NR1005X03
NR1005X03
    NEWYEA(厦门新页)
    无线充电发射模块 110-205KHz
NR1005X03 数据手册
REVISION Rev 1.1 (版本) DATE 2016.12.28 (日期) Product Name 产品名称 5W 无线接 收端 PART NUMBER (产品型号) NR1005X03 APPROVAL SHEET (承 认 书) FOR WIRELESS CHARGER RECEIVER (无线充电接收器) MODEL NO. (型号) NR1005X03 EDIT CHECK APPROVAL (制 订) (审核) (批准) CUSTOMER APPROVAL (客户承认)  Stamp(签章) Company Add: The 11#Floor,Hesheng Building,No.8,Jinshan Road,siming District,Xiamen,China  Tel:(86-592)6882776  Fax: (86-592)6882986  Website: http://www.xmnewyea.com Page 1 of 6 REVISION Rev 1.1 (版本) DATE 2016.12.28 (日期) Product Name 产品名称 5W 无线接 收端 PART NUMBER (产品型号) NR1005X03 REVISION CHANGE DESCRIPTION (版本变更描述) REV (版本) UPDATE (变更) DETAIL (详述) DATE (日期) Rev 1.0 / / 2016.08.15 Rev 1.1 更新 老化测试、插拔实验 2016.12.28 Page 2 of 6 REVISION Rev 1.1 (版本) DATE 2016.12.28 (日期) Product Name 产品名称 5W 无线接 收端 PART NUMBER (产品型号) NR1005X03 CONTENTS 1. Apply Scope(适用范围) .......................................................................................... 4 2. Environment Protection Laws(环保法规)............................................................. 4 3. According with Safety and EMC Criterion(符合的安全及电磁兼容标准)............ 4 4. Safety and EMC Approval(已认可的安全及电磁兼容标准) ................................... 4 5. Electrical Characteristic (电气特性) .......................................................................... 4 6. Output Characteristics(输出特性) ......................................................................... 5 6.1 Rated Output Voltage(输出额定电压).................................................................................... 5 6.2 Output Voltage(输出电压范围) ............................................................................................... 5 6.3 Rated Output Current(额定输出电流) ..................................................................................... 5 6.4 Protection (保护) .................................................................................................................... 5 Short Circuit Protection(短路保护) .............................................................................................. 5 7. Reliability Items (信赖性项目) .................................................................................... 5 7.1 Aging Test (老化测试) .......................................................................................................... 5 8. Mechanical Requirement (机械要求) .................................................................... 5 8.1 Dimension(尺寸) .................................................................................................................... 5 8.2 USB Plug Type(USB 接口类型).............................................................................................. 5 8.3 Insert-extract Test (插拔实验) ..................................................................................................... 6 9. Environmental Performances(环境性能) .................................................................. 6 9.1 Operating temperature range(工作温度范围).............................................................................. 6 9.2 Stored temperature range(存储温度范围) ................................................................................... 6 Page 3 of 6 REVISION Rev 1.1 (版本) DATE 2016.12.28 (日期) Product Name 产品名称 5W 无线接 收端 PART NUMBER (产品型号) NR1005X03 1. Apply Scope(适用范围) This specification shall be applied to Wireless charger 5V,1A.Sensing distance of less than 10mm 本规格适用于 5V/1A 无线充电器。感应距离≤10mm。 2. Environment Protection Laws(符合的环保法规) √RoHS □REACH □CPSIA □EN71 □PHTHALATE □HALOGEN 3. According with Safety and EMC Criterion(符合的安全及电磁兼容标 准) □EN60950-1 □EN61558-1 □EN60065-1 □EN55022 □UL60950-1 □UL1310 □UL60065-1 □EN55024 □GB4943.1-2011 □GB9254-2008 √WPC1.2 4. Safety and EMC Approval(符合的安全及电磁兼容标准) □CB □ TUV/GS √CE □PSE □UL √FCC □SAA □C-tick □KC □CCC □TLC □E-mark 5. Electrical Characteristic (电气特性) Test Circuit (测试电路) If the test is to be made on a specified circuit, be sure to use the following circuit. (无特殊规定的情况下依照下面的电路进行测试.) AC-DC Adaptor (5V/2A) AC-DC 适配器(5V/2A) Wireless charger TX 无线充电器发射端 工作模式:电磁感应式(单线圈) 输出:5V/1A Wireless charger RX 无线充电器接收端 工作协议:WPC1.2 工作频率:110-205KHz 有效工作距离:≤ 10mm (推荐工作距离 3-5mm) 智能检测:支持 过流保护:支持 过温保护:支持 指示灯:支持(可选) 支持认证:QI、CE、FCC、RoHS Page 4 of 6 Electronic Load 电子负载仪 REVISION Rev 1.1 (版本) DATE 2016.12.28 (日期) Product Name 产品名称 5W 无线接 收端 PART NUMBER (产品型号) NR1005X03 6. Output Characteristics(输出特性) 6.1 Rated Output Voltage(输出额定电压) The rated output voltage is specified at 5V (额定输出电压 5V) 6.2 Output Voltage(输出电压范围) No load voltage (空载输出电压范围): 4.75V ~ 5.25V Full load voltage (额定输出电压范围): 4.75V ~ 5.25V(I=1000mA) 6.3 Rated Output Current(额定输出电流) The output current will be performed from 0mA~1000mA at CC (在 CC:模式下,额定输出电流 0mA~1000mA) 6.4 Protection (保护) Short Circuit Protection(短路保护) Output short-circuit when the charger output hiccup mode (输出短路时充电器输出打嗝模式) 7. Reliability Items (信赖性项目) 7.1 Aging Test(老化测试) At normal temperatures,with full load operation for 96 hours,performace will be normal (常温常环境下,满载工作 96 小时,性能正常) 8. Mechanical Requirement (机械要求) 8.1 Dimension(尺寸) 90*32*6 mm 8.2 Micro USB Plug Type(Micro USB 接口类型) Plug: Micro 5pin USB (Micro 5pin USB) Page 5 of 6 REVISION Rev 1.1 (版本) DATE 2016.12.28 (日期) Product Name 产品名称 5W 无线接 收端 PART NUMBER (产品型号) NR1005X03 8.3 Insert-extract Test (插拔实验) Insert in and extract our continuously 1000 times,slight damage in exterior,but unusually electrical function is prohibited. (连续拔插 1000 次,外观允许有轻度损伤,但不允许有电性能异常) 9. Environmental Performances(环境性能) 9.1 Operating temperature range(工作温度范围) The product should operate at -10~55℃, test of operating for 8 hours at -10℃±2℃ and 55℃±2℃. (该产品工作温度范围为-10~55℃,低温-10℃±2℃和高温 55℃±2℃工作试验各 8 小时) 9.2 Stored temperature range(存储温度范围) The product should be stored at -20~70℃ ,test of non-operated for 24 hours at -20℃±2℃ and 70℃±2℃. (该产品存储温度范围为-20~70℃, 非工作状态下进行低温-20℃±2℃和高温 70℃±2℃存储试 验各 24 小时). Page 6 of 6
NR1005X03 价格&库存
很抱歉,暂时无法提供与“NR1005X03”相匹配的价格&库存,您可以联系我们找货
NR1005X03
