Surface Mount Bridge Rectifier
DB101S ---DB107S
FEATURES
• UL Recognized Component
• Ideal for Printed Circuit Board
• Glass Passivated Chip Junctions, Surge Overload Rating of 50A Peak
• Simple, Compact Structure for Trouble-free Performance
• Plastic Package - UL Flammability Classification 94V-0
.310 (7.9)
.290 (7.4)
.255 (6.5)
.245 (6.2)
.335 (8.51)
.320 (8.13)
.135 (3.4)
.115 (2.9)
Mechanical Data
• Case: Transfer Molded Epoxy
• Mounting Position: Any
• Polarity: Polarity Symbols Marked on Body
.205 (5.2)
.195 (5.0)
.042 (1.1)
.038 (1.0)
.013 (.330)
.003 (.076)
.410 (10.4)
.360 (9.4)
DB-S
.009
(9.4)
.060 (1.524)
.040 (1.016)
Dimensions in inches and (millimeters)
Maximum Ratings and
Electrical Characteristics
(Ta=25
unless otherwise noted)
Symbo1
DB
101S
DB
102S
DB
103S
DB
104S
DB
105S
DB
106S
DB
107S
Maximum Recurrent Peak Reverse Voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS Input Voltage
VRMS
35
70
140
280
420
560
700
V
Maximum OC Blocking Voltage
VOC
50
100
200
400
600
800
1000
V
Characteristic
Maximum Average Rectified output Current @
TA = 40OC
Peak Forward Surge Current Single Half Sine一wave
Superimposed on Rated Load (JEOEC Method)
Maximum Instantaneous Forward Voltage drop per
Unit
I(AV)
1.0
A
IFSM
50
A
VF
1.1
V
IR
10
1.0
uA
Element at IF = 1.0A
Maximum Reverse OC Current at Rated
@ TA =
OC Blocking Voltage per Element
@ TA = 100OC
25OC
Typical Thermal Resistance (Note 1)
Storage and operating Temperature Range
mA
RqJA
40
TJ, TSTG
一55 to +150
K/W
O
C
Notes: 1. Thermal resistance from junction to ambient mounted on PC board with 13mm x 13mm copper pads.
2. 60 Hz resistive or inductive load.
3. For capacitive load, derate current by 20%.
GUANGDONG HOTTECH
INDUSTRIAL CO,. LTD.
Page:P2-P1
DB101S ---DB107S
CHARACTERISTIC CURVES
FIG. 1 - MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
FIG. 2 - TYPICAL FORWARD CURRENT
DERATING CURVE
1.0
50
8.3ms Single Half Sine-Wave
(JEDED Method)
40
30
AVERAGE FORWARD CURRENT, (A)
PEAK FORWARD SURGE CURRENT, (A)
60
Single Phase Half Wave
60Hz Inductive or
Resistive Load
4
6 10
20 40 60
NUMBER OF CYCLES AT 60Hz
FIG. 3 - TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
10
Pulse Width = 300us
1% Duty Cycle
1.0
TJ = 25
0.1
.01
40
60
80
100
120 140
AMBIENT TEMPERATURE, ( )
160
FIG. 4 - TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT, (uA)
INSTANTANEOUS FORWARD CURRENT, (A)
.5
10
1.0
TJ = 25
0.1
.01
.4
.6
.8
1.0
1.2
1.4
INSTANTANEOUS FORWARD VOLTAGE, (V)
GUANGDONG HOTTECH
60
80
100
120 140
PERCENT OF RATED PEAK REVERSE VOLTAGE, (%)
Page:P2-P2
很抱歉,暂时无法提供与“DB107S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.33867
- 100+0.27998
- 300+0.25064
- 600+0.24688
- 1500+0.20361
