Shenzhen Orient Components Co ., Ltd
OR-3120_OR-3150
ORIENT
Photo coupler
Product Data Sheet
Part Number:
OR-3120_OR-3150
Customer:
Date:
SHENZHEN ORIENT COMPONENTS CO ., LTD
Block A 3rd Floor No.4 Building,Tian’an Cyber Park,Huangge Rd,LongGang Dist,Shenzhen,GD
TEL:0755-29681816
FAX:0755-29681200
www.orient-opto.com
Copyright© 2020 Orient .All rights Reserved
1
V14
OR-3120_OR-3150
1. Features
(1) 1.5A maximum peak output current for OR-3150,
3.0A maximum peak output current for OR-3120.
(2) 35-kV/µs minimum Common Mode Rejection (CMR) at VCM = 1500V
(3) 1.0V maximum low level output voltage (VOL) eliminates need for
negative gate drive
(4) ICC = 5 mA maximum supply current
(5) Under voltage lock-out protection (UVLO) with hysteresis
(6) Wide operating VCC range: 15V to 35V
(7) 0.2µs maximum propagation delay
(8) ±0.1µs maximum delay between devices/channels
(9) Industrial temperature range: –40°C to 110°C
(10) Safety approval
UL approved(No.E323844)
VDE approved(No.40029733)
CQC approved (No.CQC19001231254 )
(11) In compliance with RoHS, REACH standards
(12) MSL Class Ⅰ
2. Instructions
The OR-3120/OR-3150 consists of an LED optically coupled to an
integrated circuit with a power output stage. This optocoupler is ideally suited
for driving power IGBTs and MOSFETs used in motor control inverter
applications. The high operating voltage range of the output stage provides the
drive voltages required by gate-controlled devices.
3. Application Range
(1)
(2)
(3)
(4)
IGBT/MOSFET gate drive
AC/Brushless DC motor drives
Industrial inverters
Switch mode power supplies
4. Functional Diagram
Truth Table
LED
OFF
ON
ON
ON
VCC – VEE
“POSITIVE GOING”
( TURN-ON)
VCC – VEE
VO
VCC – VEE
“NEGATIVE GOING”
( TURN-OFF)
VCC – VEE
VO
0 – 30 V
0 – 11.5 V
11.5 – 13.5 V
13.5 – 30 V
30 – 0 V
30 – 12.0 V
12.0 –10.0 V
10.0 – 0 V
2
LOW
LOW
TRANSITION
HIGH
LOW
HIGH
TRANSITION
LOW
V14
OR-3120_OR-3150
5. Absolute Maximum Ratings (Ta=25℃)*1
Parameter
Input
Symbol
Rated Value
Unit
Average Forward Input Current
IF
25
mA
Reverse Input Voltage
VR
5
V
OR-3120
“High” Peak Output
Current
3.0
IOH(PEAK)
Output
“Low” Peak Output
Current
A
OR-3150
1.5
OR-3120
3.0
IOL(PEAK)
OR-3150
A
1.5
Output Collector Power Dissipation
PO
250
mW
Total Power Dissipation
PT
295
mW
Total Output Supply Voltage
VCC - VEE
35
V
Total Output Supply Voltage (90℃)
VCC - VEE
30
V
Insulation Voltage
Viso
5000
Vrms
Working Temperature
Topr
-40 ~+ 110
Storage Temperature
Tstg
-55~ + 125
*2 Soldering Temperature
Tsol
260
*1. Room temperature = 25 ℃. Exceeding the maximum absolute rating can permanently damage the device. Working long
hours at the maximum absolute rating can affect reliability.
*2. soldering time is 10 seconds.
6. Recommended Operating Conditions
Parameter
Symbol
Min
Max
Unit
Power Supply
TA
VCC-VEE
Input Current
IF(ON)
-40
15
7
30
16
0.8
V
mA
V
Operating Temperature
Input Voltage(OFF)
VF(OFF)
3
V14
OR-3120_OR-3150
7. Opto-electronic Characteristics
Parameter
High Level
Output
Current
Low Level
Output
Current
Symbol
OR-3120
IOH
OR-3150
OR-3120
IOL
OR-3150
High Level Output Voltage
VOH
Low Level
Output
Voltage
VOL
OR-3120
OR-3150
Min.
Typ.
Max.
1.0
2.0
2.5
VO = (VCC – 3V)
2.0
2.5
VO = (VCC – 6V)
0.2
1.0
VO = (VCC – 4V)
1.0
2.0
2.5
VO = (VEE + 3V)
2.0
2.5
VO = (VEE + 6V)
0.2
1.0
(VCC – 0.3) (VCC– 0.1)
0.1
0.25
0.4
1.0
Units
A
A
Test Conditions
VO = (VCC – 0.75V)
VO = (VEE + 0.75V)
VO = (VEE + 4V)
V
V
IO = –100 mA
IO = 100 mA
High Level Supply Current
ICCH
1.6
3.0
mA
Output Open, IF = 7 to 16 mA
Low Level Supply Current
ICCL
2.0
3.0
mA
Output Open,VF = –3.0 to +0.8V
Threshold Input Current Low
to High
IFLH
3.0
5.0
mA
IO = 0 mA,VO > 5V
Threshold Input Voltage High
to Low
VFHL
0.8
V
IO = 0 mA,VO < 5V
VF
1.2
1.5
1.8
V
IF = 10 mA
ΔVF/ΔTA
–1.6
mV/°C
IF = 10 mA
BVR
5
V
IR = 10 µA
CIN
70
pF
f = 1 MHz, VF = 0V
VUVLO+
11.5
12.7
13.5
VUVLO-
10.0
11.2
12.0
V
VO > 5 V
IF = 10 mA
UVLOHYS
1.5
Riso
5×1010
1×10 12
Ω
DC500V, 40~60%R.H.
Input Forward Voltage
Temperature Coefficient of
Forward Voltage
Input Reverse Breakdown
Voltage
Input Capacitance
UVLO Threshold
UVLO Hysteresis
Insulation Impedance
1.
All typical values at TA = 25°C and VCC – VEE = 30V, unless otherwise noted.
2.
Maximum pulse width = 10 µs, maximum duty cycle = 0.2%. This value is intended to allow for component tolerances for
designs with IO peak minimum = 0.5 A. See Applications section for additional details on limiting IOH peak.
3.
Maximum pulse width = 50 µs, maximum duty cycle = 0.5%.
4.
In this test, VOH is measured with a dc load current. When driving capacitive loads VOH will approach VCC as IOH approaches zero amps.
5.
Maximum pulse width = 1 ms, maximum duty cycle = 20%.
4
V14
OR-3120_OR-3150
8. Switching Characteristics
Parameter
Symbol
Min.
Typ
Max.
Units
Propagation Delay Time to High
Output Level
Propagation Delay Time to Low
Output Level
tPLH
0.05
0.11
0.20
μs
tPHL
0.05
0.11
0.20
μs
Pulse Width Distortion
PWD
0.005
0.06
μs
PDD
(tPHL – tPLH)
–0.1
0.1
μs
Rise Time
tr
0.1
μs
Fall Time
tf
0.1
μs
UVLO Turn On Delay
tUVLO ON
0.9
UVLO Turn Off Delay
tUVLO OFF
0.8
Output High Level Common Mode
Transient Immunity
|CMH|
35
50
kV/μs
Output Low Level Common Mode
Transient Immunity
|CML|
35
50
kV/μs
Propagation Delay Difference
Between Any Two Parts
1.
2.
3.
4.
5.
6.
7.
μs
Test Conditions
OR-3120:
Rg=10 ,Cg=10nF,
f=10kHz,
Duty Cycle=50%
OR-3150:
Rg=47Ω,Cg=3nF,
f=10kHz,
Duty Cycle = 50%
VO>5V,IF=10mA
VO15.0V).
Common mode transient immunity in a low state is the maximum tolerable dVCM/dt of the common mode pulse, VCM, to
assure that the output will remain in a low state (i.e., VO
很抱歉,暂时无法提供与“OR-3120S-TA1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.66560
- 10+3.72600
- 30+3.26160
- 100+2.79720
- 500+2.65680
- 1000+2.50560
- 国内价格
- 1+3.02500
- 50+2.32100
- 1000+2.14500
