RS1AG THRU RS1MG
Surface Mount Fast Recovery Rectifiers
PINNING
Reverse Voltage - 50 to 1000 V
PIN
Forward Current - 1 A
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Fast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: RS1A~RS1M
Simplified outline SMA and symbol
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
RS1AG
RS1BG
RS1DG
RS1GG
RS1JG
RS1KG
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
1
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
30
A
Maximum Forward Voltage at 1 A
VF
1.3
V
IR
5
50
μA
Cj
15
pF
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
t rr
150
250
RS1MG Units
500
ns
RθJA
75
°C/W
T j , T stg
-55 ~ +150
°C
(2)P.C.B. mounted with 1.0 X 1.0" (2.54 X 2.54 cm) copper pad areas.
1 of 3
RS1AG THRU RS1MG
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
175
100
T J =125°C
10
1.0
T J =25°C
0.1
00
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
1.0
1.5
2.0
2.5
Peak Forward Surage Current (A)
100
120
140
T J =25°C
10
30
25
10
8.3 ms Single Half Sine Wave
(JEDEC Method)
10
1.0
10
Reverse Voltage (V)
35
1
80
100
0.1
Fig.5 Maximum Non-Repetitive Peak
00
60
1
0.5
Instaneous Forward Voltage (V)
05
40
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
100
Number of Cycles
2 of 3
100
RS1AG THRU RS1MG
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
The recommended mounting pad size
2.4
(94)
a
0.3
12
Marking
Type number
Marking code
RS1AG
RS1A
1.8
(71)
1.8
(71)
1.8
(71)
g
e
A
D
mm
Unit :
(mil)
3 of 3
RS1BG
RS1B
RS1DG
RS1D
RS1GG
RS1G
RS1JG
RS1J
RS1KG
RS1K
RS1MG
RS1M
很抱歉,暂时无法提供与“RS1MG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.06629
- 500+0.06239
- 2000+0.05459
- 5000+0.05069
- 15000+0.04680
- 30000+0.04485
- 国内价格
- 1+0.00790
- 1000+0.00680
- 3000+0.00600
- 10000+0.00500
- 50000+0.00480
