Through-hole resistors
Cement Resistors
Vertical Lead Type
Normal Style [ SQM Series ]
Non-Inductive Style [ NSM Series ]
FEATURES
Power Rating
2W, 3W, 5W, 7W, 10W
Resistance Tolerance
Wirewound: ±1% ±5%, Film:±5/°C
T.C.R.
Wirewound: ±100ppm/°C , ±300ppm/°C, Film:±300ppm/°C
DERATING CURVE
40 70
155
275 °C
100
Temperature Rise
The SQM Series are ceramic housed resistors
with fiberglass based wirewound or ceramic
rod wirewound or metal oxide core. The
NSM Series are ceramic housed low-inductive
resistors with ceramic rod wirewound core.
Rated Load
INTRODUCTION
TEMPERATURE RISE
3W-5W
7W-10W
80
2W
60
40
The materials used and the construction
techniques ensure excellent flame resistance,
arc resistance and moisture resistance as well
as self-extinguishing capabilities. They will
withstand the most rigorous loading test.
(°C)
100 150 200 250 300
250
10W
200
7W
5W
150
3W
100
2W
50
60
80
100 120
Rated Load (%)
Ambient Temperature (°C)
As resistors in radio and television receivers,
hazardous conditions such as smoking and
redheat can be completely prevented by the
proper choice of power resistors.
DIMENSIONS
Unit: mm
STYLE
W
S
H
3.5±1
P
ø08±0.05
DIMENSION
Normal
Non-Ind.
H
W
S
P
SQM200
NSM200
20±1.5
11.0±1.0
7.0±1.0
5+2-1
SQM300
NSM300
25±1.5
12.0±1.0
8.0±1.0
5+2-1
SQM500
NSM500
25±1.5
13.0±1.0
9.0±1.0
5+2-1
SQM700
NSM700
39±1.5
13.0±1.0
9.0±1.0
5+2-1
SQM10A
NSM10A
51±1.5
13.0±1.0
9.0±1.0
5+2-1
SQM10S
NSM10S
35±1.5
16.0±1.0
12.0±1.0
7+2-1
57
ELECTRICAL CHARACTERISTICS
Normal Style
STYLE
SQM200
Power Rating at 40°C
SQM300
SQM500
SQM700
SQM10A
3W
5W
7W
10W
SQM10S
Power Rating at 70°C
2W
Maximum Working Voltage
250V
350V
500V
Maximum Overload Voltage
500V
700V
1,000V
Voltage Proof on Insulation
500V
700V
1,000V
Resistance Range
(Ceramic based wirewound)
0.1Ω - 36Ω
0.1Ω - 68Ω
0.1Ω - 130Ω
0.1Ω - 330Ω
0.1Ω - 510Ω
0.1Ω - 270Ω
Resistance Range (Film)
39Ω - 1MΩ
75Ω - 1MΩ
150Ω - 1MΩ
360Ω - 1MΩ
560Ω - 1MΩ
300Ω - 1MΩ
Resistance Range
(Fiberglass based wirewound)
0.1Ω - 1KΩ
0.1Ω - 4.7KΩ
0.1Ω - 4.7KΩ
0.1Ω - 5.6KΩ
0.1Ω - 4.7KΩ
Operating Temp. Range
-55°C to +155°C
Temperature Coefficient
NSM10S
Non-Inductive Style
STYLE
NSM200
NSM300
NSM500
NSM700
NSM10A
3W
5W
7W
10W
2W
PxR
500V
700V
Resistance Range
0.1Ω - 10Ω
0.1Ω - 30Ω
-55°C to +155°C
±300ppm/°C
1,000V
0.15Ω - 65Ω
0.27Ω - 100Ω
Note: Special value is available on request
ENVIRONMENTAL CHARACTERISTICS
PERFORMANCE TEST
TEST METHOD
APPRAISE
Short Time Overload
IEC 60115-1 4.13
2.5 times RCWV for 5 sec. (Not more than maximum Overload Voltage)
±2.0%+0.05Ω
IEC 60115-1 4.7
In V-Block for 60 sec., test voltage as above table
No Breakdown
IEC 60115-1 4.8
Between -40°C to +155°C
By type
Insulation Resistance
IEC 60115-1 4.6
in V-block for 60 Sec.
>1,000MΩ
Solderability
IEC 60115-1 4.17
245±5°C for 3±0.5 Sec.
95% Min. coverage
Solvent Resistance of Marking
IEC 60115-1 4.30
IPA for 5±0.5 Min. with ultrasonic
No deterioration of
coatings and markings
Robustness of Terminations
IEC 60115-1 4.16
Direct load for 10 Sec. in the direction of the terminal leads
≥2.5kg (24.5N)
Periodic-pulse Overload
IEC 60115-1 4.39
4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off)
±2.0%+0.05Ω
Damp Heat Steady State
IEC 60115-1 4.24
40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV
±5.0%+0.05Ω
Endurance at 70°C
IEC 60115-1 4.25
70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±5.0%+0.05Ω
Temperature Cycling
IEC 60115-1 4.19
-55°C Room Temp. +155°C Room Temp. (5 cycles)
±2.0%+0.05Ω
Resistance to Soldering Heat
IEC 60115-1 4.18
260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body
±1.0%+0.05Ω
Note: Rated Continuous Working Voltage (RCWV) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less.
Revision: 2020
很抱歉,暂时无法提供与“SQM700JB-8K2”相匹配的价格&库存,您可以联系我们找货
