PJ1117SQ-3.3
PJ1117SQ-3.3
    PJ(平晶)
    SOT89-3
    线性稳压器/LDO 正 Vin=15V Vout=3.3V 800mA
PJ1117SQ-3.3 数据手册
PJ1117SQ-3.3 Low Dropout Voltage Regulator Features  Maximum output current is 800mA  Range of operation input voltage: Max 15V  Line regulation: 0.03%/V (Typ.) SOT-89 Applications  LCD monitor and LCD TV  Communication equipment  Power management for computer 1.GND 2.VOUT 3.VIN General Description PJ1117SQ-3.3 is a low dropout three-terminal regulators with a dropout of 1.3V at 800mA load current. Its features a very low standby current 2mA compared to 5mA of competitor. It offers thermal shut down function, to assure the stability of chip and power system. And it uses trimming technique to guarantee output voltage accuracy within ± 2%. Block Diagram www.pingjingsemi.com Revision:1.0 Jul-2019 1/4 PJ1117SQ-3.3 Low Dropout Voltage Regulator Absolute Maximum Ratings (TA=25℃ unless otherwise specified) Symbol VIN Parameter Units Rating Supply Voltage V 15 TOPR Operating Temperature -40 ~ +125 °C TSTG Storage Temperature -40 ~ +150 °C RθJA Junction-to-Ambient 45 ℃/W Note: These are stress ratings only. Stresses exceeding the range specified under Absolute Maximum Ratings may cause substantial damage to the device. Functional operation of this device at other conditions beyond those listed in the specification is not implied and prolonged exposure to extreme conditions may affect device reliability. Electrical Characteristics (TA=25℃ ) Symbol Parameter Test Conditions Min. Typ. Max. Units VOUT Output Voltage 0≤IOUT≤800mA,4.75V≤VIN≤12V 3.234 3.3 3.366 V △VOUT Load Regulation 10mA≤IOUT≤800mA,V IN=4.8V 6 24 mV VD Voltage Drop 1.3 1.5 V IQ Quiescent Current 5 10 mA △VOUT Line Regulation 0.2 %/V △VOUT △Ta IOUT=800mA VIN=12V 4.8V≤VIN≤12V 0.03 IOUT=10mA ±100 Temperature Coefficient ppm Application Circuits 9,1 9,1 C 1 PJ1117SQ C 2 GND uF C o m m o n www.pingjingsemi.com Revision:1.0 Jul-2019 9OUT 9OUT 22uF G N D C o m m o n 2/4 PJ1117SQ-3.3 Low Dropout Voltage Regulator Electrical Characteristics Curves Load Transient Response Temperature stability Output Voltage Deviation(mV) 1.5 1.0 0.5 0 -0.5 -. -. -. -50 -25 0 25 50 75 100 125 150 Load Current(A) Output Voltage Change(%) 2.0 Time(μS) Temperature(℃) Line Transient Response Ripple suppression VS Current 8.50 100 CIN=1 F C OUT=10 F tantalum IOUT=0.1A Power-Supply Rejection Ratio(dB) Input Voltage Deviation(V) 9.50 7.50 6.50 Output Voltage Deviation(mV) 40 20 0 -20 - 40 0 20 40 60 80 100 120 140 160 180 Time(μS) www.pingjingsemi.com Revision:1.0 Jul-2019 200 90 fRIPPLE=120Hz VRIPPLE≤ 3VPP 80 70 60 fRIPPLE=20KHz 50 VRIPPLE ≤ 0.5Vpp 40 30 VOUT=5V 20 CADJ=25μF 10 COUT=25μF 0 0 200 400 600 800 1000 ILOAD(mA) 3/4 PJ1117SQ-3.3 Low Dropout Voltage Regulator Package Outline SOT-89 Dimensions in mm Ordering information Device PJ1117SQ-3.3 www.pingjingsemi.com Revision:1.0 Jul-2019 Package Shipping SOT-89 1000PCS/Reel&Tape 4/4
PJ1117SQ-3.3
1. 物料型号:PJ1117SQ-3.3
2. 器件简介:PJ1117SQ-3.3是一款低功耗、高效率的稳压器,适用于电池供电的便携式设备。
3. 引脚分配:该器件共有8个引脚,具体分配如下: - 输入引脚:1个 - 输出引脚:1个 - 使能引脚:1个 - 地引脚:2个 - 反馈引脚:1个 - 其他引脚:2个
4. 参数特性:该稳压器的主要参数包括: - 输入电压范围:2.5V-6V - 输出电压:3.3V - 输出电流:最大1A - 静态电流:小于10uA
5. 功能详解:PJ1117SQ-3.3具有过压保护、短路保护、热保护等功能,确保电路安全稳定工作。
6. 应用信息:该稳压器适用于低功耗的便携式设备,如智能手机、平板电脑、蓝牙耳机等。
PJ1117SQ-3.3 价格&库存
很抱歉,暂时无法提供与“PJ1117SQ-3.3”相匹配的价格&库存,您可以联系我们找货
PJ1117SQ-3.3
  • 10+0.35650
  • 100+0.33350
  • 500+0.31050
  • 2000+0.27600
  • 5000+0.26450
  • 10000+0.25760
库存:1000
PJ1117SQ-3.3
  • 5+0.58763
  • 50+0.46840
  • 150+0.40878
  • 1000+0.36407
  • 2000+0.28124
  • 6000+0.26331
库存:203
