PPN320JT-73-160R
PPN320JT-73-160R
    YAGEO(国巨)
    插件
    插件电阻 160Ω ±5% 3.2W
PPN320JT-73-160R 数据手册
Approval Sheet for Precision Power Wirewound Resistor Ceramic Carrier & Axial Type PPN Series ±0.5%、±1%、±2% & ±5% YAGEO CORPORATION Headquarters: 3F, No.233-1, Pao Chiao Rd., Xindian, Taipei, Taiwan, R.O.C. Tel: 886-2-6629-9999 Fax: 886-2-6628-8885 URL: www.yageo.com Page-1 Rev. Description Issue Date Drawn Approved 00 issue new spec. May 25, 2012 Feng Ye Ken Hsu Description Precision Power Wirewound Resistors, Ceramic Carrier & Axial Type Series PPN Rev. Page-2 00 1. PRODUCT: PRECISION POWER WIREWOUND RESISTORS, CERAMIC CARRIER&CAOTED&AXIAL TYPE Body colour: Grey 2. PART NUMBER: Part number of the precision power wirewound resistor is identified by the name, power, tolerance, packing, temperature coefficient, special type and resistance value. Example: PPN 100 J T - 52- 10R (1) (2) (3) (4) (5) (6) (7) Series Power Resistance Packing Temperature Special Resistance Name Rating Tolerance Style Coefficient Type Value of Resistance (1) Style: PPN SERIES (2) Power Rating : 100=1W、160=1.6W、200=2W、250=2.5W、300=3W、350=3.5W、430=4.3W、 500=5W、650=6.5W (3) Tolerance: D=±0.5% (4) Packaging Type: F=±1% G=±2% J=±5% T=Tape on Box Packing (5) Temperature Coefficient :”-“=Base on spec. (6) Special Type: 52-=52.4mm 73-=73mm (7) Resistance Value:E24 & E96 & E192 Series Example:0.1R、 1R、10R、100R、…… Page-3 3. MARKING: Pinted in clear Yageo 1210 1W 10R J 4. ELECTRICAL CHARACTERISTICS TABLE I STYLE Power Rating at 70 ℃ Max. Cont. Work. Voltage PPN100 1W PPN160 1.6W PPN200 PPN250 PPN300 PPN350 PPN430 PPN500 PPN650 2W 2.5W 3W 3.5W 4.3W 5W 6.5W 100 85 P70 × R Thermal resistancev (℃/W) 125 65 55 Insulation Resistance Tolerances Not insulated Rmin.~Rmax.: ±5%, ±2%, ±1%; R≧1R: ±0.5% Insulation Voltage (1min.) Operating Temp. Range Max. 75V - 55 ℃ to + 350 ℃ TABLE II Resistance Range and Temperature Coeficient Temperature Coeficient STYLE 500 +400 ppm/℃ 400 ± 50 ppm/℃ Appr.+180 ppm/℃ 65 48 ±20 ppm/℃ 45 35 ±10 ppm/℃ PPN100 ---- ---- ≧0R01 ≤0R024 ≧0R027 ≤0R091 ≧0R1 ≤15R ≧16R ≤220R PPN160 ≧0R022 ≤0R033 ≧0R036 ≤0R062 ≧0R068 ≤0R091 ≧0R1 ≤160R ≧180R ≤470R PPN200 ≧0R01 ≤0R02 ≧0R022 ≤0R047 ≧0R051 ≤0R091 ≧0R1 ≤47R ≧51R ≤750R PPN250 ≧0R01 ≤0R027 ≧0R03 ≤0R075 ≧0R082 ≤0R091 ≧0R1 ≤47R ≧51R ≤750R PPN300 ≧0R015 ≤0R024 ≧0R027 ≤0R062 ≧0R068 ≤0R091 ≧0R1 ≤68R ≧75R ≤1K PPN350 ≧0R02 ≤0R03 ≧0R033 ≤0R062 ≧0R068 ≤0R091 ≧0R1 ≤130R ≧150R ≤1K5 PPN430 ≧0R027 ≤0R047 ≧0R051 ≤0R062 ≧0R091 ≤0R13 ≧0R15 ≤150R ≧160R ≤2K2 PPN500 ≧0R033 ≤0R062 ≧0R068 ≤0R013 ≧0R15 ≤0R16 ≧0R18 ≤160R ≧180R ≤2K7 PPN650 ≧0R047 ≤0R075 ≧0R082 ≤0R015 ≧0R16 ≤0R24 ≧0R27 ≤180R ≧200R ≤3K9 * Below or over this resistance on request. Page-4 5. DERATING CURVE 6. DIMENSIONS STYLE DIMENSIONS (unit: mm) Lmax. ψD* max. ψd PPN100 9.0 3.0 0.65 PPN160 9.7 4.0 0.80 14.5 4.5 0.65 PPN250 12.6 5.5 0.80 PPN300 15.0 8.5 0.80 PPN350 17.0 5.5 0.80 PPN430 18.0 8.5 0.80 PPN500 22.0 8.5 0.80 PPN650 27.0 8.5 0.80 PPN200 Page-5 7. ENVIRONMENTAL CHARACTERISTICS (1) Voltage Proof The resistor shall be clamped in the trough of a 90° metal V Block. Apply the insulation voltage specified in the “Table I “ between the terminals connected together with the block for about 60 seconds. The resistor shall be able to withstand without breakdown or flashover. (2) Temperature Coefficient Test Test of resistors above room temperature 100°C ± 2°C ( Testing Temperature 115°C to 130°C ) at the constant temperature silicon plate for over 5 minutes. Then measure the resistance value. The Temperature Coefficient is calculated by the following equation and its value should be within the range of requested. Re sistor Temperatur e Coefficient = R R0 t to R − R0 1 × × 10 6 R0 t − t0 = Resistance value under the testing temperature = Resistance value at the room temperature = The testing temperature = Room temperature (3) Solderability Immerse the specimen into the solder pot at 235 ± 5 °C for 3 ± 0.5 seconds. At least 95% solder coverage on the termination. (4) Solvent Resistance of Marking The specimen into the appropriate solvent of IPA condition of ultrasonic machine for 5± 0.5 minutes. The specimen is no deterioration of coatings and color code (5) Robustness of Terminations Direct Load – Resistors shall be held by one terminal and the load shall be gradually applied in the direction of the longitudinal axis of the resistor unit the applied load reached the requirement. The load shall be held for 10 seconds. The load of weight shall be ≧ 40N (6) Damp Heat Steady State Place the specimen in a test chamber at 40 ± 2 °C and 90 ~ 95 % relative humidity. Apply the 0.1 times rated voltage to the specimen at the 1.5 hours on and 0.5 hour off cycle. The total length of test is 56 days. The change of the resistance value shall be within ± 1.0 % (7) Endurance at 70 °C Placed in the constant temperature chamber of 70 ± 3 °C the resistor shall be connected to the lead wire at the point of 25mm. Length with each terminal, the resistors shall be arranged not much effected mutually by the temperature of the resistors and the excessive ventilation shall not be performed, for 90 minutes on and 30 minutes off under this condition the rated D.C. voltage is applied continuously for 1000+48/-0 hours then left at no-load for 1hour, measured at this time the resistance value。 The change of the resistance value shall be within ± 3.0% There shall be no remarkable change in the appearance and the color code shall be legible after the test.. (8) Resistance to Soldering Heat The terminal lead shall be dipped into the solder pot at 260 ± 3 °C for 10 ± 1.0 seconds up to 2.5 ~ 3.5 mm. The change of the resistance value shall be within ± 0.2% Page-6 8. 9. PACKAGING STYLE Packaging Pieces Pack.-code C s PPN100 taped 1000 T 65 5 PPN160 taped 1000 T 65 5 PPN200 taped 1000 T 85 10 PPN250 taped 1000 T 85 10 PPN300 taped 500 T 85 10 PPN350 taped 1000 T 85 10 PPN430 taped 500 T 85 10 PPN500 taped 500 T 85 10 PPN650 taped 500 T 85 10 Plant Address A. China Dongguan Plant 7-1, Gaoli Road, Gaoli Industrial Zone Tangxia Zhen, Dongguan, Guangdong, China (廣東省東莞市塘廈鎮高麗工業區高麗路 7-1 號) Tel. 86-769-8772 0275 Fax. 86-769-8772 0275 #4333 B. China Mudu Plant No.158, Fengjiang Road, Mudu New District, Suzhou, Kiangsu, China (江蘇省蘇州木瀆新區楓江路 158 號) Tel. 86-512-6651 8889 Fax. 86-512-6651 9889 Page-7
PPN320JT-73-160R
1. 物料型号:PPN系列,包括PPN100、PPN160、PPN200、PPN250、PPN300、PPN350、PPN430、PPN500和PPN650。
2. 器件简介:这些电阻器是精密功率绕线电阻器,具有陶瓷载体和轴向类型,颜色为灰色。
3. 引脚分配:文档中没有明确提到引脚分配,但通常这类电阻器为两端引脚。
4. 参数特性: - 功率等级:从1W到6.5W不等。 - 容差:±0.5%、±1%、±2%和±5%。 - 包装类型:T=盒装胶带包装。 - 温度系数:根据规格书。 - 特殊类型:52-=52.4mm、73-=73mm。 - 电阻值:E24、E96和E192系列。
5. 功能详解: - 电气特性表提供了不同型号的功率等级、最大连续工作电压、热阻、绝缘电阻、容差、绝缘电压和工作温度范围。 - 电阻值范围和温度系数表详细列出了不同电阻值的温度系数。
6. 应用信息:文档中没有明确提到应用信息,但通常这类电阻器用于需要精密电阻值和高功率承受能力的应用。
7. 封装信息:提供了不同型号的尺寸信息,包括最大长度、直径和引脚孔径。
PPN320JT-73-160R 价格&库存
很抱歉,暂时无法提供与“PPN320JT-73-160R”相匹配的价格&库存,您可以联系我们找货
PPN320JT-73-160R
  • 1000+1.777461000+0.23020
