BZT52B2V4 - BZT52B75
Taiwan Semiconductor
Small Signal Product
500mW, 2% Tolerance SMD Zener Diode
FEATURES
- Wide zener voltage range selection : 2.4V to 75V
- Surface mount device type
- Moisture sensitivity level 1
- Pb free and RoHS compliant
- VZ Tolerance Selection of ±2%
- Matte tin (Sn) lead finish with Nickel (Ni) under plate
- Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
SOD-123F
- Halogen-free according to IEC 61249-2-21
MECHANICAL DATA
- Case: Flat lead SOD-123 small outline plastic package
- Terminal: Matte tin plated, lead free, solderable
per MIL-STD-202, Method 208 guaranteed
- High temperature soldering guaranteed: 260°C/10s
- Polarity: Indicated by cathode band
- Weight : 8.85 ± 0.5mg
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
SYMBOL
VALUE
UNIT
@ IF = 10mA
VF
PD
1
500
V
mW
(Note 1)
RθJA
350
°C/W
Junction temperature
TJ
150
°C
Storage temperature
TSTG
- 65 to +150
°C
PARAMETER
Forward voltage
Power dissipation
Thermal resistance from junction to ambient
Notes: 1. Valid provided that electrodes are kept at ambient temperature
ZENER I vs. V CHARACTERISTICS
VBR
: Voltage at IZK
IZK
: Test current for voltage VBR
ZZK
: Dynamic impedance at IZK
IZT
: Test current for voltage VZ
VZ
: Voltage at current IZT
ZZT
: Dynamic impedance at IZT
IZM
: Maximum steady state current
: Voltage at IZM
VZM
Document Number: DS_S1405026
Version: F15
(Ratings at TA=25°C ambient temperature unless otherwise specified,
and VF Forward Voltage = 1V Maximum @ IF = 10 mA for all part numbers)
Device
type
Zener voltage range
Marking
code
VZ @ IZT
Maximum zener impedance
IZT
Min (V)
Nom (V)
Max (V)
mA
ZZT @ IZT
ZZK @ IZK
Ohm
Maximum reverse
current
IZK
IR
VR
mA
μA
V
BZT52B2V4
2V4B
2.35
2.40
2.45
5
100
564
1
45
1
BZT52B2V7
2V7B
2.65
2.70
2.75
5
100
564
1
18
1
BZT52B3V0
3V0B
2.94
3.00
3.06
5
100
564
1
9
1
BZT52B3V3
3V3B
3.23
3.30
3.37
5
95
564
1
4.5
1
BZT52B3V6
3V6B
3.53
3.60
3.67
5
90
564
1
4.5
1
BZT52B3V9
3V9B
3.82
3.90
3.98
5
90
564
1
2.7
1
BZT52B4V3
4V3B
4.21
4.30
4.39
5
90
564
1
2.7
1
BZT52B4V7
4V7B
4.61
4.70
4.79
5
80
470
1
2.7
2.0
BZT52B5V1
5V1B
5.00
5.10
5.20
5
60
451
1
1.8
2.0
BZT52B5V6
5V6B
5.49
5.60
5.71
5
40
376
1
0.9
2.0
BZT52B6V2
6V2B
6.08
6.20
6.32
5
10
141
1
2.7
4.0
BZT52B6V8
6V8B
6.66
6.80
6.94
5
15
75
1
1.8
4.0
BZT52B7V5
7V5B
7.35
7.50
7.65
5
15
75
1
0.9
5.0
BZT52B8V2
8V2B
8.04
8.20
8.36
5
15
75
1
0.63
5.0
BZT52B9V1
9V1B
8.92
9.10
9.28
5
15
94
1
0.45
6.0
BZT52B10
10VB
9.80
10.00
10.20
5
1
0.18
7.0
BZT52B11
11VB
10.78
11.00
11.22
5
1
0.09
8.0
BZT52B12
12VB
11.76
12.00
12.24
5
25
141
1
0.09
8.0
BZT52B13
13VB
12.74
13.00
13.26
5
30
160
1
0.09
8.0
BZT52B15
15VB
14.70
15.00
15.30
5
30
188
1
0.045
10.5
BZT52B16
16VB
15.68
16.00
16.32
5
40
188
1
0.045
11.2
BZT52B18
18VB
17.64
18.00
18.36
5
45
212
1
0.045
12.6
BZT52B20
20VB
19.60
20.00
20.40
5
55
212
1
0.045
14.0
BZT52B22
22VB
21.56
22.00
22.44
5
55
235
1
0.045
15.4
BZT52B24
24VB
23.52
24.00
24.48
5
70
235
1
0.045
16.8
BZT52B27
27VB
26.46
27.00
27.54
2
80
282
0.5
0.045
18.9
BZT52B30
30VB
29.40
30.00
30.60
2
80
282
0.5
0.045
21.0
BZT52B33
33VB
32.34
33.00
33.66
2
80
306
0.5
0.045
23.0
BZT52B36
36VB
35.28
36.00
36.72
2
90
329
0.5
0.045
25.2
BZT52B39
39VB
38.22
39.00
39.78
2
130
329
0.5
0.045
27.3
BZT52B43
43VB
42.14
43.00
43.86
2
150
353
0.5
0.045
30.1
BZT52B47
47VB
46.06
47.00
47.94
2
170
353
0.5
0.045
33.0
BZT52B51
51VB
49.98
51.00
52.02
2
180
376
0.5
0.045
35.7
BZT52B56
56VB
54.88
56.00
57.12
2
200
400
0.5
0.045
39.2
BZT52B62
62VB
60.76
62.00
63.24
2
215
423
0.5
0.045
43.4
BZT52B68
68VB
66.64
68.00
69.36
2
240
447
0.5
0.045
47.6
BZT52B75
75VB
73.50
75.00
76.50
2
255
470
0.5
0.045
52.5
Notes: 1. The Zener Voltage (VZ) is tested under pulse condition of 10ms.
2. The device numbers listed have a standard tolerance on the normal zener voltage of ±2%.
3. For detailed information on price, availability and delivery of normal zener voltages between the voltages
shown and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative.
4. The Zener impedance is derived from the 60-cycle ac voltage, which results when an ac current
having an RMS value equal to 10% of the dc zener current is superimposed to IZT or IZK.
Version: F15
RATINGS AND CHARACTERISTICS CURVES
Fig. 2 Zener Breakdown Characteristics
Fig. 1 Typical Forward Characteristics
100
10
Zener Current (mA)
Forward Current (mA)
1000
100
10
1
0.1
0.01
1
0.4
0.5
0.6
0.7
0.8
0.9
1.0
1.1
1
2
3
5
6
7
8
9
10
11
12
Zener Voltage (V)
Forward Voltage (V)
Fig. 3 Zener Breakdown Characteristics
Fig. 4 Admissible Power Dissipation Curve
500
Power Dissipation (mW)
100
Zener Current (mA)
4
10
1
0.1
400
300
200
100
15
25
35
45
55
65
75
50
100
Ambient Temperature
150
200
(oC)
Zener Voltage (V)
Fig. 6 Effect of Zener Voltage on Impedence
Fig. 5 Typical Capacitance
1000
Dynamic Impedence(Ohm)
Capacitance (pF)
1000
100
10
1
IZ=5mA
100
IZ=20mA
10
1
1
10
Zener Voltage (V)
100
1
10
100
Zener Voltage (V)
Version: F15
ORDERING INFORMATION
PART NO.
PACKING CODE
BZT52Bxxx
(Note 1)
RH
PACKING CODE
SUFFIX
G
PACKAGE
PACKING
SOD-123F
3K / 7" Reel
Note 1: "xxx" is device code from "2V4" - "75", detail could follow the previous page
*: Optional available, packing code with suffix "G" means green compound (halogen free)
EXAMPLE
EXAMPLE P/N
PART NO.
PACKING CODE
BZT52B2V4 RHG
BZT52B2V4
RH
PACKING CODE
DESCRIPTION
SUFFIX
G
Green compound
DIMENSIONS
SOD-123F
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
1.50
1.70
0.059
0.067
B
3.30
3.90
0.130
0.154
C
0.50
0.70
0.020
0.028
D
2.50
2.70
0.098
0.106
E
0.80
1.15
0.031
0.045
F
0.05
0.20
0.002
0.008
SUGGESTED PAD LAYOUT
Unit (mm)
Unit (inch)
Typ.
Typ.
G
2.50
0.098
X
0.80
0.031
X1
4.10
0.161
Y
0.80
0.031
DIM.
Version: F15
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: F15
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Taiwan Semiconductor:
BZT52B62 BZT52B68 BZT52B75 BZT52B10 BZT52B11 BZT52B12 BZT52B13 BZT52B15 BZT52B16
BZT52B18 BZT52B20 BZT52B22 BZT52B24 BZT52B27 BZT52B2V4 BZT52B2V7 BZT52B30 BZT52B33
BZT52B36 BZT52B39 BZT52B3V0 BZT52B3V3 BZT52B3V6 BZT52B3V9 BZT52B43 BZT52B47 BZT52B4V3
BZT52B4V7 BZT52B51 BZT52B56 BZT52B5V1 BZT52B5V6 BZT52B6V2 BZT52B6V8 BZT52B7V5 BZT52B8V2
BZT52B9V1 BZT52B68 RH BZT52B62 RH BZT52B75 RH BZT52B5V6 RHG BZT52B56 RHG BZT52B11 RHG
BZT52B39 RHG BZT52B2V7 RHG BZT52B12 RHG BZT52B6V8 RHG BZT52B24 RHG BZT52B9V1 RHG
BZT52B62 RHG BZT52B16 RHG BZT52B2V4 RHG BZT52B22 RHG BZT52B4V7 RHG BZT52B8V2 RHG
BZT52B4V3 RHG BZT52B6V2 RHG BZT52B27 RHG BZT52B18 RHG BZT52B51 RHG BZT52B36 RHG
BZT52B68 RHG BZT52B3V6 RHG BZT52B7V5 RHG BZT52B13 RHG BZT52B3V9 RHG BZT52B20 RHG
BZT52B3V3 RHG BZT52B15 RHG BZT52B10 RHG BZT52B75 RHG BZT52B43 RHG BZT52B30 RHG BZT52B47
RHG BZT52B3V0 RHG BZT52B5V1 RHG BZT52B33 RHG BZT52B4V3 RH BZT52B5V6 RH BZT52B16 RH
BZT52B9V1 RH BZT52B56 RH BZT52B2V4 RH BZT52B22 RH BZT52B3V3 RH BZT52B10 RH BZT52B6V2 RH
BZT52B30 RH BZT52B13 RH BZT52B43 RH BZT52B5V1 RH BZT52B33 RH BZT52B24 RH BZT52B12 RH
BZT52B18 RH BZT52B27 RH BZT52B3V6 RH BZT52B2V7 RH BZT52B51 RH BZT52B11 RH
很抱歉,暂时无法提供与“BZT52B4V7”相匹配的价格&库存,您可以联系我们找货
