SK Series
SK Series
7 mm Standard 105℃
Features
◆ Design for space-saving and high density insertion.
◆ Applications: VTR, car radio, car stereos. charger, etc.
◆ RoHS Compliant
Specifications
Item
Performance Characteristics
Operating Temperature Range
-40 to +105℃
Rated Voltage Range
4 to 63 VDC
Capacitance Range
0.1 to 470 μF
Capacitance Tolerance
Leakage Current(+20℃, max)
Dissipation Factor
(tanδ,at 20℃,120Hz)
±20% (120Hz, +20℃)
I≦0.01 CV or 3 (μA)
After 1 minute, whichever is greater measured with rate working voltage applied.
Working Voltage (VDC)
D.F. (%)max
4
25
6.3
22
10
16
25
14
35
12
50
10
63
9
4
7
15
6.3
4
8
10
3
6
16
2
4
25
2
4
35
2
3
50
2
3
63
2
3
Impedance ratio max
Radial
Low Temperature Characteristics
(at 120Hz)
Endurance
Shelf Life
Z-25℃ / Z+20℃
Z-40℃ / Z+20℃
Test conditions
Duration time
:1000 Hrs
Ambient temperature
:+105℃
Applied voltage
:Rated DC working voltage
After test requirement at +20℃
Capacitance change
:≦ ±20% of the initial measured value (4V : ≦ ±30%)
Dissipation factor
:≦ 200% of the initial specified value
Leakage current
:≦ The initial specified value
Test conditions
Duration time
Ambient temperature
Applied voltage
:1000 Hrs
:+105℃
:None
After test requirement at +20℃ : Same limits as Endurance.
Pre-treatment for measurements shall be conducted after application of DC working voltage
for 30 minutes.
Multiplier for Ripple Current vs. Frequency
CAP(μF) Frequency(Hz) 50(60) 120
0.8
1
CAP≦10
0.8
1
10<CAP≦100
0.8
1
100<CAP≦1000
400
1.30
1.23
1.16
1K
1.45
1.36
1.25
10K 50K-100K
1.65
1.70
1.48
1.53
1.35
1.38
Diagram of Dimensions:(unit:mm)
Dφ
F
dφ
102
4
5
1.5±0.5 2.0±0.5
0.45
6.3
8
2.5±0.5 3.5±0.5
0.5
SK Series
Case Size
φDxL(mm)
WV
Cap(μF)
4.7
6.8
4
Size
6.3
Ripple
Size
10
Ripple
Size
16
Ripple
10
15
22
33
47
68
100
220
330
470
4x7
23
4x7
31
4x7
26
4x7
35
5x7
55
4x7
5x7
4x7
5x7
5x7
32
35
40
47
55
5x7
58
6.3x7
65
6.3x7
8x7
90
120
5x7
6.3x7
6.3x7
8x7
8x7
65
75
90
120
120
WV
Cap(μF)
0.1
0.15
0.22
0.33
0.47
0.68
1
1.5
2.2
3.3
4.7
6.8
10
15
22
33
47
68
4x7
4x7
28
35
4x7
5x7
4x7
5x7
5x7
6.3x7
5x7
6.3x7
6.3x7
8x7
40
45
47
51
60
68
80
90
105
150
35
25
Size
Ripple
4x7
4x7
4x7
4x7
5x7
4x7
5x7
5x7
6.3x7
6.3x7
32
37
42
45
50
61
67
72
6.3x7
8x7
95
105
50
Size
Ripple
4x7
22
4x7
5x7
4x7
5x7
5x7
6.3x7
5x7
6.3x7
6.3x7
8x7
8x7
8x7
24
28
30
35
38
45
50
58
54
68
80
85
Size
4x7
4x7
4x7
5x7
5x7
5x7
6.3x7
5x7
6.3x7
6.3x7
8x7
6.3x7
Ripple
17
21
30
33
38
45
48
52
60
68
72
75
8x7
115
63
Size
4x7
4x7
4x7
4x7
4x7
4x7
4x7
4x7
4x7
4x7
4x7
5x7
5x7
6.3x7
5x7
6.3x7
6.3x7
Ripple
1.5
1.8
2.5
3.5
5
7
10
13
19
24
27
29
32
33
35
38
52
Size
4x7
4x7
4x7
4x7
4x7
4x7
4x7
4x7
4x7
5x7
5x7
6.3x7
6.3x7
Ripple
1.5
1.8
2.5
3.5
6
7
12
14
19
25
29
33
35
6.3x7
40
8x7
55
6.3x7
8x7
8x7
60
63
78
8x7
65
Ripple Current ( mA, rms ) at 105℃ 120Hz
103
很抱歉,暂时无法提供与“SK221M016E070A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.41460
- 100+0.24720
- 500+0.17310
- 1000+0.12360
- 2000+0.11740
- 10000+0.10880
