FR107L
FR107L
    HOTTECH(合科泰)
    SMF(SOD-123FL)
    快恢复二极管 1.3V@1A 5uA@1kV 500ns Single 1A +150℃@(Tj) 1kV SOD-123FL
FR107L 数据手册
FR101L-FR107L Fast Recovery Diodes FEATURES     Glass passivated device Ideal for surface mouted applications Low reverse leakage Metallurgically bonded construction SOD-123FL MECHANICAL DATA     Case: SOD-123FL Case Material: Molded Plastic. UL flammability Classification Rating: 94V-0 Weight: 0.0155 grams (approximate) MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Symbol FR 101L FR 102L Repetitive Peak Reverse Voltage VRRM 50 100 200 400 RMS Voltage VRMS 35 70 140 280 Maximum DC Blocking Voltage VDC 50 100 200 400 600 Parameter FR 103L FR 104L Forward Voltage at 1.0A VF 1.3 Averaged Forward Current.Ta=65℃ (Note.1) IFAV 1 Peak Forward Surge Current TL=25℃ IFSM 30 Maximum DC Reverse Current Ta=25℃ Reverse recovery time (Note.2) FR 106L FR 107L 600 800 1000 420 560 700 800 1000 150 V μA 50 trr Unit A 5 IR Ta=125℃ FR 105L 250 500 ns Cj 4 pF RθJA 180 ℃/W Junction Temperature Tj 150 Storage Temperature Tstg -55 to 150 Typical Junction Capacitance (Note.3) Typical Thermal Resistance (Note.4) ℃ Note.1: Averaged over any 20ms period. Note.2: Measured with IF=0.5A, IR=1A, Irr=0.25A. Note.3: Measured at 1MHz and applied reverse voltage of 4.0V D.C. Note.4: Thermal resistance junction to ambient, 6.0 mm2 coppeer pads to each terminal. Marking NO. FR101L FR102L FR103L FR104L FR105L FR106L FR107L Marking F1 F2 F3 F4 F5 F6 F7 © SHENZHEN HOTTECH ELECTRONICS CO.,LTD E-mail:hkt@heketai.com 1/4 FR101L-FR107L Fast Recovery Diodes Typical Characteristics FIG.2 -- TYPICAL JUNCTION CAPACITANCE 100 10 T J =25 Pulse Width=300us 4 10 9 1.0 0.4 0.2 0.1 0.06 0.04 0.02 0.01 8 CAPACITANCE, pF AMPERES 2 0.6 0.8 1.0 1.2 1.4 7 6 5 4 3 2 1 0 1.6 INSTANTANEOUS FORWARD VOLTAGE,V T J = 150 ° C T J = 125 ° C T J = 100 ° C 1 T J = 75 ° C T J = 50 ° C 0.1 T J = 25 ° C 0.01 0 100 200 300 400 500 600 700 800 5 10 15 20 25 30 35 40 900 INSTANTANEOUS REVERSE VOLTAGE,V FIG.4 -- FORWARD DERATING CURVE AVERAGE FORWARD CURRENT, AMPERES 100 10 0 REVERSE VOLTAGE,VOLTS FIG.3 -- TYPICAL INSTANTANEOUS REVERSE CHARACTERISTICS µ AMPERES NSTANTANEOUS REVERSE CURRENT INSTANTANEOUS FORWARD CURRENT FIG.1 --TYPICAL FORWARD CHARACTERISTIC 1.0 0.8 0.6 0.4 0.2 0 0 25 50 75 100 125 150 175 AMBIENT TEMPERATURE, E-mail:hkt@heketai.com 2/4 FR101L-FR107L Fast Recovery Diodes SOD-123FL Package Outline Dimensions Symbol Dimensions In Millimeters Min. Max. A 0.75 B Dimensions In Inches Max. 0.95 Min. 0.029 1.60 2.00 0.063 0.079 C 2.60 3.00 0.103 0.119 D 0.90 1.20 0.036 0.047 E 0.12 0.22 0.005 0.009 F G 0.8Typ 3.50 0.037 0.032Typ 3.90 0.138 0.159 SOD-123FL Suggested Pad Layout Note: 1.Controlling dimension: in millimeters 2.General tolerance: ±0.05mm 3.The pad layout is for reference purposes only E-mail:hkt@heketai.com 3/4 FR101L-FR107L Fast Recovery Diodes SOD-123FL Tape and Reel SOD-123FL Embossed Carrier Tape DIMENSIONS ARE IN MILLIMETER TYPE A B C d E F P0 P P1 W SOD-123FL 2.10 4.00 1.25 Ø1.50 1.75 3.50 4.00 4.00 2.00 8.00 TOLERANCE ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 SOD-123FL Tape Leader and Trailer SOD-123FL Reel DIMENSIONS ARE IN MILLIMETER REEL OPTION 7’’ DIA TOLERANCE D D1 D2 G H I W1 W2 Ø178 54.40 13.00 R78 R25.60 R6.50 9.50 12.30 ±2 ±1 ±1 ±1 ±1 ±1 ±1 ±1 © SHENZHEN HOTTECH ELECTRONICS CO.,LTD E-mail:hkt@heketai.com 4/4
FR107L 价格&库存
很抱歉,暂时无法提供与“FR107L”相匹配的价格&库存,您可以联系我们找货
FR107L
  • 5+0.03026
  • 20+0.02759
  • 100+0.02492
  • 500+0.02225
  • 1000+0.02100
  • 2000+0.02011
FR107L
  • 5+0.03690
  • 20+0.03440
  • 100+0.03190
  • 500+0.02950
  • 1000+0.02700
  • 2000+0.02460
FR107L
  • 1+0.16060
  • 200+0.05357
  • 1500+0.03344
  • 3000+0.02662
库存:5519
FR107L
  • 50+0.06906
  • 500+0.05304
  • 3000+0.04864
  • 6000+0.04330
  • 24000+0.03868
  • 51000+0.03623
库存:1522
FR107L
  • 1+0.08140
  • 100+0.07940
库存:5
