BZT52C47
BZT52C47
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD-123F
    台半 SOD-123F Zzk: 353Ω Pd: 500mW Izk: 0.5mA
BZT52C47 数据手册
BZT52C2V0 - BZT52C51 SURFACE MOUNT ZENER DIODE Features        Mechanical Data   Planar Die Construction 500mW Power Dissipation General Purpose, Medium Current Ideally Suited for Automated Assembly Processes Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2) Halogen and Antimony Free. “Green” Device (Notes 3 & 4) Qualified to AEC-Q101 Standards for High Reliability Case: SOD123 Case Material: Molded Plastic. UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 1 per J-STD-020 Terminals: Matte Tin Finish Annealed over Alloy 42 Leadframe (Lead Free Plating). Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band Weight: 0.010 grams (Approximate)     SOD123 Top View Ordering Information (Notes 5 & 6) Part Number (Type Number)-7-F (Type Number)Q-7-F (Type Number)-13-F (Type Number)Q-13-F Notes: Qualification Commercial Automotive Commercial Automotive Case SOD123 SOD123 SOD123 SOD123 Packaging 3,000/Tape & Reel 3,000/Tape & Reel 10,000/Tape & Reel 10,000/Tape & Reel 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS) & 2011/65/EU (RoHS 2) compliant. 2. See http://www.diodes.com for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain
BZT52C47
物料型号:BZT52C2V0至BZT52C51,是一系列表面安装的齐纳二极管。
器件简介:这些二极管采用平面芯片结构,具有500mW的功率耗散能力,适用于一般用途和中等电流,非常适合自动化装配流程。它们完全符合RoHS标准,无铅且不含卤素和锑,是“绿色”器件。
引脚分配:文档中提供了SOD123封装的顶视图,其中标示了二极管的阳极和阴极。
参数特性:包括热特性、电气特性等。例如,功率耗散在+75°C时为500mW,25°C时为370mW。热阻从结到环境空气为338°C/W,从结到引脚为150°C/W。工作和存储温度范围为-65°C至+150°C。
功能详解:这些二极管具有稳定的齐纳电压范围,适用于电路中过压保护。
应用信息:文档中提到了产品符合汽车和商业应用的资格,并提供了相应的包装信息。
封装信息:提供了SOD123封装的详细尺寸和建议的焊盘布局。
BZT52C47 价格&库存
很抱歉,暂时无法提供与“BZT52C47”相匹配的价格&库存,您可以联系我们找货
