NPN SILICON RF TRANSISTOR
Feature
High gain:︱S21e︱2 TYP. Value is 10dB
Low noise: NF
TYP. Value is 1.7dB
fT (TYP.) :
TYP. Value is 6.5GHz
@ VCE=10V,IC=20mA,f=1GHz
@ VCE=10V,IC=7mA,f=1GHz
PIN DEFINITION:
1:
(Base) 2:
(Collector) 3:
(Emitter)
SOT-89
Absolute Maximum Ratings TA=25℃ Unless Otherwise noted
PARAMETER
Collector-base breakdown voltage
Collector-emitter breakdown voltage
Emitter-base breakdown voltage
Collector current
*Collector Power Dissipation
Junction Temperature
Storage Temperature
SYMBLE
MAXIMUM VALUE
UNIT
VCBO
VCEO
VEBO
IC
*PD
Tj
Tstg
3
100
1.2
150
-65 ~ +150
V
V
V
mA
W
*With heat dissipation panel
hFE Classification
Classification
A
B
Marking
RH
RF
hFE
60~100
90~140
C
D
E
RE
130~180
1 of 3
170~250
250~300
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
PARAMETER
SYMBLE
MIN.
VCBO
VCEO
ICBO
IEBO
hFE
fT
Collector- Emitter breakdown voltage
Collector cut-off current
Emitter cut-off current
DC current gain
Transit frequency
Power gain
Cre
| S21e |2
Noise factor
NF
Output feedback capacitance
UNIT
TEST CONDITION
V
12
V
μA
μA
IC=1.0μA
IC=100μA
VCB=10V
VEB=1V
VCE=10V,IC=20mA
VCE=10V,IC=20mA
VCB=10V,IE=0mA,f=1MHz
VCE=10V,IC=40mA,f=1GHz
VCE=10V,Ic=7mA,f=1GHz
60
TYP.
150
MAX.
0.1
0.1
300
6.5
0.65
9
Package &Dimension:
SOT-89
2 of 3
10
2.6
3.2
1.7
2.3
GHz
pF
dB
dB
3 of 3
很抱歉,暂时无法提供与“2SC3357-RF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.32635
- 200+0.30430
- 600+0.28225
- 3000+0.26020
