PMBS3906,215
PMBS3906,215
    NEXPERIA(安世)
    SOT-23
    PNP通用晶体管
PMBS3906,215 数据手册
PMBS3906 40 V, 100 mA PNP general-purpose transistor 5 June 2018 Product data sheet 1. General description PNP general-purpose transistor in a small SOT23 (TO-236AB) Surface-Mounted Device (SMD) plastic package. NPN complement: PMBS3904 2. Features and benefits • 100 mA collector current capability 3. Applications • General-purpose switching and amplification 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - -40 V IC collector current - - -100 mA hFE DC current gain 100 - 300 VCE = -1 V; IC = -10 mA; Tamb = 25 °C 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 B base 2 E emitter 3 C collector Simplified outline Graphic symbol 3 C B E 1 2 TO-236AB (SOT23) 006aab259 PMBS3906 Nexperia 40 V, 100 mA PNP general-purpose transistor 6. Ordering information Table 3. Ordering information Type number Package PMBS3906 Name Description Version TO-236AB plastic surface-mounted package; 3 leads SOT23 7. Marking Table 4. Marking codes Type number Marking code[1] PMBS3906 %O6 [1] % = placeholder for manufacturing site code 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - -40 V VCEO collector-emitter voltage open base - -40 V VEBO emitter-base voltage open collector - -5 V IC collector current - -100 mA ICM peak collector current - -200 mA IBM peak base current - -200 mA Ptot total power dissipation - 250 mW Tj junction temperature - 150 °C Tamb ambient temperature -65 150 °C Tstg storage temperature -65 150 °C Tamb ≤ 25 °C 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air [1] [1] Min Typ Max Unit - - 500 K/W Device mounted on an FR4 Printed-Circuit Board (PCB). PMBS3906 Product data sheet All information provided in this document is subject to legal disclaimers. 5 June 2018 © Nexperia B.V. 2018. All rights reserved 2 / 10 PMBS3906 Nexperia 40 V, 100 mA PNP general-purpose transistor 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = -30 V; IE = 0 A; Tamb = 25 °C - - -50 nA IEBO emitter-base cut-off current VEB = -5 V; IC = 0 A; Tamb = 25 °C - - -50 nA hFE DC current gain VCE = -1 V; IC = -0.1 mA; Tamb = 25 °C 60 - - VCE = -1 V; IC = -1 mA; Tamb = 25 °C 80 - - VCE = -1 V; IC = -10 mA; Tamb = 25 °C 100 - 300 VCE = -1 V; IC = -50 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C 60 - - VCE = -1 V; IC = -100 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C 30 - - IC = -10 mA; IB = -1 mA; Tamb = 25 °C - - -250 mV IC = -50 mA; IB = -5 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C - - -400 mV base-emitter saturation IC = -10 mA; IB = -1 mA; Tamb = 25 °C voltage IC = -50 mA; IB = -5 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C - - -850 mV - - -950 mV td delay time - - 50 ns tr rise time - - 50 ns ton turn-on time - - 100 ns ts storage time - - 600 ns tf fall time - - 100 ns toff turn-off time - - 700 ns Cc collector capacitance VCB = -5 V; IE = 0 A; ie = 0 A; f = 100 MHz; Tamb = 25 °C - - 4.5 pF Ce emitter capacitance VEB = -0.5 V; IC = 0 A; ic = 0 A; f = 100 MHz; Tamb = 25 °C - - 12 pF fT transition frequency VCE = -20 V; IC = -10 mA; f = 100 MHz; Tamb = 25 °C 150 - - MHz NF noise figure VCE = -5 V; IC = -100 µA; RS = 1 kΩ; 10 Hz < f < 15700 Hz; Tamb = 25 °C - - 4 dB VCEsat VBEsat collector-emitter saturation voltage PMBS3906 Product data sheet IC = -10 mA; IBon = -1 mA; IBoff = 1 mA; Tamb = 25 °C All information provided in this document is subject to legal disclaimers. 5 June 2018 © Nexperia B.V. 2018. All rights reserved 3 / 10 PMBS3906 Nexperia 40 V, 100 mA PNP general-purpose transistor mbh726 300 hFE 200 VCE = - 5 V 100 0 - 10- 1 Fig. 1. -1 - 102 - 10 IC (mA) - 103 DC current gain as a function of collector current; typical values 11. Test information VBB RB VCC RC (probe) oscilloscope 450 Ω Vo (probe) 450 Ω R2 VI oscilloscope DUT R1 mgd624 VI = -5 V; T = 500 µs; tp = 10 µs; tr = tf ≤ 3 ns. R1 = 56 Ω; R2 = 2.5 kΩ; RB = 3.9 kΩ; RC = 270 Ω. VBB = 1.9 V; VCC = 3 V. Oscilloscope: input impedance Zi = 50 Ω. Fig. 2. Test circuit or switching times PMBS3906 Product data sheet All information provided in this document is subject to legal disclaimers. 5 June 2018 © Nexperia B.V. 2018. All rights reserved 4 / 10 PMBS3906 Nexperia 40 V, 100 mA PNP general-purpose transistor 12. Package outline Plastic surface-mounted package; 3 leads SOT23 B D A E X HE v A 3 Q A A1 1 c 2 e1 bp w B Lp e detail X 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A A1 1.1 0.1 0.9 D E 0.48 0.15 bp c 3.0 1.4 0.38 0.09 2.8 1.2 e e1 1.9 0.95 HE Lp Q 2.5 0.45 0.55 2.1 0.15 0.45 v w 0.2 0.1 sot023_po Outline version SOT23 Fig. 3. References IEC JEDEC JEITA European projection Issue date 14-06-19 14-09-22 TO-236AB Package outline TO-236AB (SOT23) PMBS3906 Product data sheet All information provided in this document is subject to legal disclaimers. 5 June 2018 © Nexperia B.V. 2018. All rights reserved 5 / 10 PMBS3906 Nexperia 40 V, 100 mA PNP general-purpose transistor 13. Soldering 3.3 2.9 1.9 solder lands 3 solder resist 2 1.7 solder paste occupied area 0.6 (3×) 0.7 (3×) Dimensions in mm 0.5 (3×) 0.6 (3×) 1 Fig. 4. sot023_fr Reflow soldering footprint for TO-236AB (SOT23) 2.2 1.2 (2×) 1.4 (2×) solder lands 4.6 solder resist 2.6 occupied area Dimensions in mm 1.4 preferred transport direction during soldering 2.8 4.5 Fig. 5. sot023_fw Wave soldering footprint for TO-236AB (SOT23) PMBS3906 Product data sheet All information provided in this document is subject to legal disclaimers. 5 June 2018 © Nexperia B.V. 2018. All rights reserved 6 / 10 PMBS3906 Nexperia 40 V, 100 mA PNP general-purpose transistor 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PMBS3906 v.3 20180605 Product data sheet - PMBS3906 v.2 Modifications: • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. PMBS3906 v.2 20040202 Product data sheet - PMBS3906 v.1 PMBS3906 v.1 19990422 Product data sheet - - PMBS3906 Product data sheet All information provided in this document is subject to legal disclaimers. 5 June 2018 © Nexperia B.V. 2018. All rights reserved 7 / 10 PMBS3906 Nexperia 40 V, 100 mA PNP general-purpose transistor Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. 15. Legal information Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. PMBS3906 Product data sheet Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. All information provided in this document is subject to legal disclaimers. 5 June 2018 © Nexperia B.V. 2018. All rights reserved 8 / 10 PMBS3906 Nexperia 40 V, 100 mA PNP general-purpose transistor Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PMBS3906 Product data sheet All information provided in this document is subject to legal disclaimers. 5 June 2018 © Nexperia B.V. 2018. All rights reserved 9 / 10 PMBS3906 Nexperia 40 V, 100 mA PNP general-purpose transistor Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................1 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 2 9. Thermal characteristics............................................... 2 10. Characteristics............................................................ 3 11. Test information..........................................................4 12. Package outline.......................................................... 5 13. Soldering..................................................................... 6 14. Revision history..........................................................7 15. Legal information.........................................................8 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 5 June 2018 PMBS3906 Product data sheet All information provided in this document is subject to legal disclaimers. 5 June 2018 © Nexperia B.V. 2018. All rights reserved 10 / 10
PMBS3906,215 价格&库存
很抱歉,暂时无法提供与“PMBS3906,215”相匹配的价格&库存,您可以联系我们找货
PMBS3906,215
  • 1+1.056801+0.13633
  • 10+0.6532910+0.08428
  • 100+0.39902100+0.05148
  • 500+0.28726500+0.03706
  • 1000+0.250971000+0.03238
库存:7003
PMBS3906,215
    • 50+0.10093
    • 150+0.08642
    • 1000+0.07192
    • 5000+0.06612
