppm/ºC MVM5 5 350 MVM7 7 500 MVM10 10 700 Maximum Working Voltage is limited by √ P*R unless specified otherwise. 10% 0.056 - 100 0.1 - 100 0.1 - 100 0.39 - 470 0.56 - 680 0.1 - 51K 0.1 - 51K 0.1 - 51K 510 - 51K 750 - 51K - Mechanical Specifications VM: Type / Code VM2 / MVM2 VM3 / MVM3 VM5 / MVM5 VM7 / MVM7 VM10 / MVM10 MVM: A 0.276 7.00 0.335 8.50 0.374 9.50 0.374 9.50 0.472 12.00 ± ± ± ± ± ± ± ± ± ± B 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.807 20.50 0.984 25.00 0.984 25.00 1.535 39.00 1.378 35.00 ± ± ± ± ± ± ± ± ± ± C 0.039 1.00 0.039 1.00 0.039 1.00 0.059 1.50 0.039 1.00 Rev Date: 3/16/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 0.433 11.00 0.492 12.50 0.512 13.00 0.512 13.00 0.630 16.00 ± ± ± ± ± ± ± ± ± ± 1 D 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.295 7.50 ± ± ± ± ± ± ± ± ± ± Lead Diameter 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.031 0.80 0.031 0.80 0.031 0.80 0.031 0.80 0.031 0.80 ± ± ± ± ± ± ± ± ± ± 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 Lead Length 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 ± ± ± ± ± ± ± ± ± ± 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 Unit inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com VM / MVM Series Stackpole Electronics, Inc. Ceramic Housed Vertical Mount Resistor Resistive Product Solutions Performance Characteristics Test Moisture Resistance Thermal Shock Load Life @ 70C - 1000 hours Resistance to Soldering Heat Short Time Overload - 5 X Pn for 5 seconds Dielectric Withstanding Voltage Operational temperature range is -55°C to 275°C for VM and -55°C to 150°C for MVM. Test Results ± 5% ± 2% ± 5% ± 2% ± 2% ± 2% Power Derating Curve: Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Rev Date: 3/16/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 2 Minimum 60 seconds 100°C 240°C * N/A www.seielect.com marketing@seielect.com VM / MVM Series Stackpole Electronics, Inc. Ceramic Housed Vertical Mount Resistor Resistive Product Solutions Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Recommended Lead Free Resistor Reflow Profile RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series VM MVM Description Ceramic Housed Vertical Mount Wirewound Resistor (Standard WW) Ceramic Housed Vertical Mount Wirewound Resistor (Metal Oxide) Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) Radial YES 100% Matte Sn Jan-06 06/01 Radial YES 100% Matte Sn Jan-06 06/01 Rev Date: 3/16/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com VM / MVM Series Stackpole Electronics, Inc. Ceramic Housed Vertical Mount Resistor Resistive Product Solutions “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the Eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order V Product Series VM Standard WW MVM Metal Oxide M Power Rating Size W 2 2 3 3 5 5 7 7 10 10 3 Tolerance Code Tol J 5% K 10% Rev Date: 3/16/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. J B 2 R Packaging Code Description Size VM2, MVM2 VM3, MVM3 B Bulk VM5, MVM5 VM7, MVM7 VM10, MVM10 4 2 Quantity 1500 800 600 0 Resistance Value Four characters with the multiplier used as the decimal holder. "L" used as multiplier of 10-3 for any value under 0.1 ohm. 0.056 ohm = 56L0 0.1 ohm = R100 680 ohm = 680R 51 Kohm = 51K0 www.seielect.com marketing@seielect.com
VM5JBR510
物料型号:VM / MVM系列
器件简介:这些电阻器具有防火无机构造和高温灌封化合物,VM系列采用线绕元件,MVM系列采用金属氧化物元件以实现更高值。它们完全符合RoHS标准,无铅且不含卤素,符合REACH标准。
引脚分配:文档中提供了不同型号的引脚直径和引脚长度的详细尺寸,以英寸和毫米为单位。
参数特性:包括功率额定值、电压额定值、温度系数、欧姆范围和公差等电气规格。
功能详解:文档描述了电阻器的耐湿性、热冲击、负载寿命、耐焊热性、短时间过载和介质耐压等性能特性。
应用信息:操作温度范围为VM系列-55°C至275°C,MVM系列-55°C至150°C。还提供了功率降额曲线和推荐的焊接温度曲线。
封装信息:提供了机械规格,包括不同类型的A、B、C、D尺寸以及引脚直径和长度。
VM5JBR510 价格&库存
很抱歉,暂时无法提供与“VM5JBR510”相匹配的价格&库存,您可以联系我们找货
VM5JBR510
  • 1500+1.432701500+0.18378
