ASRM1JA220K
ASRM1JA220K
    SEI
    AXIAL_D4X11MM_TM
    插件电阻 - 220KΩ ±5% 1W 0~-1800ppm/℃
ASRM1JA220K 数据手册
ASR / ASRM Series Stackpole Electronics, Inc. Anti-Surge Resistor Resistive Product Solutions Features: • • • • • • • • Excellent anti-surge characteristics Stable characteristics through the resistance range Good alternative to carbon composition resistors Applications include power supplies, CRT’s, and anti-surge circuits Cut and formed product is available on select sizes; contact Stackpole for details Flameproof coating per UL94 V-0 RoHS compliant, lead free and halogen free REACH compliant Electrical Specifications - ASR Type/Code ASR14 Maximum Power Rating (W) Working Voltage(1) @ 70ºC (V) DC 1600 0.25 AC 1150 ASR1 1 4000 Maximum Overload Voltage (V) DC 2000 AC 1500 Dielectric Withstand Voltage (VAC) 5000 500 400 Surge Withstanding(2) (V) 1000 3000 5000 10000 Ohmic Range (Ω) and Tolerance 5% 3.3 - 510K 560K - 12M 3.3 - 510K 560K - 12M (1) Lesser of √ P*R or maximum working voltage. (2) 10 discharges from a 0.01 µF capacitor every 5 seconds. Electrical Specifications - ASRM Maximum Overload Voltage (V) Dielectric Withstand Voltage (VAC) Surge (2) Withstanding (V) Ohmic Range (Ω) and Tolerance 5% 2000 100K - 22M 5000 10000 5000 10000 5000 10000 3.3 - 510K 560K - 12M 3.3 - 510K 560K - 12M 3.3 - 510K 560K - 12M Type/Code Power Rating (W) @ 70ºC Maximum Working Voltage(1) (V) ASRM14 0.25 500 1000 200 ASRM12 0.5 2000 2500 500 ASRM1 1 4000 5000 500 ASRM2 2 4000 5000 500 (1) Lesser of √ P*R or maximum working voltage. (2) 10 discharges from a 0.01 µF capacitor every 5 seconds. Mechanical Specifications - ASR Type/Code Weight (mg / pc) ASR14 210 ASR1 1340 A Body Length 0.236 ± 0.012 6.00 ± 0.30 0.591 ± 0.039 15.00 ± 1.00 Rev Date: 12/13/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. B Body Diameter 0.091 ± 0.008 2.30 ± 0.20 0.197 ± 0.020 5.00 ± 0.50 1 C Lead Length (Bulk) 1.102 ± 0.118 28.00 ± 3.00 1.378 ± 0.118 35.00 ± 3.00 D Lead Diameter 0.022 ± 0.002 0.55 ± 0.05 0.031 ± 0.002 0.80 ± 0.05 Unit inches mm inches mm www.seielect.com marketing@seielect.com ASR / ASRM Series Stackpole Electronics, Inc. Anti-Surge Resistor Resistive Product Solutions Mechanical Specifications - ASRM Type/Code Weight (mg/pc) ASRM14 110 ASRM12 330 ASRM1 570 ASRM2 1340 A Body Length 0.126 ± 0.008 3.20 ± 0.20 0.354 ± 0.039 9.00 ± 1.00 0.433 ± 0.039 11.00 ± 1.00 0.591 ± 0.039 15.00 ± 1.00 B Body Diameter 0.073 ± 0.008 1.85 ± 0.20 0.118 ± 0.020 3.00 ± 0.50 0.157 ± 0.020 4.00 ± 0.50 0.197 ± 0.020 5.00 ± 0.50 C Lead Length (Bulk) 1.102 ± 0.118 28.00 ± 3.00 1.102 ± 0.118 28.00 ± 3.00 1.102 ± 0.118 28.00 ± 3.00 1.378 ± 0.118 35.00 ± 3.00 D Lead Diameter 0.018 ± 0.002 0.45 ± 0.05 0.028 ± 0.002 0.70 ± 0.05 0.031 ± 0.002 0.80 ± 0.05 0.031 ± 0.002 0.80 ± 0.05 Unit inches mm inches mm inches mm inches mm Performance Characteristics Test Test Specification ASRM14: ± 200 ppm/ºC Temperature Coefficient of Resistance Voltage Proof Insulation Resistance Solvent Resistance Overload (Short Time) Robustness of Terminations Test Condition Measure resistance (R0) at room temperature (t), after that, measure again the resistance (R) at 100ºC higher than room temperature All Other Sizes: - 1800 ~ 0 ppm/ºC TCR = Change of resistance ≤ ± (0.5% + 0.05 Ω) No mechanical damage R - R0 R3 x 106 (t +100) - t (ppm/ºC) Lay the resistor on the 90º angle metal V block and apply rated AC voltage for one minute Lay the resistor on the 90º angle metal V block and apply 100 Vdc between V block and lead wire for a minute. The insulation resistance will be measured while applying the voltage. Soak in a Isopropyl alcohol for 5 minutes. After drying up for 5 minutes, the There will be no damage stress of 5 N is added with the absorbent cotton. Five round trips at the rate of on the insulating surface one round trip a second. Apply 2.5 times rated voltage or max overload voltage whichever is lower for ≤ ± (1% + 0.05 Ω) 5 seconds and leave in room temperature for one hour after test. Tensile: The body of the resistor is fixed, a static load is added in the direction of drawing out of the terminal, and it maintains it for 10 ± 1 seconds. Tensile strength: 10 N Bend: Change of resistance ≤ ± (0.5% + 0.05 Ω) Component body will be fixed so that terminals are perpendicular to the floor. A static load specified below shall be applied to the terminal acting in a direction away from the body. The body of piezoelectric oscillator will be inclined through an angle of 90ºC and then retuned to its initial position in 2 or 3 seconds ≥ 1000 Mohm Resistance to Soldering Heat Change of resistance ≤ ± (1% + 0.05 Ω) Solderability More than 95% of the surface of the lead will be covered by new solder Rev Date: 12/13/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. Bending strength: 5 N Dip the lead into a solder bath having a temperature of 260ºC ± 5ºC up to 1.5 ± 0.5 mm from the body of the resistors and hold it for 10 ± 0.5 seconds and leave in room temperature for one hour after test. Dip the lead into a solder bath having a temperature of 245ºC ± 5ºC up to 1.5 ± 0.5 mm from the body of the resistors and hold it for 5 ± 0.5 seconds. 2 www.seielect.com marketing@seielect.com ASR / ASRM Series Stackpole Electronics, Inc. Anti-Surge Resistor Resistive Product Solutions Performance Characteristics (cont.) Test Test Specification Rapid Change of Temperature Change of resistance ≤ ± (1% + 0.05 Ω) Vibration Change of resistance ≤ ± (1% + 0.05 Ω) Damp Heat, Steady State Change of resistance ≤ ± (5% + 0.05 Ω) Change of resistance ≤ ± (5% + 0.05 Ω) Operating temperature range is - 55°C to + 155°C Endurance at 70ºC Test Condition The resistor shall be subjected to 5 continuous cycle, each as shown in the table below: Apply 1.5 mm amplitude vibration to three directions perpendicular to each other 2 hours each, total 6 hours. Vibrating frequency is 10 Hz - 55 Hz - 10 Hz cycle in 1 minute sweeping and repeat cycle In the chamber having temperature of 40 ± 2ºC and relative humidity of 93 ± 3%, apply one percent of the rated power, 1.5 hour ON, 0.5 hour OFF for 1000 hours and leave in room temperature for one hour after test. At 70 ± 2ºC, apply rated DC voltage 1.5 ON, 0.5 hour OFF for 1000 hours and leave in room temperature for one hour after test. Anti-Surge Characteristics Test Anti-Surge Characteristics 1 Anti-Surge Characteristics 2 Test Specification Change of resistance ≤ ± (10% + 0.05 Ω) Change of resistance ≤ ± (5% + 0.05 Ω) Test Condition Discharge from 0.01 µF capacitor for 10 times every 5 seconds. The discharge voltage is shown in Surge Withstanding Voltage table. Discharge from 1 nF capacitor for 50 times every 5 seconds. The discharge voltage is shown in Surge Withstanding Voltage table. Surge Withstanding Voltage - ASR Resistance Range (Ω) 3.3 - 510K ASR14 560K - 33M 3.3 - 510K ASR1 560K - 100M Reference standards: JIS C 5201-1, IEC60115-1, IEC60065, UL1676 Type/Code Surge Withstanding (KV) 1 3 5 10 Surge Withstanding Voltage - ASRM Type/Code Resistance Range (Ω) ASRM14 100K - 22M 3.3 - 510K ASRM12 560K - 33M 3.3 - 510K ASRM1 560K - 100M 3.3 - 510K ASRM2 560K - 100M Reference standards: JIS C 5201-1, IEC60115-1, IEC60065, UL1676 Rev Date: 12/13/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 Surge Withstanding (KV) 2 5 10 5 10 5 10 www.seielect.com marketing@seielect.com ASR / ASRM Series Stackpole Electronics, Inc. Anti-Surge Resistor Resistive Product Solutions Power Derating Curve: Heat Rise: Pulse Limiting Power (single square shaped pulse): Rev Date: 12/13/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com ASR / ASRM Series Stackpole Electronics, Inc. Anti-Surge Resistor Resistive Product Solutions Repetitive Pulse Information If repetitive pulses are applied to resistors, pulse wave form must be less than “Pulse limiting voltage”, “Pulse limiting current” or “Pulse limiting wattage” calculated by the formula below. Vp = K√P x R x T/t lp = K√P/R x T/t Pp = K2 x P x T/t Where: Vp: lp: Pp: P: R: T: t: K: [Vr: Note 1: Note 2: Note 3: Note 4: Note 5: Note 6: Pulse limiting voltage (V) Pulse limiting current (A) Pulse limiting wattage (W) Power rating (W) Nominal resistance (ohm) Repetitive period (sec) Pulse duration (sec) Coefficient: 1 Rated Voltage (V), Ir: Rated Current (A)] If T > 10 → T = 10 (sec), T / t > 1000 → T / t = 1000. If T > 10 and T / t > 1000, “Pulse Limiting power (Single pulse) is applied. If Vp < Vr (lp < lr or Pp < P), Vr (lr, P) is Vp (lp, Pp). Pulse limiting voltage (Current, Wattage) is applied at less than rated ambient temperature. If ambient temperature is more than the rated temperature (70°C), please decrease power rating according to “Power Derating Curve”. Please assure sufficient margin for use period and conditions for “Pulse limiting voltage”. If the pulse waveform is not square wave, please judge after transform the waveform into square wave according to “Waveform Transformation to Square Wave” information. Rev Date: 12/13/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com ASR / ASRM Series Stackpole Electronics, Inc. Anti-Surge Resistor Resistive Product Solutions Waveform Transformation to Square Wave 1. Discharge curve wave with time constant “t” → Square wave 2. Damping oscillation wave with time constant of envelope “t” → Square wave 3. Half-wave rectification wave → Square wave 4. Triangular wave → Square wave 5. Special wave → Square wave Rev Date: 12/13/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 6 www.seielect.com marketing@seielect.com ASR / ASRM Series Stackpole Electronics, Inc. Anti-Surge Resistor Resistive Product Solutions Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Minimum 60 seconds 100°C 240°C * N/A Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Recommended Lead Free Resistor Reflow Profile Rev Date: 12/13/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 7 www.seielect.com marketing@seielect.com ASR / ASRM Series Stackpole Electronics, Inc. Anti-Surge Resistor Resistive Product Solutions Packaging Specifications – Tape and Reel Reeled in accordance with EIA-296-F Series Size (W) 1/4 ASR 1 1/4 1/2 ASRM 1 2 .(1) B max A max 2.756 70.00 3.189 81.00 2.756 70.00 2.756 70.00 2.756 70.00 3.189 81.00 ± ± ± ± ± ± ± ± ± ± ± ± 0.118 3.00 0.118 3.00 0.118 3.00 0.118 3.00 0.118 3.00 0.118 3.00 11.811 300.00 11.811 300.00 11.811 300.00 11.811 300.00 11.811 300.00 11.811 300.00 ± ± ± ± ± ± ± ± ± ± ± ± (2) C 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.197 5.00 0.394 10.00 0.197 5.00 0.197 5.00 0.197 5.00 0.394 10.00 ± ± ± ± ± ± ± ± ± ± ± ± 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 2.047 52.00 2.480 63.00 2.047 52.00 2.047 52.00 2.047 52.00 2.480 63.00 D +0.079/-0.039 +2.00/-1.00 +0.079/-0.039 +2.00/-1.00 +0.079/-0.039 +2.00/-1.00 +0.079/-0.039 +2.00/-1.00 +0.079/-0.039 +2.00/-1.00 +0.079/-0.039 +2.00/-1.00 Tape Unit 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 0.250 6.35 inches mm inches mm inches mm inches mm inches mm inches mm Dimension "E": This is a non-critical dimension that does not have a tolerance in the standard. Range of diameters is from 0.547 inches (13.90 mm) to 1.500 inches (38.10 mm). (1) Reference value only. The "A" dimension shall be governed by the overall length of the taped component. The distance between flanges shall be 0.059 inches (1.50 mm) to 0.315 (8.00 mm) greater than the overall component. (2) The given dimension "D" expresses the standard width spacing. A 26mm narrow spacing is available as option "N" packaging code. Taping Specifications – Ammo Series ASR/ASRM All sizes (except ASR1, ASRM2) ASR1, ASRM2 C 0.197 5.00 0.394 10.00 ± ± ± ± 0.020 0.50 0.020 0.50 Rev Date: 12/13/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2.047 52.00 2.047 52.00 8 D Tape Unit +0.079/-0.039 +2.00/-1.00 +0.079/-0.039 +2.00/-1.00 0.250 6.35 0.250 6.35 inches mm inches mm www.seielect.com marketing@seielect.com ASR / ASRM Series Stackpole Electronics, Inc. Anti-Surge Resistor Resistive Product Solutions RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Package / Termination Type Description ASR Anti-Surge Leaded Resistor Axial ASRM Mini-Anti Surge Leaded Resistor Axial ASRM14 Mini-Anti Surge Leaded Resistor Axial Note (1): RoHS compliant by means of exemption 7c-I Standard Series RoHS Compliant YES YES YES(1) Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) 99.3/0.7 Sn/Cu 99.3/0.7 Sn/Cu 99.3/0.7 Sn/Cu Apr-05 Apr-05 Apr-05 Lead-Free Effective Date Code (YY/WW) 05/14 05/14 05/14 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order A Product Series Code Description ASR Standard ASRM Mini S Power Rating Code W 14 0.25 12 0.5 1 1 2 2 R 1 Tolerance Code Tol J 5% Rev Date: 12/13/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 J Code Description T Tape and Reel B Bulk A Ammo 9 A 1 0 Packaging Product Code ASRM14, ASR14 ASRM12, ASRM1 ASR1, ASRM2 ASRM14 ASR14, ASRM12, ASRM1, ASR1, ASRM2 ASRM14 ASR14, ASRM12 ASRM1 ASR1, ASRM2 0 K Resistance Value Quantity 5000 2500 1000 2000 1000 Four characters with the multiplier used as the decimal holder. 10 ohm = 10R0 560 Kohm = 560K 1 Mohm = 1M00 5000 2000 1000 500 www.seielect.com marketing@seielect.com
ASRM1JA220K 价格&库存
很抱歉,暂时无法提供与“ASRM1JA220K”相匹配的价格&库存,您可以联系我们找货
ASRM1JA220K
  • 1+4.778191+0.61731
  • 10+3.0678710+0.39635
  • 25+2.6026725+0.33625
  • 50+2.3108550+0.29855
  • 100+2.06414100+0.26667
  • 250+1.79275250+0.23161
  • 500+1.62300500+0.20968
库存:1707
ASRM1JA220K
  • 1000+1.478651000+0.19103
  • 2000+1.356052000+0.17519
  • 3000+1.293023000+0.16705
  • 5000+1.221715000+0.15784
  • 7000+1.179237000+0.15235
  • 10000+1.1377110000+0.14699
库存:1707
