SS22L-SS210L
SCHOTTKY BARRIER DIODE
FEATURES
Small Surface Mount device
Low power loss, high efficiency
High temperature soldering guaranteed:260°C/10 seconds at terminals
Guard ring for over voltage protection
For use in low voltage high frequency inverters,
free wheeling, and polarity protection applications
SOD-123FL
MECHANICAL DATA
Case: SOD-123FL
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Weight: 0.0155 grams (approximate)
MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Parameter
Symbol SS22L SS23L SS24L SS26L SS28L SS210L SS215L SS220L Unit
Repetitive peak reverse voltage VRRM
40
60
80
100
150
200
V
DC Reverse Voltage
VR
40
60
80
100
150
200
V
RMS Reverse Voltage
Non-Repetitive Peak Forward
Surge Current @ t = 8.3 ms
Mean rectifying current
VRMS
14
21
28
42
56
70
105
140
V
IFSM
50
A
2.0
A
Thermal Resistance
IF
RθJA
85
°C/W
Junction Temperature
TJ
150
°C
Storage Temperature
TSTG
-55 ~+175
°C
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Parameter
Forward voltage
Reverse current T=25°C
Reverse current T=100°C
Junction capacitance
VF
IR
IR
CJ
© SHENZHEN HOTTECH ELECTRONICS CO.,LTD
0.5
0.7
0.85
0.9
0.5
E-mail:hkt@heketai.com
Unit
0.92
V
mA
mA
pF
Conditions
IF=2A
V=VR
V=4V,f=1MHz
1/4
SS22L-SS210L
Typical Characteristics
FIG. 2 MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
FIG.1 FORWARD CURRENT DERATING CURVE
PEAK FORWARD SURGE CURRENT
(A)
AVERAGE FORWARD CURRENT (A
2.5
2
1.5
SS25L-SS220L
SS22L-SS24L
1
0.5
RESISTIVE OR
INDUCTIVE LOAD
60
70
80
90 100 110 120 130 140 150 160 170
50
8.3ms Single Half Sine-Wave
JEDEC Method
40
30
10
LEAD TEMPERATURE (oC)
NUMBER OF CYCLES AT 60 Hz
FIG. 3 TYPICAL FORWARD CHARACTERISTICS
FIG. 4 TYPICAL REVERSE CHARACTERISTICS
100
INSTANTANEOUS REVERSE A
CURRENT (mA)
INSTANTANEOUS FORWARD A
CURRENT (A)
100
SS25L-SS26L
10
100
SS215L-SS220L
SS22L-SS24L
1
SS22L-SS24L
SS25L-SS220L
TJ=125℃
10
1
0.1
TJ=75℃
0.01
TJ=25℃
SS29L-SS210L
0.001
0.1
0.4
0.6
0.8
1
1.2
1.4
JUNCTION CAPACITANCE (pF) a
100
f=1.0MHz
Vslg=50mVp-p
10
0.1
1
10
REVERSE VOLTAGE (V)
100
TRANSIENT THERMAL IMPEDANCE (℃/W)
FIG. 5 TYPICAL JUNCTION CAPACITANCE
40
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLYAGE(%)
FORWARD VOLTAGE (V)
1000
FIG. 6 TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
T-PULSE DURATION(S)
10
100
2/4
SS22L-SS210L
SOD-123FL Package Outline Dimensions
Symbol
Dimensions In Millimeters
Min.
Max.
A
0.75
B
Dimensions In Inches
Max.
0.95
Min.
0.029
1.60
2.00
0.063
0.079
C
2.60
3.00
0.103
0.119
D
0.90
1.20
0.036
0.047
E
0.12
0.22
0.005
0.009
F
G
0.8Typ
3.50
0.037
0.032Typ
3.90
0.138
0.159
SOD-123FL Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
3/4
SS22L-SS210L
SOD-123FL Tape and Reel
SOD-123FL Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SOD-123FL
2.10
4.00
1.25
Ø1.50
1.75
3.50
4.00
4.00
2.00
8.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SOD-123FL Tape Leader and Trailer
SOD-123FL Reel
REEL OPTION
7’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø178
54.40
13.00
R78
R25.60
R6.50
9.50
12.30
±2
±1
±1
±1
±1
±1
±1
±1
4/4
很抱歉,暂时无法提供与“SS24L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.20108
- 300+0.16544
- 1200+0.14559
- 3000+0.11841
- 国内价格
- 20+0.21936
- 200+0.18048
- 600+0.15883
- 3000+0.12918
- 9000+0.11790
- 21000+0.11184
- 国内价格
- 1+0.39270
- 200+0.13090
- 1500+0.08195
- 3000+0.06501
- 国内价格
- 20+0.09180
- 200+0.08640
- 600+0.08100
- 3000+0.07020
