Plastic-Encapsulate Diodes
1.0 AMP. Surface Mount Rectifiers
M1F ---M7F
Cathode Band
Top View
FEATURES
For surface mounted application
0.106(2.70)
0.094(2.40)
Low forward voltage drop
0.063(1.60)
0.051(1.30)
High current capability
0.146(3.7)
0.130(3.3)
Easy pick and place
High surge current capability
0.0091(0.23)
0.0071(0.18)
0.051(1.30)
0.043(1.10)
Plastic material used carries Underwriters
Laboratory Classification 94V-0 260oC / 10 seconds at terminals
0.051(1.30)
0.039(1.0)
MECHANICAL DATA
0.193(4.90)
0.173(4.40)
Case: Molded plastic SMAF
Terminals: Pure tin plated, lead free
Dimensions in inches and (millimeters)
solderable per J-STD-002B and JESD22-B102D.
SMAF
Polarity: Indicated by cathode band
Packaging: 12mm tapeper EIA STD RS-481
MAXIMUM RATINGS
AND
ELECTRICAL CHARACTERISTICS
Ratings at 25 OC ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For
capacitive load, derate current by 20%.
MDD Catalog Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=75 C
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction and storage temperature range
SYMBOLS
M1F
M2F
M3F
M4F
M5F
M6F
M7F
UNITS
VRRM
VRMS
VDC
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
VOLTS
VOLTS
VOLTS
I(AV)
1.0
Amp
IFSM
30.0
Amps
VF
1.1
Volts
IR
5.0
50.0
µA
CJ
RθJA
TJ,TSTG
15.0
75.0
-50 to +150
pF
C/W
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
GUANGDONG HOTTECH
INDUSTRIAL CO., LTD
Page:P2-P1
M1F ---M7F Typical Characteristics
2.0
1.0
25 50 75 100 125 150175
LEAD TEMPERATURE .o C
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD CURRENT,
AMPERES
30
SINGLE PHASE
HALF WAVE 60Hz
RESISTIVE OR
INDUCTIVE LOAD
P.C.B MOUNTED
ON 0.315x0.315"(8.0x8.0mm)
COPPER PAD AREAS
25
15
10
5
1
INSTANTANEOUS FORWARD CURRENT,
MICROAMPERES
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
10
Tj =125o C
Tj =75o C
Tj =25o C
0.01
0.001
60
5
10
100
Fig. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
100
0.1
2
NUMBER OF CYCLES AT 60 Hz
Fig. 1-FORWARD CURRENT
DERATING CURVE
1
8.3ms Single Half Sine Wave
(JEDEC Method)
PERCENT OF PEAK REVERSE VOLTAGE, %
100
50
5
2
1
0.5
0.2
0.1
0.05
0.02
0.01
0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0
VOLTAGE , VOLTS
Fig. 4-TYPICAL INSTANTANEOUS
FORWARD CHARACTERISTICS
Fig. 3-TYPICAL REVERSE
CHARACTERISTICS
500
200
100
50
Units Mounted On
20in2 (5.4mm 2 )+0.5mil
inches(0.013mm)
Thick Copper Land Areas
CAPACITANCE. pF
THERMAL IMPEDANCE (oC/W)
1000
5
2
1
0.01
0.1
1
10
Tj =25 oC
f=1.0MHz
Vsig=50mVp-p
50
5
2
1
10
100
1000
100
REVERSE VOLTAGE VOLTS
Fig. 5-TRANSIENT THERMAL IMPEDANCE
GUANGDONG HOTTECH
100
Fig. 6-TYPICAL JUNCTION CAPACITANCE
INDUSTRIAL CO., LTD
Page:P2-P2
很抱歉,暂时无法提供与“M7F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.06823
- 500+0.05192
- 3000+0.04771
- 6000+0.04228
- 24000+0.03756
- 51000+0.03500
- 国内价格
- 5+0.03383
- 20+0.03085
- 100+0.02786
- 500+0.02488
- 1000+0.02348
- 2000+0.02249
