MB2F THRU MB10F
Voltage Range - 200 to 1000 Volts
Current - 1.0 Ampere
SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS
Features
MBF
Glass passivated die construction
Low forward voltage drop
High current capability
High surge current capability
Designed for surface mount application
Plastic material-UL flammability 94V-0
Mechanical Data
MAX
Case : JEDEC MBF Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.0026 ounce, 0.075 grams
(1)
(2)
(3)
Maximum Ratings And Electrical Characteristics
Ratings at 25 °C ambient temperature unle ss otherwise specified.
(4)
Dimensions in inches and (millimeters)
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
MDD
MB2F
MDD
MB4F
MDD
MB6F
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
VRMS
VDC
200
140
200
400
280
400
600
420
600
Maximum average forward rectified current
at TC=125°C
IF(AV)
1.0
A
IFSM
35
A
VF
1.1
V
IR
5
40
uA
mA
CJ
13
PF
Marking Code
Peak forward surge current,
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage drop
per leg at 0.5A
Maximum DC reverse current
TA=25
at rated DC blocking voltage
TA=100
Typical junction capacitance (NOTE1)
Typical thermal resistance(NOTE2)
Operating temperature range
storage temperature range
R
JA
80
R
JC
25
TJ
TSTG
MDD
MB8F
-55 to +150
-55 to +150
800
560
800
MDD
MB10F
UNITS
1000
700
1000
V
V
V
°C/W
°C
°C
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad.
http://www.microdiode.com
Rev:2024A2
Page :1
MB2F THRU MB10F
Ratings And Characteristic Curves
Fig.2 Typical Reverse Characteristics
Fig.1 Average Rectified Output Current
Derating Curve
1.2
Instaneous Reverse Current(μ A)
100
Average Rectified Output Current (A)
1.0
0.8
0.6
0.4
0.2
Resistive or Inductive Load
0.0
25
50
75
100
125
150
TJ=125°C
10
1.0
TJ=25°C
0.1
175
00
Case Temperature (°C)
60
80
100
120
140
percent of Rated Peak Reverse Voltage (%)
Fig.3 Typical Instaneous Forward
Fig.4 Typical Junction Capacitance
Characteristics TJ=25°C
100
Junction Capacitance (pF)
Instaneous Forward Current (A)
10
1.0
0.1
pulse with 300μ
s
1% duty cycle
0.01
00..
00
0.5
1.0
1.5
TJ=25°C
10
1
2.0
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
40
30
8.3 ms Single Half Sine Wave (JEDEC
Method)
00
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A2
Page :2
MB2F THRU MB10F
Suggested Pad Layout
P2
P1
Dim
Min
P1
6.00
P2
2.40
Q1
1.84
Q2
1.20
Q1
Q2
Dimensions in millimeters
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“MB10F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.44770
- 500+0.14960
- 2500+0.09944
- 5000+0.08151
- 国内价格
- 1+0.08694
- 30+0.08379
- 100+0.07749
- 500+0.07119
- 1000+0.06804
- 国内价格
- 10+0.15470
- 100+0.12370
- 300+0.10800
- 3000+0.09450
- 9000+0.08840
- 21000+0.08400
- 国内价格
- 1000+0.08142
- 5000+0.08017
- 国内价格
- 20+0.22050
- 200+0.17990
- 600+0.15800
- 5000+0.10900
- 10000+0.09780
- 20000+0.09160
- 国内价格
- 20+0.11237
- 1000+0.09098
- 4000+0.07197
- 10000+0.07089
