NS1100
NS1100
    NEWYEA(厦门新页)
    无线充电发射模块 50-150KHz
NS1100 数据手册
REVISION Rev.1 (版本) DATE 2017.06.22 (日期) Product Name 产品名称 PART NUMBER (产品型号) 100W 单线 圈系统 NS1100 APPROVAL SHEET (承 认 书) FOR WIRELESS CHARGER (无线充) MODEL NO. (型号) MANUFACTURER (制 造 商) EDIT CONFIRM (制 订) (确认) CUSTOMER APPROVAL (审核) APPROVAL (批准) Stamp(签章) (客户承认)  CHECK Company Add: The 11#Floor,Hesheng Building,No.8,Jinshan Road,siming District,Xiamen,China  Tel:(86-592)6882776  Fax: (86-592)6882986  Website: http://www.xmnewyea.com Page 1 of 6 REVISION Rev.1 (版本) DATE 2017.06.22 (日期) Product Name 产品名称 REV (版本) A 100W 单线 圈系统 PART NUMBER (产品型号) REVISION CHANGE DESCRIPTION (版本变更描述) UPDATE (变更) DETAIL (详述) / / Page 2 of 6 NS1100 DATE (日期) REVISION Rev.1 (版本) DATE 2017.06.22 (日期) Product Name 产品名称 100W 单线 圈系统 PART NUMBER (产品型号) NS1100 CONTENTS 1. Apply Scope(适用范围)................................................................................ 4 2. Environment Protection Laws(符合的环保法规).................................... 4 3. According with Safety and EMC Criterion(符合的安全及电磁兼容标准) 4 4. Safety and EMC Approval(符合的安全及电磁兼容标准)........................4 5. Electrical Characteristic (电气特性)............................................................... 4 6. Input Characteristics(输入特性).................................................................5 6.1 6.2 6.3 6.4 6.5 6.6 Rated Input Voltage(额定输入电压)........................................................................5 Input Voltage Range (输入电压范围).......................................................................... 5 Input Frequency (输入频率).......................................................................................... 5 Steady DC Current(DC 输入电流)........................................................................... 5 Standby(待机功耗)................................................................................................... 5 Efficiency(效率)........................................................................................................5 7.1 7.2 7.3 7.4 7.5 7.5.1 Rated Output Voltage(输出额定电压)..................................................................... 5 Output Voltage(输出电压范围)................................................................................5 Rated Output Current(额定输出电流)......................................................................6 LED Lights Instruction (LED 显示说明).......................................................................6 Protection (保护)....................................................................................................... 6 Overvoltage Protection (过压保护).......................................................................... 6 7. Output Characteristics(输出特性)............................................................. 5 7.5.2 Insufficient power supply Protection (供电不足保护)............................................ 6 7.5.3 Foreign-Object Detection Protection (异物检测保护).............................................6 Page 3 of 6 REVISION Rev.1 (版本) DATE 2017.06.22 (日期) Product Name 产品名称 PART NUMBER (产品型号) 100W 单线 圈系统 NS1100 1. Apply Scope(适用范围) This specification shall be applied to Wireless charger 36V/2.8A.本规格适用于 36V/2.8A 无线充 电器。 2. Environment Protection Laws(符合的环保法规) □RoHS □REACH □CPSIA □EN71 □PHTHALATE □HALOGEN 3. According with Safety and EMC Criterion(符合的安全及电磁兼容标 准) □EN60950-1 □EN61558-1 □EN60065-1 □EN55022 □UL60950-1 □UL1310 □UL60065-1 □EN55024 □GB4943.1-2011 □GB9254-2008 □WPC1.2 4. Safety and EMC Approval(符合的安全及电磁兼容标准) □CB □ TUV/GS □CE □PSE □UL □FCC □SAA □C-tick □KC □CCC □TLC □E-mark 5. Electrical Characteristic (电气特性) Test Circuit (测试电路) If the test is to be made on a specified circuit, be sure to use the following circuit. (无特殊规定的情况下依照下面的电路进行测试.) AC-DC Adaptor (24V/5A) AC-DC 适配器(24V/5A) Wireless charger TX 无线充电器发射端 工作模式:电磁感应式(单线圈) 输入:24V/5A 以上 Wireless charger RX 无线充电器接收端 工作频率:50-150KHz 输出:36V/2.8A (可调) 有效工作距离: Coil 50mm*50mm: 推荐工作距离 5-9mm Coil 100mm*100mm: 推荐工作距离 13-22mm Coil 150mm*150mm: 推荐工作距离 20-32mm 尺寸:发射模组 PCBA:140mm*73.5mm*1.6mm 线圈:150mm*150mm*10mm 接收模组 PCBA:70mm*70mm*1.6mm 线圈:150mm*150mm*10mm 智能/异物检测:支持 过流保护:可选 过温检测:支持 Page 4 of 6 Electronic Load 电子负载仪 REVISION Rev.1 (版本) DATE 2017.06.22 (日期) Product Name 产品名称 100W 单线 圈系统 PART NUMBER (产品型号) NS1100 指示灯:支持 蜂鸣器:支持(可选) 6. Input Characteristics(输入特性) 6.1 Rated Input Voltage(额定输入电压) Rated input voltage is 24Vdc ( 额定输入直流 24V) 6.2 Input Voltage Range (输入电压范围) Input voltage range is from 23.5Vdc to 24.5Vdc. (输入电压范围直流 23.5V~24.5V) 6.3 Input Frequency (输入频率) It is normal for 50Hz or 60Hz and single phase. (输入频率 50Hz/60Hz) 6.4 Steady DC Current(DC 输入电流) Maximum steady state input current is 5A(Min)Measured at 24Vdc input and maximum load. (24V 满载时输入电流 5A(Min)) 6.5 Standby(待机功耗) The input power shall be less than 0.5W at 115Vac and 230Vac input. (在输入电压 115V 和 230V 时待机功耗小于 0.5W) 6.6 Efficiency(效率) The efficiency is 88% Min (not including the adaptor loss) 效率不低于 88% (不包括适配器损耗) ) 7. Output Characteristics(输出特性) 7.1 Rated Output Voltage(输出额定电压) The rated output voltage is specified at 36V(可调) (额定输出电压 36V) 7.2 Output Voltage(输出电压范围) Page 5 of 6 REVISION Rev.1 (版本) DATE 2017.06.22 (日期) Product Name 产品名称 100W 单线 圈系统 PART NUMBER (产品型号) NS1100 No load voltage (空载输出电压范围): 36V ~ 36.8V (可调) Full load voltage (满载输出电压范围): 36V ~ 36.8V(I=2800mA) 7.3 Rated Output Current(额定输出电流) The output current will be performed from 0mA~2800mA at CC (在 CC:模式下,额定输出电流 0mA~2800mA) 7.4 LED Lights Instruction (LED 显示说明) Stand-by Mode:The Red、Yellow、Green LED lights in turns. (待机状态:红黄绿三灯依次交替闪烁。) Loading Mode: The Green LED always ON. (带载状态:绿灯常亮。) Fault Mode:The Red LED ON,system will restart in 10S. (故障状态:红灯亮,10s 后自动重启。) 7.5 Protection (保护) 7.5.1 Overvoltage Protection (过压保护) When the input voltage exceeds 24.5V,system will open its self protection mode and restart in 10S. (输入电压超过 24.5V 则自动保护,10s 后重启。)(过压值可设置) 7.5.2 Insufficient power supply Protection (供电不足保护) When the maximum current from power supply is not enough, system will enter selfprotection mode and restart in 10S. (当供电源提供的最大电流不足时自动保护,10S 后重启。) 7.5.3 Foreign-Object Detection Protection (异物检测保护) When foreign object is detected,system will enter self-protection mode and restart in 10S. 当检测到异物时自动保护,10S 后重启。(可设置异物检测灵敏度等级) Page 6 of 6
NS1100 价格&库存
很抱歉,暂时无法提供与“NS1100”相匹配的价格&库存,您可以联系我们找货
NS1100
