US1M
US1M
    HOTTECH(合科泰)
    SMA(DO-214AC)
    直流反向耐压(Vr):1kV 平均整流电流(Io):1A 正向压降(Vf):1.7V@1A 反向电流(Ir):5μA@1kV 反向恢复时间(trr):75ns
US1M 数据手册
Plastic-Encapsulate Diodes FAST RECOVERY RECTIFIERS US1A ---US1M FEATURES For surface mount applications 52 0 32 Low profile package Built-in strain relief 7 4.50 Easy pick and place Ultrafast recovery times for high efficiency Plastic package has Underwriters Laboratories Flammability Classification 94V-0 MECHANICAL DATA SMA (DO-214AC) molded plastic DO-214AC (SMA) Polarity: Color band denotes cathode end MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS O Ratings at 25 C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20%. Symbols Parameter US1A US1B US1D US1G US1J US1K US1M Unit Maximum Repetitive Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at TL = 100 OC IF(AV) 1 A IFSM 30 A Peak Forward Surge Current 8.3 ms Single Half Sine-wave Superimposed on Rated Load (JEDEC Method) VF Maximum Forward Voltage at 1 A Maximum DC Reverse Current at Rated DC Blocking Voltage 1 1.4 O TA = 25 C O TA = 100 C Typical Junction Capacitance at 4 V, 1 MHz 1.7 V 5 IR μA 100 CJ 17 pF Maximum Reverse Recovery Time at IF = 0.5 A, IR = 1 A, Irr = 0.25 A Typical Thermal Resistance 1) Operating and Storage Temperature Range trr 50 75 RθJA 50 TJ ,TS - 55 to + 150 ns O C/W O C 1)Mounted on P.C.B. with 0.2 X 0.2" (5 X 5 mm) copper pad areas. GUANGDONG HOTTECH INDUSTRIAL CO,. LTD. Page:P2-P1 Plastic-Encapsulate Diodes US1A---US1M Typical Characteristics GUANGDONG HOTTECH INDUSTRIAL CO,. LTD. Page:P2-P2
很抱歉,暂时无法提供与“US1M”相匹配的价格&库存,您可以联系我们找货
US1M
  • 1+0.09603
  • 50+0.04807
  • 2000+0.03641
库存:8784
US1M
  • 50+0.06380
  • 500+0.05190
  • 2000+0.04110
  • 4000+0.03680
  • 24000+0.03350
  • 50000+0.03140
库存:20303
US1M
  • 50+0.03885
  • 500+0.03497
  • 5000+0.03238
  • 10000+0.03108
  • 30000+0.02978
  • 50000+0.02901
库存:6
US1M
    • 1+0.02580
    库存:2330
