BC817DS,115
BC817DS,115
    NEXPERIA(安世)
    TSOP-6
    通用三极管 45V 500mA NPN+NPN TSOP6_3.1X1.7MM 160~400
BC817DS,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia DISCRETE SEMICONDUCTORS DATA SHEET dbook, halfpage M3D302 BC817DS NPN general purpose double transistor Product data sheet Supersedes data of 2002 Aug 09 2002 Nov 22 NXP Semiconductors Product data sheet NPN general purpose double transistor FEATURES BC817DS QUICK REFERENCE DATA • High current (500 mA) SYMBOL • 600 mW total power dissipation VCEO collector-emitter voltage 45 V IC collector current (DC) 500 mA ICM peak collector current 1 A • Replaces two SOT23 packaged transistors on same PCB area. APPLICATIONS PARAMETER MAX. UNIT PINNING • General purpose switching and amplification PIN • Push-pull amplifiers • Multi-phase stepper motor drivers. DESCRIPTION 1, 4 emitter TR1; TR2 2, 5 base TR1; TR2 6, 3 collector TR1; TR2 DESCRIPTION NPN transistor pair in a SOT457 (SC-74) plastic package. handbook, halfpage 6 MARKING TYPE NUMBER 6 5 5 4 4 TR2 MARKING CODE TR1 BC817DS N3 1 2 Top view Fig.1 3 1 2 3 MAM340 Simplified outline (SOT457) and symbol. LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 60134). SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT Per transistor unless otherwise specified VCBO collector-base voltage open emitter − 50 V VCEO collector-emitter voltage open base − 45 V VEBO emitter-base voltage open collector − 5 V IC collector current (DC) − 500 mA ICM peak collector current − 1 A IBM peak base current − 200 mA Ptot total power dissipation − 370 mW Tstg storage temperature −65 +150 °C Tj junction temperature − 150 °C Tamb operating ambient temperature −65 +150 °C − 600 mW Tamb ≤ 25 °C; note 1 Per device Ptot total power dissipation Tamb ≤ 25 °C; note 1 Note 1. Device mounted on a printed-circuit board; single sided copper; tinplated; mounting pad for collector 1 cm2. 2002 Nov 22 2 NXP Semiconductors Product data sheet NPN general purpose double transistor BC817DS THERMAL CHARACTERISTICS SYMBOL Rth j-a PARAMETER CONDITIONS thermal resistance from junction to note 1 ambient VALUE UNIT 208 K/W Note 1. Device mounted on a printed-circuit board; single sided copper; tinplated; mounting pad for collector 1 cm2. CHARACTERISTICS Tamb = 25 °C unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN. TYP. MAX. UNIT Per transistor VCB = 20 V; IE = 0 − − 100 nA VCB = 20 V; IE = 0; Tj = 150 °C − − 5 μA VEB = 5 V; IC = 0 − − 100 nA VCE = 1 V; IC = 100 mA; note 1 160 − 400 VCE = 1 V; IC = 500 mA; note 1 40 − − − − 700 mV VCE = 1 V; IC = 500 mA; notes 1 and 2 − − 1.2 V collector capacitance VCB = 10 V; IE = Ie = 0; f = 1 MHz − 5 − pF transition frequency VCE = 5 V; IC = 10 mA; f = 100 MHz 100 − − MHz ICBO collector-base cut-off current IEBO emitter-base cut-off current hFE DC current gain VCEsat collector-emitter saturation voltage IC = 500 mA; IB = 50 mA; note 1 VBE base-emitter voltage Cc fT Notes 1. Pulse test: tp ≤ 300 μs; δ ≤ 0.02. 2. VBE decreases by approximately −2 mV/K with increasing temperature. 2002 Nov 22 3 NXP Semiconductors Product data sheet NPN general purpose double transistor MBL747 500 BC817DS MBL748 1000 IC handbook, halfpage handbook, halfpage hFE (mA) 800 (1) 400 (1) (2) (3) (4) (5) (6) (7) 300 (8) 600 (9) (2) 400 200 (10) (3) 100 200 0 10−1 1 10 102 0 103 2 0 IC (mA) VCE = 1 V. (1) Tamb = 150 °C. (2) Tamb = 25 °C. (3) Tamb = −55 °C. (1) IB = 15 mA. (2) IB = 13.5 mA. (3) IB = 12 mA. (4) IB = 10.5 mA. Fig.2 Fig.3 DC current gain as a function of collector current; typical values. MBL749 103 handbook, halfpage 4 6 (5) IB = 9 mA. (6) IB = 7.5 mA. (7) IB = 6 mA. (8) IB = 4.5 mA. 8 10 VCE (V) (9) IB = 3 mA. (10) IB = 1.5 mA. Collector current as a function of collector-emitter voltage; typical values. MBL750 1200 VBE handbook, halfpage (mV) 1000 VCEsat (mV) (1) 800 (2) 102 600 (1) (3) 400 (2) (3) 10 10−1 1 10 102 200 10−1 103 IC (mA) IC/IB = 10. VCE = 1 V. (1) Tamb = 150 °C. (2) Tamb = 25 °C. (3) Tamb = −55 °C. (1) Tamb = −55 °C. (2) Tamb = 25 °C. (3) Tamb = 150 °C. Fig.4 Fig.5 Collector-emitter saturation voltage as a function of collector current; typical values. 2002 Nov 22 4 1 10 102 IC (mA) 103 Base-emitter voltage as a function of collector current; typical values. NXP Semiconductors Product data sheet NPN general purpose double transistor BC817DS PACKAGE OUTLINE Plastic surface mounted package; 6 leads SOT457 D E B y A HE 6 X v M A 4 5 Q pin 1 index A A1 c 1 2 3 Lp bp e w M B detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.1 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION SOT457 2002 Nov 22 REFERENCES IEC JEDEC EIAJ SC-74 5 EUROPEAN PROJECTION ISSUE DATE 97-02-28 01-05-04 NXP Semiconductors Product data sheet NPN general purpose double transistor BC817DS DATA SHEET STATUS DOCUMENT STATUS(1) PRODUCT STATUS(2) DEFINITION Objective data sheet Development This document contains data from the objective specification for product development. Preliminary data sheet Qualification This document contains data from the preliminary specification. Product data sheet Production This document contains the product specification. Notes 1. Please consult the most recently issued document before initiating or completing a design. 2. The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. DISCLAIMERS General ⎯ Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Terms and conditions of sale ⎯ NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. Right to make changes ⎯ NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use ⎯ NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. No offer to sell or license ⎯ Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control ⎯ This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Applications ⎯ Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Quick reference data ⎯ The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values ⎯ Stress above one or more limiting values (as defined in the Absolute Maximum Ratings 2002 Nov 22 6 NXP Semiconductors Customer notification This data sheet was changed to reflect the new company name NXP Semiconductors. No changes were made to the content, except for the legal definitions and disclaimers. Contact information For additional information please visit: http://www.nxp.com For sales offices addresses send e-mail to: salesaddresses@nxp.com © NXP B.V. 2009 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands 613514/02/pp7 Date of release: 2002 Nov 22 Document order number: 9397 750 10582
BC817DS,115 价格&库存
很抱歉,暂时无法提供与“BC817DS,115”相匹配的价格&库存,您可以联系我们找货
BZT52H-B22,115
    库存:66000
    BC817DS,115
    • 5+0.55301
    • 20+0.50450
    • 100+0.45599
    • 500+0.40748
    • 1000+0.38484
    • 2000+0.36867
