HVA08FA500M
HVA08FA500M
    SEI
    插件,D3xL8.5mm
    插件电阻 - 500MΩ ±1% 800mW ±200ppm/℃
HVA08FA500M 数据手册
HVA Series Stackpole Electronics, Inc. High Voltage Axial Leaded Resistor Resistive Product Solutions Features: • • • • • • • • High resistance for high voltage circuits High voltage handling in small package size Metal film technology More economical than comparable high voltage resistors VCR less than 20 ppm/V RoHS compliant Halogen free REACH compliant Electrical Specifications Type/Code Power Rating (W) HVA05 HVA08 HVA12 0.5 0.8 1.2 Maximum Working Voltage (V) 3500 7000 8000 Ohmic Range (Ω) and Tolerance TCR (ppm/ºC) 1% ± 200 5% 1M - 500M 1M - 500M 1M - 500M 10% 1M - 1G 1M - 1G Rated voltage = √Power Rating x Nominal Resistance or Maximum Working voltage, whichever is lower. Mechanical Specifications Type/Code Weight (mg) HVA05 210 HVA08 330 HVA12 570 L Body Length 0.236 ± 0.008 6.00 ± 0.20 0.354 ± 0.039 9.00 ± 1.00 0.433 ± 0.039 11.00 ± 1.00 D Body Diameter 0.098 ± 0.020 2.50 ± 0.50 0.118 ± 0.020 3.00 ± 0.50 0.157 ± 0.020 4.00 ± 0.50 d Lead Diameter 0.022 ± 0.002 0.55 ± 0.05 0.022 ± 0.002 0.55 ± 0.05 0.022 ± 0.002 0.55 ± 0.05 H Lead Length (bulk) 1.102 ± 0.118 28.00 ± 3.00 1.102 ± 0.118 28.00 ± 3.00 1.102 ± 0.118 28.00 ± 3.00 Unit inches mm inches mm inches mm Performance Characteristics Item Temperature Coefficient of Resistance (ppm/ºC) Specification ±200 ppm/ºC Test Condition and Method 25°C ~ 125°C Rapid Change of Temperature ±1% -25°C (30 minutes) / +125°C (30 minutes) - 5 cycles Damp Heat (steady state) ±5% Endurance (at 70°C) ±5% Resistance to Soldering Heat Reference standards: JIS-C5201-1, IEC60115-1 Operating temperature range is -25ºC to +125ºC Rev Date: 2/25/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. ±1% 1 40 ± 2°C 93 ± 3% R.H. 0.1 x Rated Voltage 90 minutes ON, 30 minutes OFF - 1000 hours Room temperature. Rated Voltage 90 minutes ON, 30 minutes OFF - 1000 hours 260 ± 5°C, 10 ± 1 seconds www.seielect.com marketing@seielect.com HVA Series Stackpole Electronics, Inc. High Voltage Axial Leaded Resistor Resistive Product Solutions Power Derating Curve: Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Minimum 60 seconds 100°C 240°C * N/A Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Rev Date: 2/25/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com HVA Series Stackpole Electronics, Inc. High Voltage Axial Leaded Resistor Resistive Product Solutions Recommended Lead Free Resistor Reflow Profile RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Termination Type HVA High Voltage Axial Leaded Resistor Axial Standard Lead-Free Lead-Free Termination Mfg. Effective Date Series RoHS Composition (Std Product Series) Compliant 100% Matte Sn Always YES (1) Lead-Free Effective Date Code (YY/WW) Always Note (1): RoHS compliant by means of exemption 7c-I. “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Rev Date: 2/25/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com HVA Series Stackpole Electronics, Inc. High Voltage Axial Leaded Resistor Resistive Product Solutions Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order H Product Series High Voltage Axial HVA Leaded Resistor V A Size Code W 05 0.5 08 0.8 12 1.2 0 Code F J K 5 F Tolerance Tol Value 1% 5% E24 10% B Code A B 1 M Packaging Description Size 05, 08 Ammo 12 Bulk all sizes 0 0 Resistance Value Quantity 2000 1000 1000 Four characters with the multiplier used as the decimal holder. 1 Mohm = 1M00 50 Mohm = 50M0 1 Gohm = 1G00 Rev Date: 2/25/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com
HVA08FA500M 价格&库存
很抱歉,暂时无法提供与“HVA08FA500M”相匹配的价格&库存,您可以联系我们找货
