VM / MVM Series
Stackpole Electronics, Inc.
Ceramic Housed Vertical Mount Resistor
Resistive Product Solutions
Features:
Flameproof inorganic construction
High temperature potting compound
VM – Wirewound element
MVM – Metal oxide element for higher values
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Electrical Specifications
Power Rating (W)
@ 70ºC
Type / Code
Voltage Rating
(V)
TCR (ppm/°C)
Ohmic Range (Ω) and Tolerance
5%
VM2
2
250
VM3
3
300
< 1 Ω = ± 800 ppm/ºC
VM5
5
350
> 1 Ω = ± 300 ppm/ºC
VM7
7
500
VM10
10
700
MVM2
2
250
MVM3
3
300
± 200 ppm/ºC
MVM5
5
350
MVM7
7
500
MVM10
10
700
Maximum Working Voltage is limited by √ P*R unless specified otherwise.
10%
0.056 - 100
0.1 - 100
0.1 - 100
0.39 - 470
0.56 - 680
0.1 - 51K
0.1 - 51K
0.1 - 51K
510 - 51K
750 - 51K
Mechanical Specifications
VM:
Type / Code
VM2 / MVM2
VM3 / MVM3
VM5 / MVM5
VM7 / MVM7
VM10 / MVM10
MVM:
A
0.276
7.00
0.335
8.50
0.374
9.50
0.374
9.50
0.472
12.00
B
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
0.807
20.50
0.984
25.00
0.984
25.00
1.535
39.00
1.378
35.00
C
0.039
1.00
0.039
1.00
0.039
1.00
0.059
1.50
0.039
1.00
Rev Date: 3/16/2021
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
0.433
11.00
0.492
12.50
0.512
13.00
0.512
13.00
0.630
16.00
1
D
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
0.197
5.00
0.197
5.00
0.197
5.00
0.197
5.00
0.295
7.50
Lead Diameter
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
0.031
0.80
0.031
0.80
0.031
0.80
0.031
0.80
0.031
0.80
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
Lead Length
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
marketing@seielect.com
VM / MVM Series
Performance Characteristics
Test
Moisture Resistance
Thermal Shock
Load Life @ 70C - 1000 hours
Resistance to Soldering Heat
Short Time Overload - 5 X Pn for 5 seconds
Dielectric Withstanding Voltage
Operational temperature range is -55°C to 275°C for VM and -55°C to 150°C for MVM.
Test Results
± 5%
± 2%
± 5%
± 2%
± 2%
± 2%
Power Derating Curve:
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
Rev Date: 3/16/2021
2
Minimum
60 seconds
100°C
240°C
N/A
www.seielect.com
VM / MVM Series
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
Recommended Lead Free Resistor Reflow Profile
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
VM
MVM
Description
Wirewound Resistor
(Standard WW)
Ceramic Housed
Vertical Mount Wirewound Resistor
(Metal Oxide)
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
Radial
YES
100% Matte Sn
Jan-06
06/01
Radial
YES
100% Matte Sn
Jan-06
06/01
Rev Date: 3/16/2021
3
www.seielect.com
VM / MVM Series
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the Eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
V
Product Series
VM Standard WW
MVM Metal Oxide
M
Power Rating
Size
W
2
2
3
3
5
5
7
7
10
10
3
Tolerance
Code Tol
J
5%
K
10%
Rev Date: 3/16/2021
J
B
2
R
Packaging
Code Description
Size
VM2, MVM2
VM3, MVM3
B
Bulk
VM5, MVM5
VM7, MVM7
VM10, MVM10
4
2
Quantity
1500
800
600
Resistance Value
Four characters with the multiplier
used as the decimal holder.
"L" used as multiplier of 10-3
for any value under 0.1 ohm.
0.056 ohm = 56L0
0.1 ohm = R100
680 ohm = 680R
51 Kohm = 51K0
www.seielect.com
很抱歉,暂时无法提供与“MVM5JB100R”相匹配的价格&库存,您可以联系我们找货
