BC807-25
BC807-25
    HOTTECH(合科泰)
    SOT-23
    100nA 45V 300mW 160@100mA,1V 500mA 100MHz 700mV@500mA,50mA PNP +150℃@(Tj) SOT-23-3L
BC807-25 数据手册
Plastic-Encapsulate Transistors FEATURES BC807-16 (PNP) BC807-25 (PNP) BC807-40 (PNP) Ldeally suited for automatic insertion epitaxial planar die construction complementary NPN type available(BC817) Marking BC807-16 BC807-25 BC807-40 5A 5B MAXIMUM RATINGS (TA=25 5C unless otherwise noted) Parameter Symbol Value Unit Collector-Base Voltage VCBO -50 V Collector-Emitter Voltage VCEO -45 V Emitter-Base Voltage VEBO -5 V IC -500 mA Collector Power Dissipation PC 300 mW Junction Temperature TJ 150 Storage Temperature Tstg -55 to +150 Collector Current -Continuous Thermal Resistance Junction to Ambient RθJA ELECTRICAL CHARACTERISTICS (Tamb=25 1. BASE SOT-23 2. EMITTER 3. COLLECTO ℃/W 417 unless otherwise specified) Parameter Symbol Test conditions Min Max Unit Collector-base breakdown voltage VCBO IC= -10μA, IE=0 -50 V Collector-emitter breakdown voltage VCEO IC= -10mA, IB=0 -45 V Emitter-base breakdown voltage VEBO IE= -1μA, IC=0 -5 V Collector cut-off current ICBO VCB= -45V, IE=0 -0.1 uA Collector cut-off current ICEO VCE= -40V, IB=0 -0.2 uA Emitter cut-off current IEBO VEB= -4 V, -0.1 uA DC current gain IC=0 807-16 807-25 hFE VCE= -1V, IC= -100mA 807-40 100 250 160 400 250 600 Collector-emitter saturation voltage VCE(sat) IC=-500mA, IB= -50mA -0.7 V Base-emitter saturation voltage VBE(sat) IC= -500mA, IB= -50mA -1.2 V Transition frequency fT VCE= -5V, IC= -10mA Cc IE = 0; VCB = -10 V f = 1 MHz 100 MHz f=100MHz collector capacitance GUANGDONG HOTTECH INDUSTRIAL CO., LTD 9 PF Page:P2-P1 Plastic-Encapsulate Transistors BC807-16 BC807-25 BC807-40 Typical Characteristics GUANGDONG HOTTECH INDUSTRIAL CO., LTD Page:P2-P2
BC807-25 价格&库存
很抱歉,暂时无法提供与“BC807-25”相匹配的价格&库存,您可以联系我们找货
BC807-25
  • 1+0.28710
  • 200+0.09559
  • 1500+0.05984
  • 3000+0.04741
BC807-25
  • 3000+0.06740
  • 9000+0.06459
  • 27000+0.06290
  • 36000+0.06178
BC807-25
库存:120
