2SC3356K
2SC3356K
    SK(時科)
    SOT-23
    NPN 硅射频晶体管
2SC3356K 数据手册
  NPN N SILICON N RF TRA ANSISTOR 3 ·U Ultra high freequency low w noise transsistor ·Silicon epitaxxial bipolar process. p High power gain, g low nooise figure, ·H ·hiigh dynamicc range and ideal currennt characterisstics, ·SC-59 chip package, p maiinly used in VHF, UHF and CATV a ·hiigh frequenccy widebandd low noise amplifier. 2 1 SC C-59 Feaature Highh gain:︱S211e︱2 TYP. Value is 11ddB Low w noise: NF TYP.. Value is 1.55dB fT (T TYP.) : TYP P. Value is 7G GHz 1:Baase 2:Em mitter 3:C Collector @ VCE=10V,IC=20mA,f=1GHz @ VCE=10V,IC=7mA, f=1GHz @ VCE=10V,IC=20mA,f=1GHz ℃ Unless Otherw wise noted Abssolute Maximum Ratiings TA=25℃ PAR RAMETER Colllector-base breakdown b vooltage Colllector-emitteer breakdownn voltage Emiitter-base breeakdown volttage Colllector currennt Colllector Powerr Dissipation Juncction Temperrature Storrage Temperaature SYMBLE E MAXIM MUM VALUE U UNIT VCBO VCEO VEBO IC PD Tj Tstg 20 12 3 100 200 150 -65 ~ +150 ℃ V V V m mA m mW ℃ Tstg hFE E Classificaation (@VC CE=10V,IC C=20mA) B C Claassification M Marking R R24 hFE 90--140 130-1180 D R25 170-250   1 of 3    ELE ECTRICAL CHARACTERISTICS (T ( a=25℃ unlless otherwisse specified) PARA AMETER SY YMBLE M MIN. Colllector-base breakdown b v voltage VCBO ICBO IEBO fT 20 Collector cut-off c currennt Emitter cuut-off currennt Transit frequency TYP. 0.1 0.1 5 7 0.65 Pow wer gain Cre | S21e |2 Noisse factor NF 1.5 Output feeddback capacittor MAX. 11 U UNIT TEST CO ONDITION V IC=1 1.0μA VCB B=10V VEB B=1V VCE=10V V,IC=20mA VC CB=10V,IE= =0mA,f=1M MHz VCE=10V,IC=20mA,f=1G = GHz VCE=10V,IC=7mA,f=1G = GHz μA μA GHz pF dB dB   PAC CKAGE:SC C-59 1:( (Base) 2:(Emitter) 3:(Colllector)   2 of 3    Tyypical characcteristic curv ves (TA =25℃)                     3 of 3
2SC3356K
物料型号:2SC3356K
器件简介:NPN型硅高频低噪声射频晶体管,采用硅外延双极型工艺,具有高功率增益、低噪声系数、高动态范围和理想的电流特性,主要用于VHF、UHF和CATV的高频宽带低噪声放大器。
引脚分配:1. Base (基极) 2. Emitter (发射极) 3. Collector (集电极)
参数特性: - 增益:|S21|^2典型值为11dB @ VCE=10V, IC=20mA, f=1GHz - 噪声系数:NF典型值为1.5dB @ VCE=10V, IC=7mA, f=1GHz
绝对最大额定值: - 集-基击穿电压 VCBO: 20V - 集-射击穿电压 VCEO: 12V - 发-基击穿电压 VEBO: 3V - 集电极电流 IC: 100mA - 集电极功耗 PD: 200mW - 结温 Ti: 150°C - 存储温度 Tstg: -65°C ~ +150°C
hFE电流增益分类: - R24: hFE 90-140 - R25: hFE 130-180
封装信息:SC-59
2SC3356K 价格&库存
很抱歉,暂时无法提供与“2SC3356K”相匹配的价格&库存,您可以联系我们找货
2SC3356K
    • 5+0.28042
    • 20+0.25568
    • 100+0.23093
    • 500+0.20619
    • 1000+0.19464
    • 2000+0.18640
    库存:4865
