BC846BW,115
BC846BW,115
    NEXPERIA(安世)
    SOT-323
    通用三极管 65V 100mA NPN SOT323 200~450
BC846BW,115 数据手册
BC846 series 65 V, 100 mA NPN general-purpose transistors Rev. 9 — 25 September 2012 Product data sheet 1. Product profile 1.1 General description NPN general-purpose transistors in Surface-Mounted Device (SMD) plastic packages. Table 1. Product overview Type number[1] Package Nexperia JEITA JEDEC BC846 SOT23 - TO-236AB BC856 BC846W SOT323 SC-70 - BC856W BC846T SOT416 SC-75 - BC856T [1] PNP complement Valid for all available selection groups. 1.2 Features and benefits  General-purpose transistors  SMD plastic packages  Two different gain selections 1.3 Applications  General-purpose switching and amplification 1.4 Quick reference data Table 2. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 65 V IC collector current - - 100 mA hFE DC current gain 110 - 450 hFE group A 110 180 220 hFE group B 200 290 450 VCE = 5 V; IC = 2 mA BC846 series Nexperia 65 V, 100 mA NPN general-purpose transistors 2. Pinning information Table 3. Pinning Pin Description Simplified outline Graphic symbol SOT23, SOT323, SOT416 1 base 2 emitter 3 collector 3 3 1 1 2 2 sym021 006aaa144 3. Ordering information Table 4. Ordering information Type number[1] Package Name Description Version BC846 - plastic surface-mounted package; 3 leads SOT23 BC846W SC-70 plastic surface-mounted package; 3 leads SOT323 BC846T SC-75 plastic surface-mounted package; 3 leads SOT416 [1] Valid for all available selection groups. 4. Marking Table 5. Type number Marking code[1] BC846 1D* BC846A 1A* BC846B 1B* BC846W 1D* BC846AW 1A* BC846BW 1B* BC846T 1M BC846AT 1A BC846BT 1B [1] BC846_SER Product data sheet Marking codes * = placeholder for manufacturing site code All information provided in this document is subject to legal disclaimers. Rev. 9 — 25 September 2012 © Nexperia B.V. 2017. All rights reserved 2 of 15 BC846 series Nexperia 65 V, 100 mA NPN general-purpose transistors 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 80 V VCEO collector-emitter voltage open base - 65 V VEBO emitter-base voltage open collector - 6 V IC collector current - 100 mA ICM peak collector current single pulse; tp  1 ms - 200 mA IBM peak base current single pulse; tp  1 ms - 200 mA Ptot total power dissipation Tamb  25 C SOT23 - 250 mW SOT323 - 200 mW SOT416 - 150 mW [1] Tj junction temperature - 150 C Tamb ambient temperature 65 +150 C Tstg storage temperature 65 +150 C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 6. Thermal characteristics Table 7. Symbol Rth(j-a) [1] BC846_SER Product data sheet Thermal characteristics Parameter thermal resistance from junction to ambient Conditions in free air Min Typ Max Unit [1] SOT23 - - 500 K/W SOT323 - - 625 K/W SOT416 - - 833 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. All information provided in this document is subject to legal disclaimers. Rev. 9 — 25 September 2012 © Nexperia B.V. 2017. All rights reserved 3 of 15 BC846 series Nexperia 65 V, 100 mA NPN general-purpose transistors 7. Characteristics Table 8. Characteristics Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = 30 V; IE = 0 A - - 15 nA VCB = 30 V; IE = 0 A; Tj = 150 C - - 5 A IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 100 nA hFE DC current gain VCE = 5 V; IC = 10 A hFE group A - 180 - hFE group B - 290 - 110 - 450 DC current gain VCEsat VBEsat VBE Product data sheet hFE group A 110 180 220 hFE group B 200 290 450 collector-emitter saturation voltage base-emitter saturation voltage base-emitter voltage IC = 10 mA; IB = 0.5 mA - 90 200 mV IC = 100 mA; IB = 5 mA [1] - 200 400 mV IC = 10 mA; IB = 0.5 mA [2] - 760 - mV IC = 100 mA; IB = 5 mA [2] - 900 - mV IC = 2 mA; VCE = 5 V [3] 580 660 700 mV IC = 10 mA; VCE = 5 V [3] - - 770 mV fT transition frequency VCE = 5 V; IC = 10 mA; f = 100 MHz 100 - - MHz Cc collector capacitance VCB = 10 V; IE = ie = 0 A; f = 1 MHz - 2 3 pF Ce emitter capacitance VEB = 0.5 V; IC = ic = 0 A; f = 1 MHz - 11 - pF NF noise figure IC = 200 A; VCE = 5 V; RS = 2 k; f = 1 kHz; B = 200 Hz - 2 10 dB [1] BC846_SER VCE = 5 V; IC = 2 mA Pulse test: tp  300 s;  = 0.02. [2] VBEsat decreases by approximately 1.7 mV/K with increasing temperature. [3] VBE decreases by approximately 2 mV/K with increasing temperature. All information provided in this document is subject to legal disclaimers. Rev. 9 — 25 September 2012 © Nexperia B.V. 2017. All rights reserved 4 of 15 BC846 series Nexperia 65 V, 100 mA NPN general-purpose transistors mgt723 400 hFE mgt724 1200 VBE (mV) 1000 (1) 300 (1) 800 (2) (2) 200 600 (3) 400 (3) 100 200 0 10−1 1 10 102 0 10−1 103 1 10 102 I C (mA) VCE = 5 V VCE = 5 V (1) Tamb = 150 C (1) Tamb = 55 C (2) Tamb = 25 C (2) Tamb = 25 C (3) Tamb = 55 C (3) Tamb = 150 C Fig 1. Selection A: DC current gain as a function of collector current; typical values mgt725 103 103 I C (mA) VCEsat (mV) Fig 2. Selection A: Base-emitter voltage as a function of collector current; typical values mgt726 1200 VBEsat (mV) 1000 (1) 800 (2) 102 600 (1) (3) (2) 400 (3) 200 10 10−1 1 10 102 0 10−1 103 1 10 102 IC/IB = 20 IC/IB = 10 (1) Tamb = 150 C (1) Tamb = 55 C (2) Tamb = 25 C (2) Tamb = 25 C (3) Tamb = 55 C (3) Tamb = 150 C Fig 3. Selection A: Collector-emitter saturation voltage as a function of collector current; typical values BC846_SER Product data sheet 103 I C (mA) I C (mA) Fig 4. Selection A: Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 9 — 25 September 2012 © Nexperia B.V. 2017. All rights reserved 5 of 15 BC846 series Nexperia 65 V, 100 mA NPN general-purpose transistors mgt727 600 VBE (mV) 1000 hFE (1) 500 mgt728 1200 (1) 800 400 (2) (2) 300 600 200 400 (3) 100 0 10−1 1 10 (3) 200 102 0 10−2 103 10−1 1 102 103 I C (mA) 10 I C (mA) VCE = 5 V VCE = 5 V (1) Tamb = 150 C (1) Tamb = 55 C (2) Tamb = 25 C (2) Tamb = 25 C (3) Tamb = 55 C Fig 5. (3) Tamb = 150 C Selection B: DC current gain as a function of collector current; typical values mgt729 104 VCEsat (mV) Fig 6. Selection B: Base-emitter voltage as a function of collector current; typical values mgt730 1200 VBEsat (mV) 1000 (1) 103 800 (2) 600 (3) 102 400 (1) 200 (3) (2) 10 10−1 1 10 102 0 10−1 103 1 10 102 IC/IB = 20 IC/IB = 10 (1) Tamb = 150 C (1) Tamb = 55 C (2) Tamb = 25 C (2) Tamb = 25 C (3) Tamb = 55 C (3) Tamb = 150 C Fig 7. Selection B: Collector-emitter saturation voltage as a function of collector current; typical values BC846_SER Product data sheet 103 I C (mA) I C (mA) Fig 8. Selection B: Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 9 — 25 September 2012 © Nexperia B.V. 2017. All rights reserved 6 of 15 BC846 series Nexperia 65 V, 100 mA NPN general-purpose transistors 8. Package outline 3.0 2.8 1.1 0.9 3 0.45 0.15 2.5 1.4 2.1 1.2 1 2 0.48 0.38 1.9 0.15 0.09 Dimensions in mm Fig 9. 04-11-04 Package outline SOT23 (TO-236AB) 2.2 1.8 1.1 0.8 0.45 0.15 3 2.2 1.35 2.0 1.15 1 2 0.4 0.3 0.25 0.10 1.3 Dimensions in mm 04-11-04 Fig 10. Package outline SOT323 (SC-70) BC846_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 25 September 2012 © Nexperia B.V. 2017. All rights reserved 7 of 15 BC846 series Nexperia 65 V, 100 mA NPN general-purpose transistors 0.95 0.60 1.8 1.4 3 0.45 0.15 1.75 0.9 1.45 0.7 1 2 0.30 0.15 0.25 0.10 1 Dimensions in mm 04-11-04 Fig 11. Package outline SOT416 (SC-75) 9. Packing information Table 9. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] BC846_SER Product data sheet Type number[2] Package BC846 SOT23 BC846W BC846T Description Packing quantity 1000 3000 4000 4 mm pitch, 8 mm tape and reel -215 - -235 SOT323 4 mm pitch, 8 mm tape and reel -115 - -135 SOT416 4 mm pitch, 8 mm tape and reel -115 - -135 [1] For further information and the availability of packing methods, see Section 13. [2] Valid for all available selection groups. All information provided in this document is subject to legal disclaimers. Rev. 9 — 25 September 2012 © Nexperia B.V. 2017. All rights reserved 8 of 15 BC846 series Nexperia 65 V, 100 mA NPN general-purpose transistors 10. Soldering 3.3 2.9 1.9 solder lands solder resist 3 2 1.7 solder paste occupied area 0.6 (3×) 0.7 (3×) Dimensions in mm 0.5 (3×) 0.6 (3×) 1 sot023_fr Fig 12. Reflow soldering footprint SOT23 (TO-236AB) 2.2 1.2 (2×) 1.4 (2×) solder lands 4.6 solder resist 2.6 occupied area Dimensions in mm 1.4 preferred transport direction during soldering 2.8 4.5 sot023_fw Fig 13. Wave soldering footprint SOT23 (TO-236AB) BC846_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 25 September 2012 © Nexperia B.V. 2017. All rights reserved 9 of 15 BC846 series Nexperia 65 V, 100 mA NPN general-purpose transistors 2.65 1.85 1.325 solder lands solder resist 2 2.35 0.6 (3×) 3 solder paste 1.3 1 occupied area 0.5 (3×) Dimensions in mm 0.55 (3×) sot323_fr Fig 14. Reflow soldering footprint SOT323 (SC-70) 4.6 2.575 1.425 (3×) solder lands solder resist occupied area 1.8 3.65 2.1 09 (2×) Dimensions in mm preferred transport direction during soldering sot323_fw Fig 15. Wave soldering footprint SOT323 (SC-70) BC846_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 25 September 2012 © Nexperia B.V. 2017. All rights reserved 10 of 15 BC846 series Nexperia 65 V, 100 mA NPN general-purpose transistors 2.2 1.7 solder lands solder resist 1 0.85 2 solder paste 0.5 (3×) occupied area Dimensions in mm 0.6 (3×) 1.3 sot416_fr Fig 16. Reflow soldering footprint SOT416 (SC-75) BC846_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 25 September 2012 © Nexperia B.V. 2017. All rights reserved 11 of 15 BC846 series Nexperia 65 V, 100 mA NPN general-purpose transistors 11. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes BC846_SER v.9 20120925 Product data sheet - Modifications: • BC846_SER v.8 Table 6 “Limiting values”: Ptot values corrected BC846_SER v.8 20120424 Product data sheet BC846_BC546_SER v.7 20091117 Product data sheet - BC846_BC546_SER v.6 BC846_BC546_SER v.6 20060207 Product data sheet - - BC846_SER Product data sheet BC846_BC546_SER v.7 All information provided in this document is subject to legal disclaimers. Rev. 9 — 25 September 2012 © Nexperia B.V. 2017. All rights reserved 12 of 15 BC846 series Nexperia 65 V, 100 mA NPN general-purpose transistors 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. BC846_SER Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 8 — 25 September 2012 © Nexperia B.V. 2017. All rights reserved 13 of 15 BC846 series Nexperia 65 V, 100 mA NPN general-purpose transistors Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 13. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com BC846_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 25 September 2012 © Nexperia B.V. 2017. All rights reserved 14 of 15 Nexperia BC846 series 65 V, 100 mA NPN general-purpose transistors 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Packing information . . . . . . . . . . . . . . . . . . . . . 8 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 25 September 2012
BC846BW,115
1. 物料型号:BC846,这是一款NPN型硅晶体管,常用于音频和视频放大器、开关应用等。
2. 器件简介:BC846是一种小信号晶体管,具有高增益和低噪声特性,适合用于音频放大和信号处理。
3. 引脚分配:该晶体管有三个引脚,分别是基极(B)、集电极(C)和发射极(E)。
4. 参数特性: - 最大集电极电流(Ic):200 mA - 集电极-发射极击穿电压(BVceo):45 V - 电流增益(hFE):在100到600之间,具体值取决于具体的工作条件。
5. 功能详解:BC846晶体管可以用于放大微弱的信号,如音频信号,或者作为开关使用,控制较大的电流。
6. 应用信息:适用于音频放大器、视频放大器、开关应用等。
7. 封装信息:提供多种封装选项,包括SOT-23、SOT-89等小型封装,便于在不同的应用场景中使用。
BC846BW,115 价格&库存
很抱歉,暂时无法提供与“BC846BW,115”相匹配的价格&库存,您可以联系我们找货
BC846BW,115
  • 20+0.96420
  • 100+0.57500
  • 800+0.40250
  • 3000+0.28750
  • 6000+0.27300
  • 30000+0.25300
库存:45652
BC846BW,115
  • 1+0.18700
  • 3000+0.16500
库存:45067
BC846BW,115
  • 50+0.10488
BC846BW,115
  • 1+0.093301+0.01210
  • 100+0.09070100+0.01180
  • 500+0.08220500+0.01070
  • 3000+0.063403000+0.00820
库存:2133
