MPR5JB15L0
MPR5JB15L0
    SEI
    插件电阻 - 15mΩ ±5% 5W ±350ppm/℃
MPR5JB15L0 数据手册
MPR Series Stackpole Electronics, Inc. Flameproof Metal Plate Resistor Resistive Product Solutions Features: • • • • • • Small size with high power ratio Low resistance values and low inductance Crimped leads keep circuit board temperatures cooler 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical Specifications Type / Code Power Rating (W) @ 70ºC Maximum Working Voltage (V) MPR3 MPR5 3 5 350 Maximum Overload Voltage (V) TCR (ppm/ºC) 700 ± 350 Ohmic Range (Ω) and Tolerance 5%, 10% 0.01 - 0.47 Mechanical Specifications L Type / Code MPR3 MPR5 0.551 14.00 0.551 14.00 ± ± ± ± W 0.059 1.50 0.059 1.50 0.197 5.00 0.197 5.00 ± ± ± ± H 0.039 1.00 0.039 1.00 0.394 10.00 0.709 18.00 ± ± ± ± d 0.039 1.00 0.039 1.00 0.031 0.80 0.031 0.80 ± ± ± ± P 0.004 0.10 0.004 0.10 0.394 10.00 0.394 10.00 ± ± ± ± Unit 0.039 1.00 0.039 1.00 inches mm inches mm Performance Characteristics Test Short Time Overload Dielectric Withstanding Voltage Thermal Shock Temperature Coefficient Load Life Load Life with Humidity Operating temperature range is -55°C to 275°C Test Limit ΔR ≤ (2% Ro + 0.05Ω) 500V ΔR ≤ (2% Ro + 0.05Ω) ± 350 ppm/ºC ΔR ≤ (3% Ro + 0.05Ω) ΔR ≤ (3% Ro + 0.05Ω) Test Method (JIS C 5201-1) 2.5X, 5 seconds 5.7 4.19 4.8 4.25 4.23 Power Derating Curve: Rev Date: 12/03/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com MPR Series Stackpole Electronics, Inc. Flameproof Metal Plate Resistor Resistive Product Solutions Load Factor: Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Minimum 60 seconds 100°C 240°C * N/A Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Rev Date: 12/03/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com MPR Series Stackpole Electronics, Inc. Flameproof Metal Plate Resistor Resistive Product Solutions Recommended Lead Free Resistor Reflow Profile RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series MPR Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) Flameproof Rectangular Type Metal Plate Resistor Radial Special YES 100% Matte Sn Always Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Rev Date: 12/03/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com MPR Series Stackpole Electronics, Inc. Flameproof Metal Plate Resistor Resistive Product Solutions Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 M P R 3 J B 1 0 L 0 Product Series Flameproof MPR Metal Plate Power Rating Size W 3 3 5 5 Tolerance Code Tol J 5% K 10% Rev Date: 12/03/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. Code B 4 Packaging Description Size Bulk All Sizes Quantity 2000 Resistance Value Four characters with the multiplier used as the decimal holder. "L" used as multiplier of 10-3 for any value under 0.1 ohm. 0.01 ohm = 10L0 0.1 ohm = R100 0.47 ohm = R470 www.seielect.com marketing@seielect.com
MPR5JB15L0 价格&库存
很抱歉,暂时无法提供与“MPR5JB15L0”相匹配的价格&库存,您可以联系我们找货
