TSV324(TSSOP-14)
TSV324(TSSOP-14)
    TRUSIGNAL(坤元微电子)
    TSSOP-14
    1MHz低电压四通道轨到轨运算放大器 最大失调5mV 产品性能媲美LMV324
TSV324(TSSOP-14) 数据手册
Trusignal Microelectronics TSV321 TSV358 TSV324 July 2018 1MHz, Rail-to-Rail I/O CMOS Operational Amplifiers FEATURES GENERAL DESCRIPTION       TSV321/TSV358/TSV324 are the most cost-effective amplifiers for low voltage, low power consumption and low-cost applications. The rail-to-rail output and rail-torail inputs that exceed power supply range make the TSV321 series easy to use for very low voltage supply applications.   RAIL-TO-RAIL INPUT/OUTPUT HIGH SLEW RATE: 0.8V/μs LOW INPUT BIAS CURRENT: 10pA typ at 25°C GAIN BANDWIDTH PRODUCT: 1 MHz LOW OFFSET VOLTAGE DRIFT: 3μV/°C typ LOW POWER CONSUMPTION: 90μA per amplifier at 5 V LOW SUPPLY VOLTAGE: 2.5 V ~ 5.5 V (25°C) EXTENDED TEMPERATURE: -40°C to +125°C Low IB feature of these amplifiers allows the parts to be ideal for many sensor applications. 1MHz GBW and 0.8V/μs slew rate under low power supply voltage can meet almost all sensor requirement. APPLICATIONS         Small Packages: BATTERY-POWERED APPLICATIONS PORTABLE DEVICES SIGNAL CONDITIONING ACTIVE FILTERING CURRENT SENSOR AMPLIFIER WEIGHT SCALE SENSOR MEDICAL/ INDUSTRIAL INSTRUMENTATION INSTRUMENTATION TSV321 in a SOT23-5 and SC70-5 TSV358 in a SO8 and MSOP8 TSV324 in a SO14 and TSSOP14 PIN ASSIGNMENTS 5 V+ +IN 1 V- 2 + - -IN 3 SOT23-5,SC-70 TSV324 TSV358 TSV321 OUTA 1 -INA 2 4 OUT +INA 3 + - 8 V+ OUTA 1 7 OUTB -INA 2 6 -INB +INA 3 14 OUTD 13 -IND - + + - V- 4 + SO-8,MSOP-8 5 +INB +INB 5 -INB 6 12 +IND 11 V- V+ 4 10 +INC - + + - OUTB 7 9 -INC 8 OUTC SO-14, TSSOP-14 PROPRIETARY AND CONFIDENTIAL REV KY.1.0.1A6 Trusignal Microelectronics TSV321 TSV358 TSV324 ORDERING INFORMATION Model Part Number Eco Plan Package AMP Container, Pack Qty TSV321 TSV321SOT235R Rohs SOT23-5 1 Reel, 3000 TSV321 TSV321SC705R Rohs SC70-5 1 Reel, 3000 TSV358 TSV358SO8R Rohs SO-8 2 Reel, 2500 TSV358 TSV358MSOP8R Rohs MSOP-8 2 Reel, 3000 TSV324 TSV324SO14R Rohs SO-14 4 Reel, 2500 TSV324 TSV324TSSOP14R Rohs TSSOP-14 4 Reel, 3000 ABSOLUTE MAXIMUM RATINGS Parameter Min Supply Voltage Max Unit 7.0 V Signal Input Terminal Voltage (V-) - 0.5 (V+) + 0.5 V Operating Temperature -50 150 C 150 C 150 C 260 C ESD HBM ±3000 V ESD MM ±400 V ESC CDM ±1000 V Junction Temperature Storage Temperature Lead Temperature (Soldering, 10s) -65 ESD CAUTION ESD (Electrostatic Discharge) sensitive device. Charged devices and circuit boards can discharge without detection. Although this product features patented or proprietary protection circuitry, damage may occur on devices subjects to high energy ESD. Therefore, proper ESD precautions should be taken to avoid performance degradation or loss of functionality. REV KY.1.0.1A6 2 www.kunyuanic.com Trusignal Microelectronics TSV321 TSV358 TSV324 ELECTRICAL CHARACTERISTICS VS = +2.5V to +5.5V, at TA = +25C, RL=100kΩ connected to VS/2, and VOUT = VS/2, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40C to +125C. Symbol Parameter Operating Conditions Min Typ Max Unit 1.2 3 5 mV μV/°C Input Characteristics VOS dVOS/dT CMRR Input Offset Voltage Drift Common Mode Rejection Ratio TA = −40C to +125C TA = −40C to +125C IB IOS PSRR AOL VS=5V (V-) - 0.2V < VCM < (V+) - 2V 73 84 dB (V-) - 0.2V < VCM < (V+) - 2V VS = 5.5V, (V−) − 0.2V < VCM < (V+) + 0.2V VS = 5.5V, (V−) − 0.2V < VCM < (V+) + 0.2V 65 57 56 70 dB dB dB 10 10 pA pA 87 dB Input Bias Current Input Offset Current Power Supply Rejection Ratio TA = −40C to +125C Open-Loop Gain TA = −40C to +125C Open-Loop Gain TA = −40C to +125C VS = 2.5V to VS = 5.5V, VCM < (V+) - 2V 66 63 VS = 5V RL = 5kΩ, 0.125V < VO < 4.875V VS = 5V RL= 5kΩ, 0.125V < VO < 4.875V VS = 5V RL= 100kΩ, 0.025V < VO < 4.975V VS = 5V RL= 100kΩ, 0.025V < VO < 4.975V 86 70 95 76 dB 100 dB dB dB dB 108 Output Characteristics ROUT Output Voltage Swing from Rail Open-Loop Output Impedance RL = 100KΩ 10 mV f = 1MHz, Io = 0 280 Ω VOUT = 2V step; G = +1 Vin * Gain > VS G = +1 1 3 1 0.8 MHz μs μs V/μs Frequency Domain Response GBW tS SR Gain Bandwidth Product Settling Time to 0.1% Overload recovery time Slew Rate Power Supply VS IS Specified Voltage Range Operating Voltage Range Supply Current 2.5 2.2 IO = 0, VS = 5V 90 5.5 5.5 V V 140 μA 125 ºC Temperature Range θJA Specified Range Thermal Resistance SO-8 REV KY.1.0.1A6 −40 150 3 ºC/W www.kunyuanic.com Trusignal Microelectronics TSV321 TSV358 TSV324 TYPICAL CHARACTERISTICS At TA = +25C, RL = 10kΩconnected to VS/2, and VOUT = VS/2, unless otherwise noted. OPEN−LOOP GAIN AND PHASE vs FREQUENCY 0 Open−Loop Gain (dB) 100 Gain 80 100 -20 90 -40 80 -60 60 -80 40 -100 Phase 20 -120 Phase Margin () 120 60 50 30 -140 20 -160 10 -180 0 100 10K 100 1M Frequency (Hz) PSRR 40 -20 1 CMRR 70 0 -40 POWER−SUPPLY AND COMMON−MODE REJECTION RATIO vs FREQUENCY 110 AOL RO=100K PSRR 95 VSS = 5.5V 100 105 100 1M COMMON-MODE REJECTION RATION VS TEMPERATURE 105 CMRR (DB) AOL, PSRR (DB) AOL RO=5K 100K LARGE−SIGNAL STEP RESPONSE OPEN−LOOP GAIN AND POWER−SUPPLY REJECTION RATIO vs TEMPERATURE 115 10K Frequency (Hz) SMALL−SIGNAL STEP RESPONSE 120 1K 90 95 VCM = -0.2V to 3.5v 90 85 80 VCM = -0.2V to 5.7V 75 85 70 80 -55 -30 -5 20 45 70 95 -55 120 145 -5 20 45 70 95 120 145 Temperature(℃) Temperature (℃) REV KY.1.0.1A6 -30 4 www.kunyuanic.com Trusignal Microelectronics TSV321 TSV358 TSV324 TYPICAL CHARACTERISTICS At TA = +25C, RL = 10kΩconnected to VS/2, and VOUT = VS/2, unless otherwise noted. INPUT VOLTAGE NOISE SPECTRAL DENSITY VS FRENQUENCY 150 140 130 120 110 100 90 80 70 60 50 10000 Voltage Noise (nV/√Hz) Quiescent Current ( A) QUIESCENT CURRENT VS TEMPERATURE VCC = 5V -60 -10 40 90 1000 100 10 1 140 0.1 Temperature (℃) QUIESCENT CURRENT VS SUPPLY VOLTAGE 30 90 85 80 2 3 4 5 10 ISC+ 5 0 2 3 4 5 Power-Supply Voltage (V) 6 OUTPUT VOLTAGE SWING VS OUTPUT CURRENT SHORT-CIRCUIT CURRENT VS TEMPERATURE 4 3 30 Output Voltage (V) Short-Circuit Current (mA) ISC- 15 6 35 ISC+ 25 20 100K CONTINUOUS SHORT-CIRCUIT CURRENT VS POWER-SUPPLY VOLTAGE 20 Supply Voltage (V) 40 1K Frequency (Hz) 25 Short-Circuit Current (mA) Quiescent Current ( A) 95 10 ISC- 15 2 1 150℃ -50℃ 25℃ 0 -1 -50℃ 25℃ 150℃ -2 -3 10 -4 -50 -25 0 25 50 0 75 100 125 150 175 Temperature (℃) REV KY.1.0.1A6 5 10 20 30 Output Current (mA) 40 www.kunyuanic.com Trusignal Microelectronics TSV321 TSV358 TSV324 TYPICAL CHARACTERISTICS At TA = +25C, RL = 10kΩconnected to VS/2, and VOUT = VS/2, unless otherwise noted. Offset Voltage Drift Magnitude Production Distribution Population Population Offset Voltage Production Distribution 5 4 3 2 1 0 -1 -2 -3 -4 -5 Offset Voltage(mV) REV KY.1.0.1A6 Offset Voltage Drift(uV/℃) 6 www.kunyuanic.com Trusignal Microelectronics TSV321 TSV358 TSV324 MECHANICAL DIMENSIONS SOT23-5 PACKAGE MECHANICAL DRAWING θ SOT23-5 PACKAGE MECHANICAL SPECIFICATIONS dimensions symbol millimeters min max min max A 2.650 2.950 0.104 0.116 A1 1.500 1.700 0.059 0.067 B 2.820 3.020 0.111 0.119 B1 REV KY.1.0.1A6 inches 0.950 0.037 B2 0.300 0.500 0.012 0.020 C 1.050 1.250 0.041 0.049 C1 -- 0.100 -- 0.004 L 0.300 0.600 0.012 0.024 D 0.100 0.200 0.004 0.008 θ 0o 0o 8o 8 7 o www.kunyuanic.com Trusignal Microelectronics TSV321 TSV358 TSV324 SC70-5 PACKAGE MECHANICAL DRAWING SC70-5 PACKAGE MECHANICAL SPECIFICATIONS dimensions symbol millimeters min max min max A 2.150 2.450 0.085 0.096 A1 1.150 1.350 0.045 0.053 B 2.000 2.200 0.079 0.087 B1 REV KY.1.0.1A6 inches 0.650 0.026 B2 0.150 0.350 0.006 0.014 C 0.900 1.100 0.035 0.043 C1 -- 0.100 -- 0.004 L 0.260 0.460 0.010 0.018 D 0.080 0.150 0.003 0.0087 θ 0o 8o 0o 8o 8 www.kunyuanic.com Trusignal Microelectronics TSV321 TSV358 TSV324 MSOP-8 PACKAGE MECHANICAL DRAWING θ MSOP-8 PACKAGE MECHANICAL SPECIFICATIONS dimensions symbol millimeters min max min max A 4.750 5.050 0.187 0.199 A1 2.900 3.100 0.114 0.122 B 2.900 3.100 0.114 0.122 B1 REV KY.1.0.1A6 inches 0.650 0.026 B2 0.250 0.380 0.010 0.015 C 0.820 1.100 0.032 0.043 C2 0.020 0.150 0.001 0.006 L 0.400 0.800 0.016 0.031 D 0.090 0.230 0.004 0.009 θ 0o 6o 0o 6o 9 www.kunyuanic.com Trusignal Microelectronics TSV321 TSV358 TSV324 TSSOP-14 PACKAGE MECHANICAL DRAWING θ TSSOP-14 PACKAGE MECHANICAL SPECIFICATIONS dimensions symbol millimeters min max min max A 6.250 6.550 0.246 0.258 A1 4.300 4.500 0.169 0.177 B 4.900 5.100 0.193 0.201 B1 REV KY.1.0.1A6 inches 0.650 0.026 B2 0.190 0.300 0.007 0.012 C -- 1.200 -- 0.047 C1 0.050 0.150 0.002 0.006 L 0.500 0.700 0.020 0.028 D 0.090 0.200 0.004 0.008 θ 0o 7o 0o 7o 10 www.kunyuanic.com Trusignal Microelectronics TSV321 TSV358 TSV324 SO-8 PACKAGE MECHANICAL DRAWING θ SO-8 PACKAGE MECHANICAL SPECIFICATIONS dimensions symbol millimeters min max min max A 5.800 6.200 0.228 0.244 A1 3.800 4.000 0.150 0.157 B 4.700 5.100 0.185 0.201 B1 REV KY.1.0.1A6 inches 1.270 0.050 B2 0.330 0.510 0.013 0.020 C 1.350 1.750 0.053 0.069 C1 0.100 0.250 0.004 0.010 L 0.400 1.270 0.016 0.050 D 0.170 0.250 0.007 0.010 θ 0o 8o 0o 8o 11 www.kunyuanic.com Trusignal Microelectronics TSV321 TSV358 TSV324 SO-14 PACKAGE MECHANICAL DRAWING θ SO-14 PACKAGE MECHANICAL SPECIFICATIONS dimensions symbol millimeters min max min max A 5.800 6.200 0.228 0.244 A1 3.800 4.000 0.150 0.157 B 8.450 8.850 0.333 0.348 B1 1.270 0.050 B2 0.310 0.510 0.012 0.020 C -- 1.750 -- 0.069 C1 0.100 0.250 0.004 0.010 L 0.400 1.270 0.016 0.050 D 0.100 0.250 0.004 0.010 θ REV KY.1.0.1A6 inches 0 o 8 o 12 o 0 8o www.kunyuanic.com Trusignal Microelectronics TSV321 TSV358 TSV324 CONTACT INFORMATION Trugsignal Microelectronics Phone: +86 512-65923982 Fax: +86 512-65923995 Email: sales@kunyuanic.com support@kunyuanic.com REV KY.1.0.1A6 13 www.kunyuanic.com
TSV324(TSSOP-14) 价格&库存
很抱歉,暂时无法提供与“TSV324(TSSOP-14)”相匹配的价格&库存,您可以联系我们找货
