CETC1030-A
CETC1030-A
    ECRIEE(博微电气)
    IND_11.5X10MM_SM
    贴片电感 CETC1030-A Ecriee 11.5mm*10.0mm*3.1mm
CETC1030-A 数据手册
COMPOSITE FORMING SMD INDUCTORS CETC-A TYPE Features RoHS compliant* and halogen free** lowest DCR/uH,in this package size. High saturation current Frequency range up to 1.0MHZ. Ultra low buzz noise,due to composite construction. Applications Notebook/Desktop/Server applications. low profile,high current power supplies. Battery powered devices. DC/DC converters. Product identification CETC XXXX - XXX M - A ① ② ③ ① Product Code ④ ⑤ ② Size: L×W (mm) ③ Inductance Value ④ Tolerance: J±5%, K±10%, L±15% , M±20%, P± 25%, N±30% Product Dimensions(02) [unit: mm] ⑤ Category Recommended Layout [unit: mm] G F H 型号 A B C D F G H CETC 02010 2.0± 0.2 1.6± 0.2 1.0Max 0.5 ± 0.3 2.3 1.6 0.9 Recommended Layout [unit: mm] Product Dimensions(03、04、05) [unit: mm] E E A F B G C XXXX D H 型号 A B C D E F G H CETC 0315 3.6Max 3.0± 0.2 1.5Max 0.6 ± 0.2 0.76± 0.3 4.2 1.2 1.2 CETC 0320 3.6Max 3.0± 0.2 2.0Max 0.6 ± 0.2 0.76± 0.3 4.2 1.2 1.2 CETC 0420 4.45± 0.25 4.06± 0.25 2.0Max 1.5 ± 0.5 0.76± 0.3 5.2 2.5 2.2 CETC 0530 5.8 Max 5.18± 0.25 3.0Max 2.2 ± 0.3 1.2 ± 0.3 5.99 2.5 2.5 Product Dimensions(06、10、12) [unit: mm] Recommended Layout [unit: mm] G F H 型号 A B C D E F G H CETC 0618 7.4 Max 6.6± 0.2 1.8Max 3.0 ± 0.3 1.6 ± 0.4 8.0 3.6 3.6 CETC 0624 7.4 Max 6.6± 0.2 2.4Max 3.0 ± 0.3 1.6 ± 0.4 8.0 3.6 3.6 CETC 0630 7.4 Max 6.6± 0.2 3.0Max 3.0 ± 0.3 1.6 ± 0.4 8.0 3.6 3.6 CETC 1030 11.5 Max 10± 0.5 3.1Max 3.0 ± 0.5 2.2 ± 0.4 13.6 4.1 5.4 CETC 1040 11.5 Max 10± 0.5 4.0Max 3.0 ± 0.5 2.2 ± 0.4 13.6 4.1 5.4 CETC 1250 14 Max 12.6± 0.2 5.0Max 3.8± 0.3 2.0± 0.5 14.5 5.0 8.0 CETC 1270 14 Max 12.6± 0.2 7.0Max 3.8± 0.3 2.0± 0.5 14.5 5.0 8.0 Specification table CETC02010-A series 1MHz 0.25V P/N CETC 02010-R68 N-A D.C.R (mΩ) Heat Rating Current Saturation Current L0(μH) ±30% '@0A Typical Max Idc (Amp) Typical Isat (Amp) Typical 0.68 52 65 2.5 2.6 CETC 02010-1R0 N-A 1 65 70 2.1 2.5 CETC 02010-1R5 N-A 1.5 115 140 1.8 2 CETC 02010-2R2 N-A 2.2 140 150 1.3 1.6 Heat Rating Current Saturation Current CETC0315-A series 100KHz 0.25V P/N D.C.R (mΩ) L0(μH) ±20% '@0A Typical Max Idc (Amp) Typical Isat (Amp) Typical CETC 0315-R22 M-A 0.22 10 12 8.5 12 CETC 0315-R33 M-A 0.33 12.5 15 7.8 9 CETC 0315-R47 M-A 0.47 19 22 5 6.5 CETC 0315-R56 M-A 0.56 23 27 5 7 CETC 0315-2R2 M-A 2.2 85 97 2 3.5 Heat Rating Current Saturation Current Idc (Amp) Typical Isat (Amp) Typical CETC0320-A series 100KHz 0.25V P/N L0(μH) ±20% '@0A D.C.R (mΩ) Typical Max CETC 0320-R33 M-A 0.33 14 17 5.5 8.3 CETC 0320-R47 M-A 0.47 18 22 4.8 8 CETC 0320-R68 M-A 0.68 22 27 4.5 6 CETC 0320-1R0 M-A 1.0 28 32 4 5 CETC 0320-1R5 M-A 1.5 34 40 3.7 4.5 CETC 0320-2R2 M-A 2.2 67 80 3 4.3 CETC 0320-3R3 M-A 3.3 99 114 2.2 4.2 CETC 0320-4R7 M-A 4.7 132 152 2.5 3.5 CETC 0320-6R8 M-A 6.8 168 193 1.6 2.85 • All test data is referenced to 25°C ambient • DC current (Idc) that will cause an approximate △ T of 40℃ • DC current (Isat) that will cause Lo to drop approximately 30% • Operating temperature Range: –40°C to +85°C CETC0420-A series 100KHz 0.25V P/N D.C.R (mΩ) Heat Rating Current Saturation Current L0(μH) ±20% '@0A Typical Max Idc (Amp) Typical Isat (Amp) Typical CETC 0420-R10 M-A 0.1 3.5 4.0 12 22 CETC 0420-R22 M-A 0.22 6.00 6.6 9.5 12 CETC 0420-R47 M-A 0.47 12.5 14 7.5 12 CETC 0420-R56 M-A 0.56 14 16 7.5 10 CETC 0420-R68 M-A 0.68 18 20.0 7.5 9 CETC 0420-1R0 M-A 1.0 24.0 27 6 7 CETC 0420-1R5 M-A 1.5 38 46.0 5 6 CETC 0420-2R2 M-A 2.2 52 58.0 4 5 CETC 0420-3R3 M-A 3.3 74 87.0 3 4 CETC 0420-4R7 M-A 4.7 92 110 2.5 3.5 CETC 0420-6R8 M-A 6.8 160 175 2.4 2.8 CETC 0420-8R2 M-A 8.2 200 215 2 2 CETC 0420-100 M-A 10 256 286 1.6 2 Heat Rating Current Saturation Current Idc (Amp) Typical Isat (Amp) Typical CETC0530-A series 100KHz 0.25V P/N L0(μH) ±20% '@0A D.C.R (mΩ) Typical Max CETC 0530-R20 M-A 0.2 3.5 3.90 14 15 CETC 0530-R47 M-A 0.47 7.4 8.5 11 13 CETC 0530-R68 M-A 0.68 11 12 9 12 CETC 0530-1R0 M-A 1.0 13 14 9 11 CETC 0530-1R5 M-A 1.5 20 25 8.5 9 CETC 0530-2R2 M-A 2.2 25 29 6.5 7 CETC 0530-3R3 M-A 3.3 32.0 38 5 6 CETC 0530-4R7 M-A 4.7 50 60 4.5 5 CETC 0530-6R8 M-A 6.8 75 90 3.5 4 CETC 0530-100 M-A 10 110 125 3.2 3.5 Heat Rating Current Saturation Current CETC0618-A series 100KHz 0.25V P/N D.C.R (mΩ) L0(μH) ±20% '@0A Typical Max Idc (Amp) Typical Isat (Amp) Typical CETC 0618-R10 M-A 0.1 2.8 3.20 18 40 CETC 0618-R15 M-A 0.15 3.0 3.5 15 38 CETC 0618-R22 M-A 0.22 3.8 4.2 14 26 CETC 0618-R33 M-A 0.33 6 6.8 12 18 CETC 0618-R47 M-A 0.47 7.3 8.4 11 17 CETC 0618-R68 M-A 0.68 12.7 13.9 9 16 CETC 0618-R82 M-A 0.82 13.8 15.9 8 15 CETC 0618-1R0 M-A 1.0 17.5 18.3 7 12 CETC 0618-1R5 M-A 1.5 22.6 34.0 4 10 CETC 0618-2R2 M-A 2.2 40.3 46.0 3.75 7 CETC 0618-3R3 M-A 3.3 56.2 60 3.25 6 CETC 0618-4R7 M-A 4.7 89 99 3 6 CETC0624-A series 100KHz 0.25V P/N D.C.R (mΩ) Heat Rating Current Saturation Current L0(μH) ±20% '@0A Typical Max Idc (Amp) Typical Isat (Amp) Typical CETC 0624-R10 M-A 0.1 1.5 1.7 30 50 CETC 0624-R22 M-A 0.22 2.9 3.2 21 34 CETC 0624-R33 M-A 0.33 3.2 3.55 18 35 CETC 0624-R47 M-A 0.47 5.4 6.0 13.5 22 CETC 0624-R68 M-A 0.68 7.3 8.1 11 18 CETC 0624-R82 M-A 0.82 8.5 9.35 11 18 CETC 0624-1R0 M-A 1.0 11.5 12.5 9 16 CETC 0624-1R5 M-A 1.5 18 20.6 7.5 16 CETC 0624-2R2 M-A 2.2 23 25 7 14 CETC 0624-3R3 M-A 3.3 28.5 31.5 6 6 CETC 0624-4R7 M-A 4.7 53 63 5 8 CETC 0624-6R8 M-A 6.8 68 76 3.5 4.5 CETC 0624-100 M-A 10 112 125 2.5 3.5 Heat Rating Current Saturation Current Max Idc (Amp) Typical Isat (Amp) Typical CETC0630-A series 100KHz 0.25V P/N L0(μH) ±20% '@0A D.C.R (mΩ) Typical CETC 0630-1R0 M-A 1.0 7.0 8 14 14.5 CETC 0630-1R5 M-A 1.5 10.2 12.0 13 14 CETC 0630-2R2 M-A 2.2 15.6 18.0 8.2 8.4 CETC 0630-3R3 M-A 3.3 23.5 26.0 8.5 9.5 6.5 CETC 0630-4R7 M-A 4.7 29.5 33.4 6 CETC 0630-6R8 M-A 6.8 41 46.8 5 6 CETC 0630-8R2 M-A 8.2 52.5 54.9 5.5 5.7 CETC 0630-100 M-A 10 64 68 4 5 CETC 0630-150 M-A 15 108 118 3 3.5 CETC 0630-220 M-A 22 128 135 2.8 3.2 Heat Rating Current Saturation Current CETC1030-A series 100KHz 0.25V P/N D.C.R (mΩ) L0(μH) ±20% '@0A Typical Max Idc (Amp) Typical Isat (Amp) Typical CETC 1030-R16 M-A 0.16 0.85 0.95 36 60 CETC 1030-R30 M-A 0.30 1.55 1.7 28 55 CETC 1030-R47 M-A 0.47 2 2.2 28 45 CETC 1030-R56 M-A 0.56 2.5 2.75 25 30 CETC 1030-R68 M-A 0.68 2.8 3.1 25 28 CETC 1030-1R0 M-A 1.0 4.5 4.95 25 28 CETC 1030-1R5 M-A 1.5 7.0 7.8 13.5 25 CETC 1030-2R2 M-A 2.2 8.3 10 14 20 CETC 1030-3R3 M-A 3.3 13.5 15 9 15 CETC 1030-4R7 M-A 4.7 21 24.0 9 12 CETC 1030-6R8 M-A 6.8 32 36 7 12 CETC 1030-100 M-A 10 46 52 7 10 CETC1040-A series 100KHz 0.25V P/N D.C.R (mΩ) Heat Rating Current Saturation Current L0(μH) ±20% '@0A Typical Max Idc (Amp) Typical Isat (Amp) Typical CETC 1040-R33 M-A 0.33 1.06 1.2 25 50 CETC 1040-R47 M-A 0.47 1.5 1.68 24 35 CETC 1040-R56 M-A 0.56 2.1 2.4 23.5 33 CETC 1040-R68 M-A 0.68 2.3 3.0 20 30 CETC 1040-1R0 M-A 1.0 3.0 4 18 28 CETC 1040-1R5 M-A 1.5 3.7 5.5 12 24 CETC 1040-2R2 M-A 2.2 7.2 9.0 12 18 CETC 1040-3R3 M-A 3.3 10.8 11.8 10 16 CETC 1040-4R7 M-A 4.7 17 20 8.5 13 CETC 1040-6R8 M-A 6.8 18.8 25 7 10 CETC 1040-8R2 M-A 8.2 24.3 27 6 9 CETC 1040-100 M-A 10 17.5 30 5.5 8.5 CETC 1040-150 M-A 15 40 45 4.5 7 CETC 1040-220 M-A 22 60 66 4 5.5 Heat Rating Current Saturation Current CETC1250-A series 100KHz 0.25V P/N D.C.R (mΩ) L0(μH) ±20% '@0A Typical Max Idc (Amp) Typical Isat (Amp) Typical CETC 1250-R33 M-A 0.33 0.7 1.1 41 60 CETC 1250-R47 M-A 0.47 1.0 1.3 39 52 CETC 1250-R68 M-A 0.68 1.3 1.5 32 40 CETC 1250-1R0 M-A 1.0 1.9 2.2 26 35 CETC 1250-1R5 M-A 1.5 2.7 3.2 23 30 CETC 1250-2R2 M-A 2.2 4 5.0 15 26 CETC 1250-3R3 M-A 3.3 7 9 13 22 CETC 1250-4R7 M-A 4.7 9 11 12 17 CETC 1250-5R6 M-A 5.6 13 15 11 16 CETC 1250-6R8 M-A 6.8 15 18 10 14 CETC 1250-100 M-A 10 20 23 8 12 CETC 1250-150 M-A 15 28 32 5 10 CETC 1250-220 M-A 22 45 52 4.5 7 CETC1270-A series 100KHz 0.25V P/N D.C.R (mΩ) Heat Rating Current Saturation Current L0(μH) ±20% '@0A Typical Max Idc (Amp) Typical Isat (Amp) Typical 0.47 1.0 1.2 33 60 CETC 1270-R47 M-A CETC 1270-R56 M-A 0.56 1.2 1.4 35 60 CETC 1270-R68 M-A 0.68 1.4 1.6 32 50 CETC 1270-1R0 M-A 1.0 1.7 2.0 30 49 CETC 1270-2R2 M-A 2.2 3.5 4.2 22 40 CETC 1270-3R3 M-A 3.3 5.7 6.8 18 32 CETC 1270-3R6 M-A 3.6 6.3 7 16 30 CETC 1270-4R7 M-A 4.7 8 8.7 13.5 28 CETC 1270-6R8 M-A 6.8 12 13.5 11.5 25 CETC 1270-100 M-A 10 15.5 17 9 16 CETC 1270-150 M-A 15 31 34 6 9 CETC 1270-220 M-A 22 46 50 6 8 CETC 1270-330 M-A 33 75 81 5 8 CETC 1270-470 M-A 47 85 90 4.5 6 • All test data is referenced to 25°C ambient • DC current (Idc) that will cause an approximate △ T of 40℃ • DC current (Isat) that will cause Lo to drop approximately 30% • Operating temperature Range: –55°C to +125°C • The part temperature (ambient + temp rise) should not exceed125℃ under the worst operating conditions. Circuit design,component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. http://www.ecthf.com
CETC1030-A 价格&库存
很抱歉,暂时无法提供与“CETC1030-A”相匹配的价格&库存,您可以联系我们找货
