PIC16F883T-I/SS
PIC16F883T-I/SS
    MICA
    SSOP-28_10.2X5.3MM
    PIC PIC® 16F 微控制器 IC 8 位 20MHz 7KB(4K x 14) 闪存 28-SSOP
PIC16F883T-I/SS 数据手册
PIC16F88X PIC16F88X Family Silicon Errata and Data Sheet Clarification The PIC16F88X family devices that you have received conform functionally to the current Device Data Sheet (DS41291G), except for the anomalies described in this document. For example, to identify the silicon revision level using MPLAB IDE in conjunction with a hardware debugger: 1. The silicon issues discussed in the following pages are for silicon revisions with the Device and Revision IDs listed in Table 1. The silicon issues are summarized in Table 2, Table 3 and Table 4. 2. 3. The errata described in this document will be addressed in future revisions of the PIC16F88X silicon. 4. Note: This document summarizes all silicon errata issues from all revisions of silicon, previous as well as current. Only the issues indicated in the last column of Table 2, Table 3 and Table 4 apply to the current silicon revision (A0 or A2, as applicable). Data Sheet clarifications and corrections start on page 14, following the discussion of silicon issues. The silicon revision level can be identified using the current version of MPLAB® IDE and Microchip’s programmers, debuggers, and emulation tools, which are available at the Microchip corporate web site (www.microchip.com). TABLE 1: 5. Using the appropriate interface, connect the device to the hardware debugger. Open an MPLAB IDE project. Configure the MPLAB IDE project for the appropriate device and hardware debugger. Based on the version of MPLAB IDE you are using, do one of the following: a) For MPLAB IDE 8, select Programmer > Reconnect. b) For MPLAB X IDE, select Window > Dashboard and click the Refresh Debug Tool Status icon ( ). Depending on the development tool used, the part number and Device Revision ID value appear in the Output window. Note: If you are unable to extract the silicon revision level, please contact your local Microchip sales office for assistance. The DEVREV values for the various PIC16F88X silicon revisions are shown in Table 1. SILICON DEVREV VALUES Part Number (1) Revision ID for Silicon Revision(2) Device ID A0 A2 PIC16F882 2000h 00h PIC16F883 2020h 00h PIC16F884 2040h 00h PIC16F886 2060h 02h PIC16F887 2080h 02h Note 1: 2: The device and revision data is stored in the Device ID located at 2006h in program memory. Refer to the “PIC16F88X Memory Programming Specification” (DS41287) for detailed information.  2007-2014 Microchip Technology Inc. DS80000302J-page 1 PIC16F88X TABLE 2: SILICON ISSUE SUMMARY (PIC16F882) Module Feature Item Number Issue Summary Affected Revisions(1) A0 LVP Programming 1. Programming disruption. X MSSP SPI Master 2. SPI using Timer2/2. X ADC VP6 Reference 3. Disruption of the HFINTOSC. X MSSP SPI Master 4. Write collision on loading. X MSSP I2C™ Slave 5. R/W bit on ACK. X MSSP I2 6. Clock-stretching handling. X MSSP SPI Slave 7. Multi-byte transmission. X Timer1 Ext. Crystal 8. Overflow may take additional count. X C™ Master Timer1 Ext. Crystal 9. Oscillator may stop running at low temps. X Timer0 Prescaler 10. Spurious Reset. X MSSP SPI Master 11. Disabling the module generates a clock pulse. X CCP Dead-Band Delay 12. Unpredictable waveforms if dead-band delay is greater than the PWM duty cycle. X Note 1: Only those issues indicated in the last column apply to the current silicon revision. DS80000302J-page 2  2007-2014 Microchip Technology Inc. PIC16F88X TABLE 3: SILICON ISSUE SUMMARY (PIC16F883/PIC16F884) Module Feature Item Number Affected Revisions(1) Issue Summary A0 LVP Programming 1. Programming disruption. X MSSP SPI Master 2. SPI using Timer2/2. X ADC VP6 Reference 3. Disruption of the HFINTOSC. X MSSP SPI Master 4. Write collision on loading. X MSSP I2C™ Slave 5. R/W bit on ACK. X MSSP I2 6. Clock-stretching handling. X MSSP SPI Slave 7. Multi-byte transmission. X Timer1 Ext. Crystal 8. Overflow may take additional count. X Timer1 Ext. Crystal 9. Oscillator may stop running at low temps. X Timer0 Prescaler 10. Spurious Reset. X MSSP SPI Master 11. Disabling the module generates a clock pulse. X CCP Dead-Band Delay 12. Unpredictable waveforms if dead-band delay is greater than the PWM duty cycle. X Note 1: C™ Master Only those issues indicated in the last column apply to the current silicon revision.  2007-2014 Microchip Technology Inc. DS80000302J-page 3 PIC16F88X TABLE 4: SILICON ISSUE SUMMARY (PIC16F886/PIC16F887) Module Feature Item Number Issue Summary Affected Revisions(1) A2 LVP Programming 1. Programming disruption. X MSSP SPI Master 2. SPI using Timer2/2. X ADC VP6 Reference 3. Disruption of the HFINTOSC. X MSSP SPI Master 4. Write collision on loading. X MSSP I C™ Slave 5. R/W bit on ACK. X MSSP I2 6. Clock-stretching handling. X MSSP SPI Slave 7. Multi-byte transmission. X Timer1 Ext. Crystal 8. Overflow may take additional count. X Timer1 Ext. Crystal 9. Oscillator may stop running at low temps. X Timer0 Prescaler 10. Spurious Reset. X MSSP SPI Master 11. Disabling the module generates a clock pulse. X CCP Dead-Band Delay 12. Unpredictable waveforms if dead-band delay is greater than the PWM duty cycle. X Programming 13. Memory read and verify operations. X 2 ICSP™ Note 1: C™ Master Only those issues indicated in the last column apply to the current silicon revision. DS80000302J-page 4  2007-2014 Microchip Technology Inc. PIC16F88X Silicon Errata Issues Note: This document summarizes all silicon errata issues from all revisions of silicon, previous as well as current. Only the issues indicated by the shaded column in the following tables apply to the current silicon revision (A0 or A2, as applicable). 2. Module: MSSP (SPI Mode) When the SPI is using Timer2/2 as the clock source, a shorter than expected SCK pulse may occur on the first bit of the transmitted/received data (Figure 1). FIGURE 1: 1. Module: Low-Voltage In-Circuit Serial Programming™ (LVP) Write SSPBUF If LVP (Low-Voltage Programming) mode is enabled, programming the device using the VPP pin while holding high or toggling the port pin RB3/ PGM during Program mode could disrupt the programming sequence. SDO Work around SCK Pull down pin RB3/PGM using external circuitry during programming of the device. Affected Silicon Revisions PIC16F882 A0 X SCK PULSE VARIATION USING TIMER2/2 bit 0 = 1 bit 1 = 0 Work around To avoid producing the short pulse, turn off Timer2 and clear the TMR2 register, load SSPBUF with the data to transmit and then turn Timer2 back on. Refer to Example 1 for sample code. EXAMPLE 1: PIC16F883/PIC16F884 AVOIDING THE INITIAL SHORT SCK PULSE LOOP BTFSS SSPSTAT, BF A0 X PIC16F886/PIC16F887 A2 X bit 2 = 1 . . . . GOTO MOVF MOVWF MOVF BCF CLRF MOVWF BSF LOOP SSPBUF, W RXDATA TXDATA, W T2CON, TMR2ON TMR2 SSPBUF T2CON, TMR2ON ;Data received? ;(Xmit complete?) ;No ;W = SSPBUF ;Save in user RAM ;W = TXDATA ;Timer2 off ;Clear Timer2 ;Xmit New data ;Timer2 on Affected Silicon Revisions PIC16F882 A0 X PIC16F883/PIC16F884 A0 X PIC16F886/PIC16F887 A2 X  2007-2014 Microchip Technology Inc. DS80000302J-page 5 PIC16F88X 3. Module: Analog-To-Digital Converter (ADC) Module Selecting the VP6 reference as the analog input source (CHS = 1111) for the ADC conversion after sampling another analog channel with input voltages approximately greater than 3.6V can temporarily disturb the HFINTOSC oscillator. Note: This only occurs when selecting the VP6 reference ADC channel using the CHS bits in the ADCON0 register and NOT during the start of an actual ADC conversion using the GO/DONE bit in the ADCON0 register. Work around Select an ADC channel with input voltages lower than 3.6V prior to selecting the VP6 reference voltage input. Any analog channel can be used, even if that channel is configured as a digital I/O (configured as an output) that is driving the output pin low. An alternative is to configure the CVREF module to output a voltage lower than 3.6V and then selecting that analog channel CHS = 1110 as the analog input source. EXAMPLE 2: BANKSEL MOVLW MOVWF MOVLW MOVWF AVOID DISTURBING THE HFINTOSC OSCILLATOR ADCON0 B’XX111001’ ADCON0 B’XX111101’ ADCON0 ; ;Select ADC ;Channel CVREF ;Select ADC ;Channel VP6 4. Module: MSSP (SPI Master Mode) With MSSP in SPI Master mode, FOSC/64 or Timer2/2 clock rate and CKE = 0, a write collision may occur if SSPBUF is loaded immediately after the transfer is complete. A delay may be required after the MSSP Interrupt Flag bit, SSPIF, is set or the Buffer Full bit, BF, is set and before writing SSPBUF. If the delay is insufficiently short, a write collision may occur as indicated by the WCOL bit being set. Work around Add a software delay of one SCK period after detecting the completed transfer and prior to updating the SSPBUF contents. Verify the WCOL bit is clear after writing SSPBUF. If the WCOL is set, clear the bit in software and rewrite the SSPBUF register. Date Codes that pertain to this issue: All engineering and production devices. Affected Silicon Revisions PIC16F882 A0 X PIC16F883/PIC16F884 A0 X PIC16F886/PIC16F887 A2 Affected Silicon Revisions X PIC16F882 A0 X PIC16F883/PIC16F884 A0 X PIC16F886/PIC16F887 A2 X DS80000302J-page 6  2007-2014 Microchip Technology Inc. PIC16F88X 5. Module: MSSP (I2C™ Slave Mode) When the master device wants to terminate receiving any more data from the slave device, it will do so by sending a NACK in response to the last data byte received from the slave. When the slave receives the NACK, the R/W bit of the SSPSTAT register remains set improperly. Work around Use the CKP bit of the SSPCON register to determine when the master has responded with a NACK. The CKP bit will be clear when the response is an ACK, and set when the response is a NACK. The CKP bit is automatically cleared to stretch the clock when the master responds to received data with an ACK. This gives the slave time to load the SSPBUF register before setting the CKP bit to release the clock stretching. When the master responds to received data with a NACK, the CKP bit properly remains set and there is no clock stretching. Affected Silicon Revisions PIC16F882 A0 X PIC16F883/PIC16F884 A0 X PIC16F886/PIC16F887 A2 X  2007-2014 Microchip Technology Inc. DS80000302J-page 7 PIC16F88X 6. Module: MSSP (I2C™ Master Mode) When the MSSP is I2C™ Master mode with a slave device stretching the clock, the clock generation does not function as described in the data sheet. remainder of the BRG period, and then the MSSP device will immediately resume transmitting the data. Figure 1 illustrates an expected I2C transmission in which the SCL line is completely controlled by the master device and the slave device does not attempt to stretch the clock period. When a slave device is performing clock stretching by pulling the SCL line low, the master device should continuously sample the SCL line to determine when all slaves have released SCL. When SCL is released, the master device should wait one BRG period to ensure a constant SCL high time. Figure 2 illustrates the expected operation of an I2C transmission in which the slave device has stretched the clock period by holding the SCL line low. The high time of the SCL pulse is constant, regardless of the duration of the clock stretch. The current implementation does not ensure accurate SCL high time. During clock stretch, the MSSP device will erroneously continue running the BRG counter. At the end of the clock stretch, the BRG counter continues to count down for the Figure 3 and Figure 4 illustrate an actual I2C transmission in which the slave has stretched the clock period by holding the SCL line low. Note that the high time of the SCL signal has shortened from the expected time. FIGURE 1: ACTUAL (CORRECT) OPERATION WITHOUT CLOCK STRETCHING SDA SCL Master Slave BRG Period FIGURE 2: BRG Period BRG Period BRG Period BRG Period BRG Period EXPECTED OPERATION WITH CLOCK STRETCHING SDA SCL Master Slave BRG Period DS80000302J-page 8 BRG Period BRG Period BRG Period  2007-2014 Microchip Technology Inc. PIC16F88X FIGURE 3: ACTUAL (INCORRECT) OPERATION WITH CLOCK STRETCHING – EXAMPLE 1 SDA SCL Master Slave BRG Period FIGURE 4: BRG Period BRG Period BRG Period BRG Period BRG Period ACTUAL (INCORRECT) OPERATION WITH CLOCK STRETCHING – EXAMPLE 2 SDA SCL Master Slave BRG Period BRG Period BRG Period BRG Period BRG Period BRG Period Work around Set the communication speed to match the slowest device on the bus. This ensures that no slave device will perform clock stretching. It is possible to dynamically adjust the communication speed to match the device being addressed by modifying the BRG register. However, the behavior of slower slave devices must be understood and speed adjustments made such that no slave performs clock stretching. Affected Silicon Revisions PIC16F882 A0 X PIC16F883/PIC16F884 A0 X PIC16F886/PIC16F887 A2 X  2007-2014 Microchip Technology Inc. DS80000302J-page 9 PIC16F88X 7. Module: MSSP When all of the following conditions are met: 1. 2. 3. 4. The module is configured as a SPI slave CKP = 1 CKE = 1 Multiple bytes are sent to the Slave with the SS line remaining low between bytes The SSPIF flag will only be set on reception of the first byte and the following bytes will not be correctly received. Work around • SPI Master toggles the SS line between bytes or • On reception of the first byte, modify the SSPM0 bit in the SSPCON register to configure the module as a SPI slave with SS pin disabled. Then, restore the SSPM0 bit to the configuration for SPI slave with SS pin enabled. The module is then ready for reception of the following byte. EXAMPLE 3: MODIFICATION OF THE SSPM0 BIT BSF SSPCON, SSPM0 BCF SSPCON, SSPM0 Affected Silicon Revisions PIC16F882 A0 X PIC16F883/PIC16F884 A0 X PIC16F886/PIC16F887 A2 X DS80000302J-page 10  2007-2014 Microchip Technology Inc. PIC16F88X 8. Module: Asynchronous Timer1 This Errata supersedes Errata DS80233 and DS80329. When TImer1 is started or updated, the timer needs to see a falling edge from the external clock source before a rising edge can increment the counter. If writes to TMR1H and TMR1L are not completed while the external clock pulse is still high, Timer1 will not count the first clock pulse after the update. EXAMPLE 4: BTFSC GOTO BTFSS GOTO When using an external crystal, the pulse width from rising to falling edge is temperaturedependent and may decrease with temperature. As a result, the timer may require an additional oscillation to overflow. Work around Switching to the HFINTOSC after reloading, the timer ensures the Timer1 will see a falling edge before switching back to the external clock source. Due to the time from Timer1 overflow to the reload being application specific, wait for the timer to increment before beginning the reload sequence. This ensures the timer does not miss a rising edge during reload. SWITCHING TO HFINTOSC TO ENSURE TIMER1 WILL SEE A FALLING EDGE TMR1L,0 $-1 TMR1L,0 $-1 ;Timer has just incremented, 31 s before next rising edge to ;complete reload Update: BCF BSF BCF BSF BCF T1CON,TMR1CS TMR1H,7 T1CON,TMR1ON T1CON,TMR1CS T1CON,TMR1ON ;Select ;Timer1 ;Timer1 ;Select ;Timer1 HFINTOSC for Timer1 high byte 0x80 off external crystal on Critical Timing of code sequence for instructions following last write to TMR1L or TMR1H. Affected Silicon Revisions PIC16F882 A0 X PIC16F883/PIC16F884 A0 X PIC16F886/PIC16F887 A2 X  2007-2014 Microchip Technology Inc. DS80000302J-page 11 PIC16F88X 9. Module: LP/Timer1 Oscillator Operation Below 25°C 1-2% of devices experience reduced drive as temperatures approach -40°C. This will result in a loss of Timer1 counts or stopped Timer1 oscillation. This can also prevent Timer1 oscillator start-up under cold conditions. Work around Use of low-power crystals properly matched to the device will reduce the likelihood of failure. A 1 m resister between OSC2 and VDD will further improve the drive strength of the circuit. Affected Silicon Revisions PIC16F882 A0 X PIC16F883/PIC16F884 A0 X Description On a POR, the Timer0/WDT prescaler is assigned to the WDT. If the prescaler is reassigned to Timer0 and Timer0 external clock input (T0CKI) is enabled then the prescaler would be clocked by a transition on the T0CKI pin. On power-up, the T0CKI pin is (by default) enabled for Timer0 in the OPTION register. If the T0CKI pin is: • High and Timer0 is configured to transition on a falling edge (T0SE set), or • Low and Timer0 is configured to transition on a rising edge (T0SE clear) Then, if the prescaler is reassigned to the WDT, a clock pulse to the prescaler will be generated on the reassignment. If the prescaler is configured for the 1:1 option, the clock pulse will incorrectly cause a WDT Time-out Reset of the device. Work around 1. Disable the Timer0 external clock input by clearing the T0CKI bit in the OPTION register. 2. Modify the T0SE bit in the OPTION register to the opposite configuration for the logic level on the T0CKI pin. 3. Select a prescaler rate other than 1:1 and issue a CLRWDT instruction before switching to the final prescaler rate. PIC16F886/PIC16F887 A2 X 10. Module: Timer0 and WDT Prescaler Assignment Spurious Reset A spurious Reset may occur if the Timer0/ Watchdog Timer (WDT) prescaler is assigned from the WDT to Timer0 and then back to the WDT. Summary The issue only arises when all of the below conditions are met: • Timer0 external clock input (T0CKI) is enabled. • The Prescaler is assigned to the WDT, then to the Timer0 and back to the WDT. • During the assignments, the T0CKI pin is high when bit T0SE is set, or low when T0SE is clear. • The 1:1 Prescaler option is chosen. DS80000302J-page 12 Affected Silicon Revisions PIC16F882 A0 X PIC16F883/PIC16F884 A0 X PIC16F886/PIC16F887 A2 X  2007-2014 Microchip Technology Inc. PIC16F88X 11. Module: MSSP (SPI Master Mode) When the MSSP module is configured as a SPI master with CKP set, (SPI clock idles high) disabling the module by clearing the SSPEN bit will cause the clock line to be driven low for 2 TOSC before the setting of the RC3 output in the PORTC register takes effect. Similarly on enabling the module. There is a 1 TOSC period where the clock line will be driven low before the CKP bit takes effect and the line is driven high. Work around A pull-up resistor on the SCK line allows the pin to be configured as high-impedance during disabling/ enabling the module and the line to be pulled high by the resistor. The TRISC3 bit should be set before disabling or enabling the module to tristate the pin, and then cleared before transmission. Affected Silicon Revisions PIC16F882 A0 X PIC16F883/PIC16F884 A0 X PIC16F886/PIC16F887 A2 X 12. Module: Capture Compare PWM (CCP) With the ECCP configured for PWM Half-Bridge mode and a dead-band delay greater than or equal to the PWM duty cycle, unpredictable waveforms will result. Work around Make sure the dead-band delay is always less than the PWM duty cycle. Affected Silicon Revisions PIC16F882 A0 X PIC16F883/PIC16F884 A0 X PIC16F886/PIC16F887 A2 X 13. Module: ICSP™ If the supply voltage (VDD) applied to the device is below 2.7V, the device can misread memory locations while performing an In-Circuit Serial Programming™ (ICSP™) read or verify command of the Program Flash Memory (PFM) or the Data EEPROM. This errata applies to both the HighVoltage ICSP and the Low-Voltage ICSP modes of the device, as described in the “PIC16F88X Memory Programming Specification” (DS41287). This low-voltage memory misread issue is limited to only the ICSP hardware interface module on the device, which is only used during device programming. In Normal user mode, the device will operate properly down to the specified VDD supply limits, as documented in the device data sheet (“PIC16F882/883/884/886/887, 28/40/44Pin Flash-Based, 8-Bit CMOS Microcontrollers)’’’ (DS41291). Work around Maintain a minimum VDD voltage setting of 2.7V or above when performing an ICSP read or verify command during programming of the PFM or Data EEPROM Memory. PIC16F886/PIC16F887 A2 X  2007-2014 Microchip Technology Inc. DS80000302J-page 13 PIC16F88X Data Sheet Clarifications The following typographic corrections and clarifications are to be noted for the latest version of the device data sheet (DS41291G): Note: Corrections are shown in bold. Where possible, the original bold text formatting has been removed for clarity. 1. Module: ADC (Block Diagram) Figure 9-1: ADC Block Diagram changes references from AVSS to VSS and AVDD to VDD. 2. Module: ADC Acquisition Time Example calculation correction. EQUATION 9-1: ACQUISITION TIME EXAMPLE Temperature = 50°C and external impedance of 10k  5.0V V DD Assumptions: T ACQ = Amplifier Settling Time + Hold Capacitor Charging Time + Temperature Coefficient = T AMP + T C + T COFF = 2µs + T C +   Temperature - 25°C   0.05µs/°C   The value for TC can be approximated with the following equations: 1  = V CHOLD V AP P LI ED  1 – -------------------------n+1   2 –1 ;[1] VCHOLD charged to within 1/2 lsb –T C ----------  RC V AP P LIED  1 – e  = V CHOLD   ;[2] VCHOLD charge response to VAPPLIED – Tc ---------  RC 1  V A PP LIE D  1 – e  = V A P PLIE D  1 – -------------------------n+1    2 –1 ;combining [1] and [2] Solving for TC: T C = – C HOLD  R IC + R SS + R S  ln(1/2047) = – 10pF  1k  + 7k  + 10k   ln(0.0004885) = 1.37 µs Therefore: T ACQ = 2µs + 1.37µs +   50°C- 25°C   0.05µs/°C   = 4.67µs DS80000302J-page 14  2007-2014 Microchip Technology Inc. PIC16F88X 3. Module: MSSP (SPI) The electrical specification parameter number 70 from Table 17-4 has been modified as follows. TABLE 17-4: SPI MODE REQUIREMENTS Standard Operating Conditions (unless otherwise stated) Param No. Symbol Characteristic Min. Typ† Max. Units Conditions 2.25 * TCY — — ns SP70* TSSL2SCH, TSSL2SCL SS to SCK or SCK input SP71* TSCH SCK input high time (Slave mode) TCY + 20 — — ns SP72* TSCL SCK input low time (Slave mode) TCY + 20 — — ns SP73* TDIV2SCH, TDIV2SCL Setup time of SDI data input to SCK edge 100 — — ns SP74* TSCH2DIL, TSCL2DIL Hold time of SDI data input to SCK edge 100 — — ns SP75* TDOR SDO data output rise time 3.0-5.5V — 10 25 ns 2.0-5.5V — 25 50 ns SP76* TDOF SDO data output fall time — 10 25 ns SP77* TSSH2DOZ SS to SDO output high-impedance 10 — 50 ns SP78* TSCR SCK output rise time (Master mode) 3.0-5.5V — 10 25 ns 2.0-5.5V — 25 50 ns SP79* TSCF SCK output fall time (Master mode) — 10 25 ns SP80* TSCH2DOV, TSCL2DOV SDO data output valid after SCK edge — — 50 ns 3.0-5.5V — — 145 ns SP81* TDOV2SCH, SDO data output setup to SCK edge TDOV2SCL 2.0-5.5V Tcy — — ns SP82* TSSL2DOV SDO data output valid after SS edge — — 50 ns SP83* TSCH2SSH, TSCL2SSH SS after SCK edge 1.5 TCY + 40 — — ns * These parameters are characterized but not tested. † Data in “Typ” column is at 5.0V, 25°C unless otherwise stated. These parameters are for design guidance only and are not tested.  2007-2014 Microchip Technology Inc. DS80000302J-page 15 PIC16F88X APPENDIX A: DOCUMENT REVISION HISTORY Rev. J Document (9/2014) Data Sheet Clarifications: Added Module 3; Other minor corrections. Rev. A Document (2/2007) First revision of this document. Added Module 1: Low-Voltage In-Circuit Serial Programming™ (PIC16F884/883 Silicon Rev. A0); Added Module 2: MSSP (SPI Mode). Clarifications/Corrections to the Data Sheet – Added Module 1: Product Identification System. Rev. B Document (5/2007) Clarifications/Corrections to the Data Sheet – Added Module 2: Electrical Specification - Supply Current. Rev. C Document (7/2007) Added Module 3: Analog-to-Digital Converter (ADC) Module. Rev. D Document (8/2007) Added Module 4: MSSP (SPI Master Mode), Module 5: MSSP (I2C Slave Mode) and Module 6: MSSP (I2C Master Mode). Rev. E Document (4/2009) Updated Errata to new format. Data Sheet Clarification: Added Module 1: Timer1 (Block Diagram); Module 2: Comparator (C2 Block Diagram); Module 3: ADC (Block Diagram); Module 4: Comparator Voltage Reference; Module 5: Comparator Voltage Reference. Added Module 7: MSSP; Added Module 8: Asynchronous Timer1; Added Module 9: LP/Timer1 Oscillator Operation Below 25C; Module 10: Timer0 and WDT Prescaler Assignment Spurious Reset. Rev. F Document (8/2009) Added Module 11: MSSP (SPI Master Mode); Updated Tables 2, 3, 4. Data Sheet Clarification: Removed Modules 1, 2, 4 and 5 as the Data Sheet has already been updated according to this version of the errata. Added Module 2: ADC. Rev. G Document (12/2012) Added Module 12: Capture Compare PWM (CCP). Rev. H Document (8/2013) Added Module 13: ICSP; Other minor corrections. DS80000302J-page 16  2007-2014 Microchip Technology Inc. Note the following details of the code protection feature on Microchip devices: • Microchip products meet the specification contained in their particular Microchip Data Sheet. • Microchip believes that its family of products is one of the most secure families of its kind on the market today, when used in the intended manner and under normal conditions. • There are dishonest and possibly illegal methods used to breach the code protection feature. All of these methods, to our knowledge, require using the Microchip products in a manner outside the operating specifications contained in Microchip’s Data Sheets. Most likely, the person doing so is engaged in theft of intellectual property. • Microchip is willing to work with the customer who is concerned about the integrity of their code. • Neither Microchip nor any other semiconductor manufacturer can guarantee the security of their code. Code protection does not mean that we are guaranteeing the product as “unbreakable.” Code protection is constantly evolving. We at Microchip are committed to continuously improving the code protection features of our products. Attempts to break Microchip’s code protection feature may be a violation of the Digital Millennium Copyright Act. If such acts allow unauthorized access to your software or other copyrighted work, you may have a right to sue for relief under that Act. Information contained in this publication regarding device applications and the like is provided only for your convenience and may be superseded by updates. It is your responsibility to ensure that your application meets with your specifications. MICROCHIP MAKES NO REPRESENTATIONS OR WARRANTIES OF ANY KIND WHETHER EXPRESS OR IMPLIED, WRITTEN OR ORAL, STATUTORY OR OTHERWISE, RELATED TO THE INFORMATION, INCLUDING BUT NOT LIMITED TO ITS CONDITION, QUALITY, PERFORMANCE, MERCHANTABILITY OR FITNESS FOR PURPOSE. Microchip disclaims all liability arising from this information and its use. Use of Microchip devices in life support and/or safety applications is entirely at the buyer’s risk, and the buyer agrees to defend, indemnify and hold harmless Microchip from any and all damages, claims, suits, or expenses resulting from such use. No licenses are conveyed, implicitly or otherwise, under any Microchip intellectual property rights. Trademarks The Microchip name and logo, the Microchip logo, dsPIC, FlashFlex, flexPWR, JukeBlox, KEELOQ, KEELOQ logo, Kleer, LANCheck, MediaLB, MOST, MOST logo, MPLAB, OptoLyzer, PIC, PICSTART, PIC32 logo, RightTouch, SpyNIC, SST, SST Logo, SuperFlash and UNI/O are registered trademarks of Microchip Technology Incorporated in the U.S.A. and other countries. The Embedded Control Solutions Company and mTouch are registered trademarks of Microchip Technology Incorporated in the U.S.A. Analog-for-the-Digital Age, BodyCom, chipKIT, chipKIT logo, CodeGuard, dsPICDEM, dsPICDEM.net, ECAN, In-Circuit Serial Programming, ICSP, Inter-Chip Connectivity, KleerNet, KleerNet logo, MiWi, MPASM, MPF, MPLAB Certified logo, MPLIB, MPLINK, MultiTRAK, NetDetach, Omniscient Code Generation, PICDEM, PICDEM.net, PICkit, PICtail, RightTouch logo, REAL ICE, SQI, Serial Quad I/O, Total Endurance, TSHARC, USBCheck, VariSense, ViewSpan, WiperLock, Wireless DNA, and ZENA are trademarks of Microchip Technology Incorporated in the U.S.A. and other countries. SQTP is a service mark of Microchip Technology Incorporated in the U.S.A. Silicon Storage Technology is a registered trademark of Microchip Technology Inc. in other countries. GestIC is a registered trademarks of Microchip Technology Germany II GmbH & Co. KG, a subsidiary of Microchip Technology Inc., in other countries. All other trademarks mentioned herein are property of their respective companies. © 2007-2014, Microchip Technology Incorporated, Printed in the U.S.A., All Rights Reserved. ISBN: 978-1-63276-567-3 QUALITY MANAGEMENT SYSTEM CERTIFIED BY DNV == ISO/TS 16949 ==  2007-2014 Microchip Technology Inc. Microchip received ISO/TS-16949:2009 certification for its worldwide headquarters, design and wafer fabrication facilities in Chandler and Tempe, Arizona; Gresham, Oregon and design centers in California and India. The Company’s quality system processes and procedures are for its PIC® MCUs and dsPIC® DSCs, KEELOQ® code hopping devices, Serial EEPROMs, microperipherals, nonvolatile memory and analog products. In addition, Microchip’s quality system for the design and manufacture of development systems is ISO 9001:2000 certified. DS80000302J-page 17 Worldwide Sales and Service AMERICAS ASIA/PACIFIC ASIA/PACIFIC EUROPE Corporate Office 2355 West Chandler Blvd. Chandler, AZ 85224-6199 Tel: 480-792-7200 Fax: 480-792-7277 Technical Support: http://www.microchip.com/ support Web Address: www.microchip.com Asia Pacific Office Suites 3707-14, 37th Floor Tower 6, The Gateway Harbour City, Kowloon Hong Kong Tel: 852-2943-5100 Fax: 852-2401-3431 India - Bangalore Tel: 91-80-3090-4444 Fax: 91-80-3090-4123 Austria - Wels Tel: 43-7242-2244-39 Fax: 43-7242-2244-393 Denmark - Copenhagen Tel: 45-4450-2828 Fax: 45-4485-2829 Australia - Sydney Tel: 61-2-9868-6733 Fax: 61-2-9868-6755 Atlanta Duluth, GA Tel: 678-957-9614 Fax: 678-957-1455 China - Beijing Tel: 86-10-8569-7000 Fax: 86-10-8528-2104 Austin, TX Tel: 512-257-3370 China - Chengdu Tel: 86-28-8665-5511 Fax: 86-28-8665-7889 Boston Westborough, MA Tel: 774-760-0087 Fax: 774-760-0088 Chicago Itasca, IL Tel: 630-285-0071 Fax: 630-285-0075 Cleveland Independence, OH Tel: 216-447-0464 Fax: 216-447-0643 Dallas Addison, TX Tel: 972-818-7423 Fax: 972-818-2924 Detroit Novi, MI Tel: 248-848-4000 Houston, TX Tel: 281-894-5983 Indianapolis Noblesville, IN Tel: 317-773-8323 Fax: 317-773-5453 Los Angeles Mission Viejo, CA Tel: 949-462-9523 Fax: 949-462-9608 New York, NY Tel: 631-435-6000 San Jose, CA Tel: 408-735-9110 Canada - Toronto Tel: 905-673-0699 Fax: 905-673-6509 DS80000302J-page 18 China - Chongqing Tel: 86-23-8980-9588 Fax: 86-23-8980-9500 China - Hangzhou Tel: 86-571-8792-8115 Fax: 86-571-8792-8116 China - Hong Kong SAR Tel: 852-2943-5100 Fax: 852-2401-3431 China - Nanjing Tel: 86-25-8473-2460 Fax: 86-25-8473-2470 China - Qingdao Tel: 86-532-8502-7355 Fax: 86-532-8502-7205 China - Shanghai Tel: 86-21-5407-5533 Fax: 86-21-5407-5066 China - Shenyang Tel: 86-24-2334-2829 Fax: 86-24-2334-2393 China - Shenzhen Tel: 86-755-8864-2200 Fax: 86-755-8203-1760 China - Wuhan Tel: 86-27-5980-5300 Fax: 86-27-5980-5118 China - Xian Tel: 86-29-8833-7252 Fax: 86-29-8833-7256 India - New Delhi Tel: 91-11-4160-8631 Fax: 91-11-4160-8632 France - Paris Tel: 33-1-69-53-63-20 Fax: 33-1-69-30-90-79 India - Pune Tel: 91-20-3019-1500 Japan - Osaka Tel: 81-6-6152-7160 Fax: 81-6-6152-9310 Germany - Dusseldorf Tel: 49-2129-3766400 Japan - Tokyo Tel: 81-3-6880- 3770 Fax: 81-3-6880-3771 Germany - Munich Tel: 49-89-627-144-0 Fax: 49-89-627-144-44 Korea - Daegu Tel: 82-53-744-4301 Fax: 82-53-744-4302 Germany - Pforzheim Tel: 49-7231-424750 Italy - Milan Tel: 39-0331-742611 Fax: 39-0331-466781 Korea - Seoul Tel: 82-2-554-7200 Fax: 82-2-558-5932 or 82-2-558-5934 Italy - Venice Tel: 39-049-7625286 Malaysia - Kuala Lumpur Tel: 60-3-6201-9857 Fax: 60-3-6201-9859 Netherlands - Drunen Tel: 31-416-690399 Fax: 31-416-690340 Malaysia - Penang Tel: 60-4-227-8870 Fax: 60-4-227-4068 Poland - Warsaw Tel: 48-22-3325737 Philippines - Manila Tel: 63-2-634-9065 Fax: 63-2-634-9069 Singapore Tel: 65-6334-8870 Fax: 65-6334-8850 Taiwan - Hsin Chu Tel: 886-3-5778-366 Fax: 886-3-5770-955 Spain - Madrid Tel: 34-91-708-08-90 Fax: 34-91-708-08-91 Sweden - Stockholm Tel: 46-8-5090-4654 UK - Wokingham Tel: 44-118-921-5800 Fax: 44-118-921-5820 Taiwan - Kaohsiung Tel: 886-7-213-7830 Taiwan - Taipei Tel: 886-2-2508-8600 Fax: 886-2-2508-0102 Thailand - Bangkok Tel: 66-2-694-1351 Fax: 66-2-694-1350 China - Xiamen Tel: 86-592-2388138 Fax: 86-592-2388130 China - Zhuhai Tel: 86-756-3210040 Fax: 86-756-3210049 03/25/14  2007-2014 Microchip Technology Inc.
PIC16F883T-I/SS 价格&库存
很抱歉,暂时无法提供与“PIC16F883T-I/SS”相匹配的价格&库存,您可以联系我们找货
PIC16F883T-I/SS
  • 1+6.80323
  • 30+6.56863
  • 100+6.09944
  • 500+5.63026
  • 1000+5.39566
