MB1S THRU MB10S
Voltage Range - 100 to 1000 V olts
Current - 0.8 Ampere
SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS
Features
PINNING
PIN
DESCRIPTION
Ideal for printed circuit board
1
Input Pin(~)
Reliable low cost construction utilizing molded plastic technique
2
Input Pin(~)
High temperature soldering guaranteed: 260°/10 seconds at 5
lbs., (2.3kg) tension
3
Output Anode(+)
4
Output Cathode(-)
MBS
Small size, simple installation
High surge current capability
3
4
Mechanical Data
MBxxS
1
2
Case : JEDEC MBS Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.008 ounce, 0.22 grams
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
MB1S
MB2S
MB4S
MB6S
MB8S
MB10S
UNITS
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
VRMS
VDC
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
Maximum average forward rectified current
at TC=30
On glass-epoxy P.C.B.
On aluminum substrate
IF(AV)
Peak forward surge current,
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward
at=0.4A
voltage drop per leg
TA=25°C
Maximum DC reverse current
at rated DC blocking voltage
TA=125°C
0.5
A
0.8
IFSM
30
A
VF
1.0
V
IR
5
0.5
uA
mA
CJ
13
PF
Typical thermal resistance
RθJC
70
°C/W
Operating temperature range
TJ
TSTG
-55 to +150
-55 to +150
°C
°C
Typical junction capacitance
storage temperature range
(Note 3)
NOTES:1.On glass epoxy P.C.B. mounted on 0.05x0.05''(1.3x1.3mm) pads
2.On aluminum substrate P.C.B. with on area of 0.8''x0.8''(20x20mm) mounted on 0.05X0.05''(1.3X1.3mm) solder pad
3.Measured at 1.0MHz and applied reverse voltage of 4.0 volts.
www.tw-gmc.com
1
MB1S THRU MB10S
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current(μ A)
Average Rectified Output Current (A)
Fig.1 Average Rectified Output Current
Derating Curve
1.2
1.0
0.8
0.6
0.4
0.2
Resistive or Inductive Load
0.0
25
50
75
100
125
150
175
100
T J =125°C
10
1.0
T J =25°C
0.1
00
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
1.0
1.5
2.0
Peak Forward Surage Current (A)
80
100
100
120
140
T J =25°C
10
0.1
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
10
1.0
10
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
100
Number of C cles
www.tw-gmc.com
60
1
0.5
Instaneous Forward Voltage (V)
1
40
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
0.01
0.0
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
10
2
100
MB1S THRU MB10S
PACKAGE OUTLINE
Plastic surface mounted package; 4 leads
MBS
A
∠ALL ROUND
C
a
L1
L
d
HE
e
D
e
E
MBS mechanical data
A
C
D
E
HE
d
e
L
L1
a
max
2.6
0.22
5.0
4.1
7.0
2.7
0.7
1.7
1.1
0.2
min
2.2
0.15
4.5
3.6
6.4
2.3
0.5
1.3
0.5
max
102
8.7
197
161
276
106
28
67
43
min
94
5.9
177
142
252
91
UNIT
mm
7°
mil
6.0
236
2.5
100
0.9
35
2.4
94
www.tw-gmc.com
mm
Unit :
(mil)
3
8
很抱歉,暂时无法提供与“MB10S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.15195
- 500+0.12518
- 3000+0.08639
- 6000+0.07746
- 24000+0.06977
- 51000+0.06557
- 国内价格
- 20+0.13928
- 300+0.11474
- 1200+0.11302
- 3000+0.07919
- 国内价格
- 1+0.38830
- 200+0.12980
- 1500+0.08085
- 3000+0.06413
