BAT46W
BAT46W
    JINGDAO(晶导微电子)
    SOD-123
    肖特基二极管 SOD123 VRRM=100V IF=150mA VF=1V
BAT46W 数据手册
山东晶导微电子股份有限公司 BAT46W Jingdao Microelectronics co.LTD SCHOTTKY BARRIER RECTIFIERS PINNING FEATURES PIN • High breakdown voltage • Low turn-on voltage DESCRIPTION 1 Cathode 2 Anode • Guard ring construction for transient protection 2 MECHANICAL DATA ▪Case: SOD-123 ▪Terminals: Solderable per MIL-STD-750, Method 2026 ▪ Approx. Weight:16mg/0.00056oz 1 Top View Marking Code: S9 Simplified outline SOD-123 and symbol Maximum Ratings at 25 °C Symbols BAT46W Units Maximum Repetitive Peak Reverse Voltage V RRM 100 V Working peak reverse voltage V RWM 100 V Continuous Forward Current IF 150 mA I FRM 350 mA I FSM 25 A PD 200 mW Thermal resistance junction to ambient air R thJA 500 °C/W Operating and Storage Temperature Range T j , T stg -55 ~ +125 °C Symbols BAT46W Units V (BR)R 100 V VF 0.45 1.0 V Peak Reverse Current V R1 =1.5V V R2 =10V V R3 =50V V R4 =75V IR 0.3 0.5 1 2 μA Diodes Capacitance V R =0,f=1MHz V R =1V,f=1MHz CT 20 12 pF Parameter Repetitive peak forward current (Note 1) @ tp < 1.0s, Duty Cycle < 50% Non-reptitive Peak Forward Surge Current at 8.3ms Power Dissipation ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Reverse Breakdown Voltage at I R=100 μA(NOTE 2) Maximum Forward Voltage (NOTE 2) I F1 =10 m A I F2 = 250 m A NOTES: (1) Part mounted on FR-4 board with recommended pad layout. (2)Short duration pulse test used to minimize self-heating effect. 2018.06 SOD123-S-BAT46W-150mA100V Page 1 of 3 山东晶导微电子股份有限公司 BAT46W Jingdao Microelectronics co.LTD Fig.2 Typical Reverse Characteristics 0.30 1000 Reverse Current ( uA) POWER DISSIPATION PD (W) Fig.1 Power Derating Curve 0.25 0.20 0.15 0.10 0.05 T J =100°C 100 10 T J =25°C 1.0 0.00 0.1 25 75 50 100 125 150 0 Ambient temperature Ta(℃) Junction Capacitance ( pF) Ta = 00 =1 2 5° C °C 100 Ta 100 100 T J =25°C f=1MHz 10 1 1 0 0.1 0.2 0.3 0.4 1.0 0.5 36 30 24 18 12 06 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 10 20 30 Reverse Voltage (V) INSTANTANEOUS FORWARD VOLTAGE, VOLTS Transient Thermal Impedance( °C /W) INSTANTANEOUS FORWARD CURRENT (mA) Peak Forward Surage Current (A) 80 Fig.3 Typical Junction Capacitance Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6 Typical Transient Thermal Impedance 2000 1000 100 10 0.01 Number of Cycles at 60Hz 2018.06 60 Reverse Voltage VR (V) Fig.2 TYPICAL FORWARD VOLTAGE 10 40 20 0.1 1 10 100 t, Pulse Duration(sec) www.sdjingdao.com Page 2 of 3 山东晶导微电子股份有限公司 BAT46W Jingdao Microelectronics co.LTD PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123 A D b E A1 C ∠ALL ROUND L1 E1 SOD-123 mechanical data A C D E E1 L1 b A1 max 1.3 0.22 1.8 2.8 3.9 0.45 0.7 0.2 min 0.9 0.09 1.5 2.5 3.6 0.25 0.5 max 51 8.7 71 110 154 18 28 min 35 3.5 59 98 142 10 20 UNIT ∠ mm 9° 8 mil The recommended mounting pad size 2.0 (79) 1.2 (47) Type number Marking code BAT46W S9 1.2 (47) 1.2 (47) Marking Unit: mm (mil) 2018.06 806222A8 Page 3 of 3
BAT46W
物料型号为BAT46W,是一款肖特基势垒整流器。
器件简介包括高击穿电压、低导通电压和用于瞬态保护的保护环结构。
引脚分配为PIN 1为阴极,PIN 2为阳极。
参数特性包括最大重复峰值反向电压100V,工作峰值反向电压100V,连续正向电流150mA,重复峰值正向电流350mA,非重复峰值正向浪涌电流25A,功率耗散200mW,结到环境空气的热阻500°C/W,工作和存储温度范围-55°C至+125°C。
功能详解涉及电气特性,包括反向击穿电压、最大正向电压、反向峰值电流和结电容等。
应用信息未在文档中明确说明,但通常用于需要高效率整流的应用。
封装信息为SOD-123,是一种塑料表面贴装封装,具有两个引脚。
BAT46W 价格&库存
很抱歉,暂时无法提供与“BAT46W”相匹配的价格&库存,您可以联系我们找货
BAT46W
  • 20+0.14397
  • 200+0.11362
  • 600+0.09677
库存:147
