HHV1WSFR-73-1M5
HHV1WSFR-73-1M5
    YAGEO(国巨)
    插件
    插件电阻 - 1.5MΩ ±1% 1W ±200ppm/℃
HHV1WSFR-73-1M5 数据手册
Through-hole resistors Metal Glazed Film Resistors High Voltage & High Ohmic Type Normal & Miniature Style [ HHV Series ] FEATURES Power Rating 1/4W, 1/2W, 1W, 2W, 3W Resistance Tolerance ±1%, ±5% T.C.R. ±200ppm/°C Flameproof Multi-layer Coating Meets UL-94V-0 Flameproof Feature Meets Overload Test UL-1412 INTRODUCTION DERATING CURVE The HHV Series High Voltage & High Ohmic Resistors are made of metal glaze film, with tinned connecting leads of electrolytic copper welded to the end-caps. The resistors are coated with layers of pink color lacquer. For resistors operated in ambient temperatures above 70°C, power rating must be derated in accordance with the curve below. Rated Load (%) 70 155 °C 100 80 60 40 20 20 40 60 80 100 120 140 160 Ambient Temperature (°C) DIMENSIONS Unit: mm STYLE ød H L 5th color code: yellow øD DIMENSION Normal Miniature L øD H ød HHV-25 HHV50S 6.3±0.5 2.4±0.2 28±2.0 0.55±0.05 HHV-50 HHV1SS 9.0±0.5 3.3±0.3 26±2.0 0.55±0.05 HHV1WS HHV2SS 11.5±1.0 4.5±0.5 35±2.0 0.8±0.05 HHV2WS HHV3SS 15.5±1.0 5.0±0.5 33±2.0 0.8±0.05 37 Note: ELECTRICAL CHARACTERISTICS STYLE HHV-25 HHV50S HHV-50 HHV1SS HHV1WS Power Rating at 70°C 1/4W 1/2W Maximum Working Voltage (DC) 1,600V 3,500V 5,000V 7,000V Maximum Overload Voltage (DC) 3,000V 7,000V 10,000V 14,000V Voltage Proof on Insulation 300V 500V 700V Resistance Range 100KΩ - 68MΩ for E24 & E96 series value Operating Temp. Range -55°C to +155°C Temperature Coefficient ±200pm/°C 1W HHV2SS HHV2WS HHV3SS 2W 3W Note: Special value is available on request ENVIRONMENTAL CHARACTERISTICS PERFORMANCE TEST TEST METHOD APPRAISE Short Time Overload IEC 60115-1 4.13 2.5 times RCWV for 5 sec. (Not more than maximum Overload Voltage) ±2.0%+0.05Ω Voltage Proof on Insulation IEC 60115-1 4.7 In V-Block for 60 sec., test voltage as above table No Breakdown Temperature Coefficient IEC 60115-1 4.8 Between -55°C to +155°C By type Insulation Resistance IEC 60115-1 4.6 in V-block for 60 Sec. >10,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of Marking IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of coatings and markings Robustness of Terminations IEC 60115-1 4.16 Direct load for 10 Sec. in the direction of the terminal leads ≥2.5kg (24.5N) Periodic-pulse Overload IEC 60115-1 4.39 4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off) ±1.0%+0.05Ω Damp Heat Steady State IEC 60115-1 4.24 40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV ±5.0%+0.05Ω Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±5.0%+0.05Ω Temperature Cycling IEC 60115-1 4.19 -55°C  Room Temp.  +155°C  Room Temp. (5 cycles) ±1.0%+0.05Ω Resistance to Soldering Heat IEC 60115-1 4.18 260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body ±1.0%+0.05Ω Accidental Overload Test IEC 60115-1 4.26 4 times RCWV for 1 Min. No evidence of flaming or arcing Note: RCWV(Rated Continuous Working Voltage) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less. Revision: 2020
HHV1WSFR-73-1M5
物料型号:HHV系列高压高阻值电阻器。
器件简介:这些电阻器由金属釉膜制成,端盖焊接有镀锡电解铜引线,并涂有粉红色漆层。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 功率等级:1/4W, 1/2W, 1W, 2W, 3W - 电阻公差:±1%, ±5% - 温度系数:±200ppm/°C - 防火多层涂层符合UL-94V-0标准 - 防火特性符合过载测试UL-1412
功能详解: - 电阻器在70°C以上的环境温度下工作时,需要根据提供的降额曲线进行功率降额。 - 提供了不同风格的电阻器尺寸,包括正常尺寸和微型尺寸。
应用信息:文档中未明确提供应用信息
封装信息:提供了电阻器的尺寸信息,包括长度、直径和高度。
HHV1WSFR-73-1M5 价格&库存
很抱歉,暂时无法提供与“HHV1WSFR-73-1M5”相匹配的价格&库存,您可以联系我们找货
