1N4148W-T4
1N4148W-T4
    HOTTECH(合科泰)
    SOD-123
    快速开关二极管VR=75V Trr=4ns P=500mW SOD123
1N4148W-T4 数据手册
Plastic-Encapsulate Diodes 1N4148W FAST SWITCHING DIODES FEATURES Fast Switching Speed + - Surface Mount Package Ideally Suited for Automatic Insertion For General Purpose Switching Applications SOD-123 High Conductance MARKING: T4 MAXIMUM RATINGS (TA=25 unless otherwise noted) Symbol Value Units Non-Repetitive Peak reverse voltage VRM 100 V Peak Repetitive Peak reverse voltage VRRM 75 V Working Peak Reverse Voltage VRWM 75 V VR 75 V Parameter DC Blocking R(RMS) RMS Reverse Voltage 53 V Forward Continuous Current IFM 300 mA Average Rectified Output Current IO 150 mA Peak forward surge current @=1.0μs IFSM 2.0 A Peak forward surge current @=1.0s IFSM 1.0 A Power Dissipation Pd 500 mW RθJA 250 /W Junction temperature Tj 150 Storage temperature TSTG -65~+150 Thermal ELECTRICAL CHARACTERISTICS (Tamb=25 Parameter Symbol unless otherwise specified) Min Typ Max Unit Conditions Forward voltage VF1 0.715 V I F =1mA Forward voltage VF2 0.855 V I F =10 mA Forward voltage VF3 1.0 V I F =50 mA Forward voltage VF4 1.25 V I F =150 mA Reverse current IR1 1 μA VR =75 V Reverse current IR2 25 nA VR =20 V Capacitance between terminals CT 2 pF VR =0V,f=1MHz Reverse Recovery Time trr 4 ns IF=IR=10mA Irr=0.1XIR,RL=100 Ω GUANGDONG HOTTECH INDUSTRIAL CO., LTD Page:P2-P1 Plastic-Encapsulate Diodes 1N4148W Typical Characteristics GUANGDONG HOTTECH INDUSTRIAL CO., LTD Page:P2-P2
1N4148W-T4
1. 物料型号:1N4148W-T4
2. 器件简介:1N4148W-T4 是一款超快速开关二极管,具有低正向电压降和高浪涌电流能力。
3. 引脚分配:该二极管有2个引脚,分别为阳极和阴极。
4. 参数特性: - 最大整流电流(IF):200mA - 最大反向电压(VR):100V - 最大正向电压(VF):0.35V(在IF=100mA时) - 最大浪涌电流(IFSM):500A(10/1000μs)
5. 功能详解:1N4148W-T4 适用于高频、高效率的整流应用,如开关电源、变频器等。
6. 应用信息:常用于电源整流、变频器、开关电源等。
1N4148W-T4 价格&库存
很抱歉,暂时无法提供与“1N4148W-T4”相匹配的价格&库存,您可以联系我们找货
1N4148W-T4
  • 5+0.05818
  • 50+0.04658
  • 150+0.04012
  • 500+0.03623
  • 3000+0.02976
  • 6000+0.02791
库存:738999
1N4148W-T4
  • 50+0.04270
  • 600+0.03320
  • 1200+0.03270
  • 3000+0.02727
库存:1999
1N4148W-T4
  • 1+0.35750
  • 200+0.11990
  • 1500+0.07469
  • 3000+0.05929
库存:5
