3362P-1-104LF
3362P-1-104LF
    BOCHEN(博晨)
    POTENTIONMETER_7.1X6.9MM_TM
    精密微调电阻 POTENTIONMETER_7.1X6.9MM_TM 100KΩ ±10% 1/2W ±250ppm/℃
3362P-1-104LF 数据手册
*R oH V SC AV ER OM AI SIO PL LA N IA BL S NT E Features ■ Single-Turn / Cermet / Industrial / Sealed ■ Miniature package ■ Rotor designed for automatic machine ■ RoHS compliant* version available ■ For trimmer applications/processing guidelines, click here adjust interface ■ Withstands harsh environments and immersion cleaning processes ■ Tape and reel packaging available 3362 - 1/4 ” Square Trimpot® Trimming Potentiometer Electrical Characteristics Standard Resistance Range ......................10 ohms to 2 megohms (see standard resistance table) Resistance Tolerance ........... ±10 % std. Absolute Minimum Resistance .................................... 1 % or 2 ohms (whichever is greater) Contact Resistance Variation ........................... 1 % or 3 ohms max. (whichever is greater) Adjustability Voltage Divider ...................... ±0.05 % Rheostat ................................ ±0.15 % Resolution ................................... Insulation Resistance ............... 500 vdc. 1,000 megohms min. Dielectric Strength Sea Level................................ 900 vac 80,000 Feet ............................ 350 vac Adjustment Angle ................. 240 ° nom. Environmental Characteristics Power Rating (300 volts max.) 70 °C .................................... 0.50 watt 125 °C ....................................... 0 watt Temperature Range ... -55 °C to +125 °C ... ±100 ppm/°C Seal Test ......................85 °C Fluorinert† Humidity .......MIL-STD-202 Method 103 96 hours (2 % ΔTR; 10 Megohms IR) Vibration ....... 30 G (1 % ΔTR; 1 % ΔVR) Shock ......... 100 G (1 % ΔTR; 1 % ΔVR) Load Life.. 1,000 hours 0.5 watt @ 70 °C (3 % ΔTR; 3 % or 3 ohms, whichever is greater, CRV) Rotational Life .......................200 cycles (4 % ΔTR; 3 % or 3 ohms, whichever is greater, CRV) Physical Characteristics Mechanical Angle ................. 270 ° nom. Torque............................. 3.0 oz-in. max. Stop Strength ................. 7.0 oz -in. min. Terminals .......................Solderable pins Weight ....................................... 0.02 oz. Marking....................... Resistance code, terminal numbers, manufacturer’s model number, style and date code Wiper ............... 50 % (Actual TR) ±10 % Flammability ..........................U.L. 94V-0 Standard Packaging .....50 pcs. per tube Adjustment Tool..............................H-90 Product Dimensions 6.60 (.260) ADJ. CROSS SLOT 2.77 LONG X (.109) .64 WIDE X (.025) .89 DEEP X (.035) 6.99 .25 TYP. (.275) (010) 3.84 (.151) 4.70 (.185) .46 ± .03 (.018 ± .001) .330 (.013) 2.54 (.100) www.P65Warnings.ca.gov 3.84 (.151) DIA. .46 ± .03 (.018 ± .001) 3 PLCS. PIN MARKING REVERSED FOR STYLE W 5.46 ± .38 (.215 ± .015) 2.54 2.54 (.100) 5.46 ± .38 (.215 ± .015) 2.29 (.090) 1.22 (.048) .46 ± .12 (.018 ± .005) DIA. 3 PLCS. 4.70 (.185) 1 5.08 (.200) 3 2 2.54 (.100) 1 2 3 4.06 ± .38 (.160 ± .015) 90° ± 5° 3 4.70 (.185) 1.02 (.040) 1 1 2 3 2.54 (.100) 1.80 (.071) 4.70 (.185) 2 2.54 (.100) TYP. 1.02 (.040) 3 2.54 (.100) 1 2 2 1 2.54 (.100) 3.53 (.139) 4.70 (.185) 3 1.02 (.040) 1.02 (.040) 1 2.54 (.100) 1 2 DIMENSIONS: 0.25 (.010) 2 2 3 2.54 (.100) 3 4.70 (.185) 3.53 (.139) TOLERANCES: ± WARNING Cancer and Reproductive Harm 6.99 .25 TYP. (.275) (010) (.100) 2.54 (.100) 1 *RoHS Directive 2002/95/EC Jan. 27, 2003 including annex and RoHS Recast 2011/65/EU June 8, 2011. †“Fluorinert” is a registered trademark of 3M Co. 6.60 (.260) ADJ. CROSS SLOT 2.77 LONG X (.109) .64 WIDE X (.025) .89 DEEP X (.035) 1.02 (.040) 2 2 3 MM (INCHES) 3 CCW 1 WIPER 3 1 CW CLOCKWISE EXCEPT WHERE NOTED Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf. 3362 - 1/4 ” Square Trimpot® Trimming Potentiometer Product Dimensions How To Order SIDE ADJUST 3362M-1 Top adjust models 3362F, H, P, R and U are 25.02 ± .76 (0.985 ± .030) (“P” Style shown) 3362 P - 1 - 502 T __ LF 12.70 REF. (.500) 18 ± .76 (.708 ± .029) 7.0 (.275) 6.71 (.264) 7.04 (.277) 0.25 (.010) 3.84 (.151) 3 2 1 ADJ. SLOT 4.0 LONG (.157) 0.6 X WIDE (.024) 1.0 X DEEP (.039) 2.54 (.100) 4.0 ± 0.3 DIA. (.157 ± .011) 4.7 (.185) 2.54 CENTER (.100) 1000/REEL/BOX 12.70 REF. (.500) 18 ± .76 (.708 ± .029) 22.7 ± .76 4.7 (.893 ± .029) (.185) DIMENSIONS: TOLERANCES: ± 0.25 (.010) 2 3 5.46 (.215) 4.7 (.185) Terminations LF = 100 % Tin-plated (RoHS compliant) Blank = 90 % Tin / 10 % Lead-plated (Standard) Consult factory for other available options. 1 5.00 DIA. (.197) Packaging Designator Blank = Tube (Standard) R = Tape and Reel (M, U and P Pin Styles Only) A = Ammo Pack (M, U and P Pin Styles Only) Tape and reel material meets Antistatic ANSI/ ESD 5541-2003 packaging standards. *Knob option is available only in standard Tube packaging for terminal styles F, H, P, R and U. DIA. 3 PLCS. 0.46 ± 0.03 (.018 ± .001) 9.93 (.391) 2.3 ± .38 (.090 ± .014) MM (INCHES) TOP ADJUST 3362U-1, 3362P-1 14.63 (.576) Product Indicator -1 = Standard Product Resistance Code 3 18 + 1.0/ - 0.5 (.709 + .039 -.019) 12.7 + 0.3/ -0.25 (.500 + .012/ -.009) DIMENSIONS: 2.54 (.100) Style T = Knob* ALL PINS IN-LINE ON 3.53 (.139) 2.54 (.100) 2 1 Model MM (INCHES) 18 + .76/ -.5 (.708 + .029 -.019) 12.70 + 0.3/ - 0.25 (.500 + .011 -.009) 4.0 ± 0.3 DIA. (.157 ± .011) EXCEPT WHERE NOTED SIDE VIEW 3362U-1 SIDE VIEW 3362P-1 7.0 (.275) 3.56 ± .38 (.140 ± .014) ALL PINS IN-LINE ON DIMENSIONS: Resistance (Ohms) 10 20 50 100 200 500 1,000 2,000 5,000 10,000 20,000 25,000 50,000 100,000 200,000 250,000 500,000 1,000,000 2,000,000 Resistance Code 100 200 500 101 201 501 102 202 502 103 203 253 503 104 204 254 504 105 205 Popular distribution resistance values listed in boldface. Special resistances available. 2.54 CENTER (.100) MM (INCHES) Standard Resistance Table 750/REEL 1000/BOX Meets EIA Specification 468. REV. 09/16 “Trimpot” is a registered trademark of Bourns, Inc. Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf. Legal Disclaimer Notice This legal disclaimer applies to purchasers and users of Bourns® products manufactured by or on behalf of Bourns, Inc. and P[ZHɉSPH[LZJVSSLJ[P]LS`¸)V\YUZ¹ Unless otherwise expressly indicated in writing, Bourns® products and data sheets relating thereto are subject to change ^P[OV\[UV[PJL
3362P-1-104LF 价格&库存
很抱歉,暂时无法提供与“3362P-1-104LF”相匹配的价格&库存,您可以联系我们找货
